COD 4 Inverted Graphics Problem!
xsmallheartx
I have been playing COD 4 and have been noticing that the graphics will 'invert' sometimes, at first i thought this was because of the installation disc as it was VERY, VERY scratched. But I got a new one and installed it again, then I thought it was the graphics card and was replacing it anyway so I chucked it. Then I thought it was the monitor as Vista x64 didn't have drivers for it. So I got a new monitor, reformatted recently, all drivers are installed and I still have the problem.
I went into my ATI Catalyst Control Center and put fan speed to 100% incase the gfx card was over heating... still nothing.
This is what it looks like, as soon as I alt tab it fixes the problem but it is very annoying.
http://i64.photobucket.com/albums/h193/identity01/Cod4invert.jpg
(Check my system spec's)
    Intel Q9450
    GA-X48-DQ6
    OCZ Platnium (800mhz) 2GBx4
    Gigabyte Radeon 4850 512mb
    Samsung 2333SW
    Samsung SATAII 650GB
    Corsair TX 750W
    Antec 900
    Stock
    Razor Lachesis
    Logitech Slim
it maybe something to do with your image settings within the CCC (catalyst control center), have you tried fiddling with them settings to see what difference it makes, it does look to me like mist from GPU processing functions.
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
Do you get the same problem in single player, and on any other game ?
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
    Intel Q9450
    GA-X48-DQ6
    Samsung 2333SW
    Corsair TX 750W
    Antec 900
    Stock
    Razor Lachesis
    Logitech Slim
its cod , cod 5 does it too , the only way i can sort it is by alt/tabbing too , it doesnt happen often but it does happen , lots and LOTS of people have the same issue and so far nothing seems to have been done about it
reducing AA to 0 and AF to 0 seems to help too but who the hell wants to play a game like that?
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
I had this in Crysis, re-installed my driver and it cured it, i have both COD's and have never had this issue, (thank god), do you find if you view the same piece of the map from a different angle it's ok ?.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Nah, it happens randomly. Thanks for everyones help though, I don't play COD much anymore so I don't really mind that much now.
ty
    Intel Q9450
    GA-X48-DQ6
    Samsung 2333SW
    Corsair TX 750W
    Antec 900
    Stock
    Razor Lachesis
    Logitech Slim
