When I use the CD drive, it would open and bluescreen the comp. This is a new issue, it only happened today. I restarted and then tried to update drivers(they were the newest and vista compatible drivers, and they have worked fine for months) to no avail. I then un-installed the drives and tried to reinstall them. Vista bluescreened right away not allowing me to re-install them. On every start-up try from then on, it would get to the welcome screen and then bluescreen right away. Safe mode is the same way, loads the drivers then blue screens. I had to remove the cd-roms to boot and then check for any soultions. If anyone has any input at all, please post away. Thanks.
Intel Core 2 Quad E6600 2.4Ghz
2x WD 500gig HHD
Lite-On Lightscribe DVD-ROM
Sony DVD-ROM
4 Gig's Patriot DDR2 800
Nvidia 8800GTS
2x WD 500gig HHD
Sony DVD-ROM
Nvidia 8800GTS
