ClearChat comfort USB not detected
Delawynn
Hi guys, long time reader first time poster :D
Now I've been having a weird issue with my ClearChat Comfort USB microphone and I've been asking both Logitech and Microsoft for support. So far, Logitech claims it's Microsoft's problem and Microsoft.... well anyway
I plug my microphone (Certified for Windows Vista) and nothing happens... I mean, there's nothing even in Device Manager. Now there are no drivers for this microphone and I haven't found any hotfix. I thought it was because of Vista 64x but I tried on my laptop using Vista 32 home edition and got the same issue. It worked well on my laptop before Vista Service Pack came out.
Oh and yes, I have the latest version of all~ drivers
Some info :
Intel Core 2 Duo E8400 3.00G/1333/6M/S775
Motherboard : S775 ASUS P5Q SE P45 PCIE
Graphic Card : Geforce 9800 GTX+ DK 512MB
RAM : Kingston DDR2 4 gig
Using Windows Vista Home Edition Premium 64x, and tried on 32x
Hi delawynn,
Welcome to the forum.
Plug in your Headset and right click on the speaker symbol in the notification area, select playback devices. A new window will open and should look like this..see attached (where I have kopfhörer you should have headset)
Let me know please
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
Thanks for the quick answer
Here's what I have in playback device. Looks like the USB headset is not detected. Tried with a USB gamepad and a Ipod, both were detected.
Strange!! have you tried all of your ports? sometimes they are awkward to say the least.
I am no expert with USB headsets but I will see what I can come up with
As a start I think it could possibly be some sort of conflict but that is as far as I get
Pooch
One after thought right click on haut-parleurs and make sure there is a tick in the box for show disabled devices, should your Hedset show up try to enable it and then set as default.
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
all ports are working fine.
USB headset was working fine on my laptop until I installed Vista Service Pack 1.
I'll try contacting Microsoft again.
Did you see my edit?
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
Yep, and Show Disabled Devices was already on. Still nothing.
Sending a request at Microsoft for support.
Headset used to work fine with my laptop before Vista Service Pack 1. Gonna ask them if they can send me a hotfix or something like that.
I'll give some news later
Ok, I'll keep my fingers crossed that they help you,
All the best
Pooch
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
Tested and so far nothing.
EDIT : Some news. so far microsoft has been sending me some hotfix and well... none of them worked. Last thing they asked me was to uninstall Service Pack 1, something I won't be doing.
Some info :
have you checked that it is in the device manager or is it not even being detected in there either, if its not showing, click on the little computer with the spyglass and post your findings
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
Thanks for the advice.
I clicked on the computer with the spyglass and nothing happened.
The USB microphone doesn't show in the Device Manager. I've tried to manually install it and still can't detect it.
I know the microphone isn't broken, it worked fine until some Windows Updates.
I had an answer from Microsoft :
"En regardant dans notre base de données, j'ai retrouvé la source du problème : Service Pack 1 à introduit plusieurs changements au systèmes audio et USB qui peuvent créer des problèmes avec certains carte de son et autre périphériques."
In English : Service Pack 1 made some changes in Audio and USB that could create some issues with soundcards and other devices
thats a bit of a problem, you cant uninstall service pack 1 as it gives you more advantages than disadvantages, the only thing i can suggest is if you buy a microphone that is not usb connected, just make sure that it has a jack input rather than a usb, you can pick up a decent microphone for about 15euros
    16Mb Sky bb
