CoD4 install problem
Ajic
Hi there,
so my Call of Duty 4 didn't start so I decided to reinstall it. I removed it and now when I try to install it back it says Error 1303 "The installer has insufficient privileges to access this directory "C:\Program Files (x86)\Activison\Call of Duty 4 - Modern Warfare\Mods.
Thanks!
Run the installer from an Administrator account, and right click on it, and click Run as Administrator. Before this,
  • Navigate to the "C:\Program Files (x86)\Activison\Call of Duty 4 - Modern Warfare\Mods" and right click on it and select Properties.
  • Under the Security tab, click Advanced.
  • Under the Owner tab, click Edit.
  • Click "Other Users and Groups".
  • Click Advanced.
  • Click "Find Now".
  • Scroll down and double click on Everyone.
  • Click OK THREE times.
  • Click Edit (now on the standard file Property window under the Security tab).
  • Click Add.
  • Click Advanced.
  • Click "Find Now".
  • Click OK.
  • Single click on Everyone and then tick the "Full Control" box under Allow.
  • Click OK TWO times.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Actually I solved the problem already, I had to install the game to some other folder than default one.
But the startup problem didn't disappear. So I can't still run CoD4 multiplayer. It shows the green guy and logo and then nothing happens. No error message or anything.
Go into your sound options and then in the recording tab and right click to show disabled and enable stereo mix.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Have you patched the game yet?
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
Yes to 1.7
E: I don't know if this is important, but when CoD4 is running it makes a file called __iw3mp. When you close the game it normally deletes the file. But now whenever I start the game the file just stays there, like it would be running all the time.
