combat arms
kiddieboy12
sloowlag
i play combat arms, an dim also very good at it:)
but lately i have been lagging
when i play it i get 20-30fps, using fraps (not recoding)
the requirments is very low for combat arms
REQUIREMENTS MINIMUM RECOMMENDED
OS Windows 2000 Windows XP or better
CPU Pentium 3 - 1GHz+ Pentium 4 - 2.4GHz+
MEMORY 256Mb RAM 512Mb RAM
VIDEO CARD GeForce 2 MX GeForce FX 5600 or better
DIRECT X Version 9.0C or later Version 9.0C or later
HARD DISK SPACE 2.0 Gb 2.0 Gb
INTERNET CONNECTION Cable/DSL Cable/DSL or better
os...owned vista home premiure
cpu..owned 2.2x2
memory..3gb owned
video card..owned?? idk i got a nvdia geforce 6150 nforce 430(built in)
direct x 9 ..owned
hard drive...200gb avalible
internet ..dsl
so my question, is what graphic card is good for it? i want to be able to get 100fps while recording..
do you think a nvdia 8600gt would do? or will some one recommend me a raedon card?
i am kinda on a budget, you can say, lets just no go over 70$.
i do make money, but im running kinda low, on my budget
    amd 64x2 4200+ 2.2ghz per core
    ECS NETTLE
    3 gb
    nvdia 6150se nforce 430(old rig, upgrading)
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    upgrading, Coolmax CA-450 450watts
    hp casing
    defult..
    hp
    hp
    768kbps down and 128 up...very slow..
    not great compared to other people..
Try looking at a 9600GT instead of the 8600GT. You'll see a better improvement performance wise. Not sure if it will reach 100fps though as I've never played Combat Arms, but I'd imagine it would be fine while recording as well.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
uh yes, it would be overkill, i know a friend on a laptop, 9300m gs and he get 100fps in game, i dont want anything overkill...
also how much is a 9800gt?
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
A 9800 GT is around 100$-130$. pick one up from a local pc/electronics store or get one from an E-tailer like TigerDirect or Newegg.
14-130-435-S03
14-130-435-S01
14-130-435-S06
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130435
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4410177&CatId=3669
    JUST ME/Custom Built
    Intel(R) Core(TM) 2 Quad Q9550 E0 2.83 Ghz @ 4037.5 Ghz
    EVGA NFORCE 790I SLI FTW Digital PWM
    8 Gig Corsair XMS3 DHX 1600 Mhz DDR3 CAS 9
    2x GTX 480's w/ Koolance VID-NX480's
    Creative SoundBlaster X-Fi Titanium (non-Fatal1ty) Edition
    Acer P243W 24" Premium Series
    1920 x 1200
    Seagate Barracuda 7200.11 1 TB HDD 32mb cache (3 Platters, 6 Heads model)
    Ultra X4 1050W PSU 76A Rated 12V SLI
    Antec 1200 Full tower ATX case
    x2 Thermaltake Blue LED 120mm 2800rpm fans, Zalman CNPS 9900
    Logitech LX310 2.4Ghz Wireless Laser Mouse
    Logitech LX310 2.4 Ghz Wireless Keyboard
    32mb Download, 12mb Upload from Comcast
    300$ custom watercooling setup. Antec 1200 big boy Radiator, Dual bay XPSC reservoir with clear bubble window, OCZ hydropulse 800L/H 12v pump, 12 ft tygon 1/2" ID, 3/4" OD tubing, Feser One UV Green 1 L fluid. (and VID-NX480 waterblock)
got it, but i think stick with 8600gts, i got a friend with it, and he said he get 60 fps when he records, that good enought for me
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
of course. my old 8400 GS 512mb ran that game at 55-60 fps easily. its just when i got my first games for windows game is when i realized i had a junk card XD. for what your trying to play, the 8600 gts is perfect. but going to more intense and graphical games will need an upgrade.
    1920 x 1200
lol
a 8400gs?? dayum, im getting a 8600gts i think
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
yup an 8400 GS. of course that 8600 gts has 32 more stream processors which is a good thing. just try playing gears of war for windows with an 8400. lol that gets you about 25 fps at 800 by 600 with everything on medium/low. horrible and thats with dx9.
    1920 x 1200
thx your great help, you try anyother games with it?
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
It wouldn't suprise me if it was the game itself though. I used to play it a few months ago, and didn't play for long, there were to many glitches and bad coding -> which makes me think that's the reason I lagged with my system. Though it may have gotten better between that time and now.
I would say something like a 9400GT though, performance wize it's kind of close to 8600GT and it's not as outdated as the 8*** series.
    Custom built (Myself)
    Intel Core i3
    Asus P7P55-M
    8GB DDR3
    EVGA Nvidia GTX 550Ti FPB
    HP w2207h with Acer H213H
    1680x1050 and 1920x1080
    1 TB WD Caviar Black 32mb cache, 750 GB WD Caviar Blue, 500 GB WD Caviar Blue, 320 GB WD
    Mushkin HP-550 550W Power suppy
    Cooler Master Elite310
    Air
    Microsoft Comfort 1000
    Logitech Access 600
    15 Mb/s up and down
    I also have an Asus G53SW-A1
it has, patched alot of lgtiches and sued some pub hack sites like tgs
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
i tried Bioshock and Tf2 with it as well. basiclly with those games you get about 30-35 at 1024 by 768 with an 8400 GS because those games arent TOO hard on your gpu. For combat arm's, an 8600 GTS is enough for you. that is if you can get one.
    1920 x 1200
