Choppy gameplay, fps droping, HELP!
Siimon
Hello there!
I bought a new computer a half year ago.
AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ 3.0GHz
2046MB RAM
Geforce 8600 GT 256MB @ 1680 x 1050
Vista Home Premium 32bit
But when i play World of Warcraft it is choppy, I have "OK" fps.. like 50-60. And other games the fps drop dramatic. Please help me.. It is really annoying. :cry:
You're getting 50-60 FPS? If so that is not bad the game only maxes out at 60 if you have vsync enabled. Unless you're using a CRT and even then I dont see why you wouldnt have it on. Also you have to give more info than just "choppy gameplay". I play the game as well and with it maxed out, like literally I cant set anything higher AA or AF 1680x1050, I am still getting 40FPS average. Anyway give more info and I can try and help. Tell me what settings you're using, what drivers all the usual things.
    AMD AM2 64 6000+
    Asus M2N-E SLI
    4 Gigs DDR2 800
    Nvidia 8800GTS OC2 320MB
    Creative X-Fi Titanium 5.1 Dolby Digital
    Acer 2216W 22Inch
    Hitachi SATA 380GB Windows XP Professional SP 2 Western Digital 300GB Windows Vista Ultimate SP 1
    650 Watt
    Thermaltake III Full Tower
    Logitech MX310
    Saitek Illuminated Desktop Keyboard
    12Mbs
    Built this desktop myself about a year ago so that I could enjoy Crysis. May not be able to max out crysis more than 1440x900 Very High/Enthusiast (which still looks better than any other game :-X) but this desktop has yet to have any other game give it a hard time. Everything else I run in 1680x1050 16xAF 4xAA with Vsync. I love my PC :D
Well atm i dont play WoW anymore. But I play Tibia..My thoughts was that Tibia use directx 9, and Vista use 10. Can that be the problem? And lol i use 32bit, isnt this a 64 forum?
No this is a general discussion board for all versions of the Windows Vista platform. Also, you still didnt give me any more info, such as video driver version or description of the issue. It could be something as simple as windows running services in the background or an anti-virus/spyware program that just needs to be set to not do anything on its own unless at your scheduled time.
Oh and by the way running a DirectX 9 game under vista, at least from my experiances yields exactly the same if not better performance than under XP. So no that should not be a problem. Just so you know I have XP and Vista installed on seperate HDDs that I choose which one I want to use when I start up. 99% of the time its Vista
    AMD AM2 64 6000+
    Asus M2N-E SLI
    4 Gigs DDR2 800
    Acer 2216W 22Inch
    650 Watt
    Logitech MX310
    12Mbs
Tell me exactly what u wanna know, becuase im not that good at computers.. tell me exactly in detail please :) When i play tibia and i run to places where there are alot of ppl i get loow fps.. Normal fps i got is 120 and when i run to places with alot of ppl i get like 50 and then i get lag. But it also random drop fps from 120 to like 70. And i tryed to play Assassin Creed with highest setting, it was laggy.. not good at all. But with lowest detail it run perfect
Your expectations are too high.
Even with a 3GHz Conroe the 8600 GT delivers marginal performance at 1280x1024. 1680 is a big jump; perhaps too much for the card to handle?
AnandTech: 8600 GT/GTS Follow-up Performance
About the only thing you can do is to turn down your settings as low as possible to avoid lag.
    Fumz' Flux-Capacitor
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    500GB W.D. RE2 Primary 1TB W.D. Caviar GP WD10EACS
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
Im not sure where the 8600 stands but I believe I have heard that its not a very good card. Its basically a low end DX10 card. You've got a generally nice system there but you definitely skimped on the GPU. You should have went with a 512 MB graphics card if you wanted performance in 1680x1050. Not to put your choice down or anything as not knowing a lot about computers is not your fault. Look into a 9800GTX or 260 768MB card if you want really good performance. Or at least an 8800GTX. Buying a 256MB card these days for gaming is almost as poor a choice as trying to run Vista with only 1 gig of ram. Speaking of which if you dont have the money to buy a new video card right away buy more ram. Is amazingly cheap like my local small PC shop I go to sells sticks of 1gb ddr2 5300 for 17$. 17$!!! lmao
    AMD AM2 64 6000+
    Asus M2N-E SLI
    4 Gigs DDR2 800
    Acer 2216W 22Inch
    650 Watt
    Logitech MX310
    12Mbs
I tryed 1280 x 800. And then I got 200 fps. So I think it is that my graphic card cant handle 1680~
I have 2gig not 1.. Well Im thinking of a new graphic card.. What card is good? I can spend like 130$ :huh:
I concur, sounds like card is maxed.
If you can scrounge up another $35 you can get this 9800GTX 512 from Newegg with free shipping.
Newegg.com - EVGA 512-P3-N879-AR GeForce 9800 GTX+ 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Desktop Graphics / Video Cards
Best deal out there I think is this one: Geforce GTX 260 896mb for $220 and comes with Farcry2, also free shipping.
Have to make sure it fits your Mobo though, it takes up 2 slots and you might have to get another PSU unless you already have over 500W.
Then again you might be just as well off or maybe better off getting a Geforce 8800GT 512mb. This one is only $95.
Newegg.com - XFX PVT88PYHF4 GeForce 8800 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Desktop Graphics / Video Cards
Then spend $38 on 4GB of good memory.
Newegg.com - Patriot Extreme Performance 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Desktop Memory
    Home Built
    Q6600 @ 2.66ghz
    Asus Maximus Formula
    8GB Patriot PC2 6400
    HT Omega Claro Halo
    Dell 21" 2001FP
    1600X1200
    Western Digital 640GB 32mb cache
    Cooler Master 750W
    Cooler Master ATC 201C-SX1
    Stock Intel CPU fan 4 80X80mm case fans 1 120mm case fan
    Logitech MX Revolution
    Logitech G15 gaming keyboard
    RR cable 10Mbps with 16Mbps boost
    Sennheiser PC350 Headset
