I have a Dell 2209WA monitor , this is my first lcd (im a gamer and very particular about image quality nothing matches a good old CRT
Dell UltraSharp 2209WA 22" Widescreen LCD Monitor
Anyhoo ive noticed something very annoying , bold type seems to be blurry around the edges and have a very slight red tinge to it
After some research ive put it down to the alaising that clear type adds to text (if i turn clear type off all is well but text looks awfull with cleartype off)
Ive used the XP cleartype powertoy to tweak it a little (yes it works fine on Vista even though it says it wont) and i have got normal text looking better but not ideal i still have the issue with bold text
I have looked at other monitors (friends family etc) and the issue doesnt seem quite as pronounced however they are using low quality displays that dont do anything justice let alone text , they are blurry anyway and i think thats reducing the problem
Its really starting to annoy me so has anyone else had this problem? and solved it?
My monitor is calibrated and the correct colour profile is loaded and selected (just incase you need to know that)
If anyone can solve this issue (im assuming its not solvable) I will come to yours and make you a lovely cup of tea and bring you the biscuits of your choice (half price)
- Custom Build
- Intel Q9550 @ 4Gig / Titan Fenir
- XFX 780i
- 4GB OCZ PC2-8500C5 DDR2
- Gainward GTX260/216 SLI
- Creative X-FI Xtreme Gamer
- Dell UltraSharp 2209WA 22"
- 1680x1050
- western digital raptor 10000rpm sata
- PSU
- OCZ Modstream 700w
- Cooling
- Titan Fenir
- Logitech G5 Gamer
- Razer Reclusa
- 8mb
