Civilization 5 wont start
kec7971
I'm running a 32 bit Vista Ultimate, just bought Civ 5, it installed fine, and i downloaded service pack 2 and a platform update to play the game in the recommended DirectX10 mode, and now everytime i try to load the game, a windows message pops up informing me that a problem has caused Civ 5 to stop working properly and must close. Im increasingly angry and frustrated that nothing i do helps and i've no clue how to resolve this. Can someone please help me so i dont have a $52.00 paperweight and an absurd amount of anger and frustration leading up to an office space moment?
Did you attempt to run it in Compatibilty Mode for Windows XP? Sometimes this works for games like that. Just a side note that to make sure you are hitting the minimum requirements and have a DX10 Card, usually a DX9 card wont work and you wont know it until something like this happens.
    HP Pavilion DV7-1129wm Entertainment PC
    AMD Turion X2 RM-72 Dual Core @ 2.1GHz
    2 x 2 GB Hyundai DDR2 400 MHZ
    ATI Mobility Radeon HD 3200 @ 256 MB
    IDT High Definition Audio/SRS Premium Sound/Altec Lansing
    17" Laptop Screen
    1440 x 900 laptop, external 17 in LCD 1024 x 768
    WD Scorpio Blue 320 GB SATA 5400 RPM Toshiba 68 GB SATA 5400 RPM Second Drive (backup)
    8 Cell Lithium Ion Battery
    Laptop with "light up" HP Logo on outside
    Insane air coming out of Targus dual fan cooler
    Microsoft Wireless Mobile Mouse 3000 / Touchpad
    Full Keyboard with numpad
    Comcast Cable 20 MBps
    Used Primarily for CAD design using SolidWorks 2010. Also I love to watch HD movies using the HDMI output(Netflix). Linked to my Xbox 360 for Windows Media Center 3 USB ports + USB/eSata HP Remote for Windows Media Center and Quickplay Internal Dual Layer DVD+/-RW External HP Lightscribe Dual Layer DVD+/-RW HP Webcam and Microphone
It took me hours before I could get mine to load to the main menu. I found out that the intro video causes problems, so I had to disable that. Also I changed my startup resolution, which wasn't supported by the game in the options menu. If you search around on the net, you will find tons of conversations about it, its a hot topic at the moment.
    AMD Phenom x4 1.8 GHz
    Nvidia 9500GT
    LG 22"
    1920x1080
