color red gone please help
Gman46
Was wondering if anyone can help me.
i have a NVIDIA GeForce 6150 LE and running Vista Pro 32
Its been 3 weeks i lost the color red. Mind you it came and went a few times. Also in the NVIDIA control panel i can adjust the other colors but red doesnt react. I have tried many drivers and still no fix.
Can anyone help?
Monitor is fine i have tried it on my other pc.
Thx
Can anyone help?
Thx
Gman
It feels like a hardware issue more than software. Might be a bent pin on the graphic card or cable or a loose wire on the card. Can you pull the graphic card and try it on another machine?
Ken J
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
I can't do that. I got a HP Pavilion Slimline which the card is on the motherboard. I tried removing and putting th cable back but didn't work. I guess i can still open up the PC and check it out. Strange thing is that a few days ago it went back to normal but only lasted a few minutes.
If it came back, I lean towards bad cable.
I say that as once the card goes bad, it isn't likely to recover.
Hmm... Have you tried different monitors ? Or checked the cable to the monitor ?
I have seen monitors go out more often than video cards, in my experience anyway.
edit:
On second thought. Its the cable or monitor. The pin on the cable supplying red could be it. Or the red color electronics in the monitor is bad.
Change monitors, and if that isn't it then try another video cable.
    Acer Aspire X1700
    ASUS
    3 gigs
    EVGA 1 gig GeForce 210
    Vizio 21" tv
    1920x1080 resolution
    fans that came with it
    basic USB
    basic USB
Not sure cause i connected the monitor with the same cable to my laptop and everything works fine. Only when i put it back on my pc this happenes. I thought it would be the drivers being faulty with vista.
thx for helping
are you solved or u need more help?
    Intel Pentium Dual Core E5200 Overclocked @ 2.90
    ASUStek
    OCZ DDR2 PC2-6400 Vista Performance Gold 4GB Dual Channel
    ASUStek ENGTX275 PCI-E x 1
    19inch benq
    1400x900
    400 gb
    700 Watt artic power
    Artic cooler
    4.70 mb/s download, 0.37 mb/s upload
no still going crazy. I wish there was a way i can test the grafic card. Makes no sense to me cause in the control panel i can adjust the other colors but the red doesnt even slide its as if its the software.
just nuts
Well, you've ruled out the monitor and the cable, and it's unlikely to be video drivers or setup -- unless you've been messing with the Gamma setting or the RGB mixes.
The most likely culprit is the video chipset in the HP. And, if that's true, the only fix will be an add-in card --which, if there is no room for expansion in the case, rules that out as well.
I'm guessing the unit has been out of warranty for a long time as well, right?
    Home built
    Athlon x64 4400
    ASUS A8n32-deluxe
    OCZ 2GB low-latency 3200
    ATI X1600
    B-enspirer CMI8788
    Samsung 24-inch flat panel
    19290x1280
    WD 320GB SATA II
    350 watt enermax
    Antec PS180
    Logitech wireless
    Logitech G15 gaming
    Broadband -- 15MB
well this what i have done....
got a new video card and nothing doing. I checked out some motherboards and i got one that will match under $65CDN and a new tower Under $60CDN so gonna transfer everything over. Its not costing me much and now i can actually add to my pc which with a slimline u cant. Will post to see if it was my motherboard.
thxs
I had the same problem, also since 3-4 weeks ago. I use a laptop (HP Pavillion DV9000) with an external monitor hooked up. I mistakingly had "autoupdate" setup on my windows vista, and it had updated a new video driver (nvidia). Everything went green (basically, I lost all red). I tried rolling back the driver, but that came close to shutting down my computer (had to system restore). On system restore I got my colors back, but only for a week... it went green again.
For me I could get red from the laptop screen, but not the extended monitor.
I stumbled over the solution.
I right clicked on my desktop screen, clicked the "Nvidia Control Panel."
That didn't load.
So
1. I went to "my computer," click the C:\ and searched Nvidia.
2. I went into the Nvidia folder, clicked the "Display" folder, clicked "Setup" and it tried to setup my drivers.
3. It came up with a message saying it couldn't find the necessary drivers, but as that message came up, my screen instantly went back to normal and has stayed that way since.
Got me ??? But it works.
