cd-rom problems
Your "My System Specs" are not giving enough information.
What make & model is your CD/DVD drive, computer and what type of recordable disks are you trying to read. Not all models of CD/DVD drives will read all types of CD/DVD disks.
    Custom - Built Myself
    E8400 Core 2 Duo @ 9 X 400
    ASUS P5E3 Deluxe WiFi X38
    4GB OCZ Platinum OCZ3P13332GK
    Gigabyte Radeon HD RX3850 775MHZ 512MB 1.4GHZ GDDR3
    On Board
    Dell SP2208WFP
    1680 X 1050
    1 X 640GB 7200 Western Digital 2 X 500GB 7200 Seagate Barracuda All with cooling fans
    ENERMAX 1000W Galaxy DXX
    CoolerMaster CM690
    Zalman CNPS9700 NT / 4 X 120mm / 1 X 80mm Case Fans
    Microsoft Comfort Optical 3000
    Microsoft Natural Ergonomic Comfort 4000
    10mbps down / 1mbps up - Shaw Xtreme
    Lg GGC-H20L BLU-RAY HD-DVD Reader BD-ROM DVD+-RW 16X8X6 DL 4X Scythe Multi-Format Card Reader / Floppy Drive
make sure your cd drive can read the type of disc you have in there such as dvd -r or dvd +r etc... also if this persists then you should up date the driver and if that does not work and your cd rom worked before just rollback the driver or do a system restore
do this at your own risk but a driver roll back wont hurt the pc lol
hope this helped
    Amd Athlon X2 x64
    2.5 Gb
    80Gb internal 320Gb external
