CCleaner for 64bit system
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Hi Bills Carol,
Glad to be of help.
One app. that I use a lot and have always found to be safe is Glaryutilities Free version. In case you want to try it:
Glary Utilities
By coincidence, they are giving away the Pro version free , just for today - you need to download and install it from here in the next 13hrs :
Giveaway of the Day - free licensed software daily. Today: Glary Utilities PRO 2.9 - Glary Utilities Pro offers numerous powerful and easy-to-use system tools and utilities to fix, speed up, maintain and protect your ...
Hope it helps
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
I'm trying to find C Cleaner for a 64bit Vista system to do a bit of Registry clean up. Any help out there?
I'm having a great deal of difficulty locating a free CC Cleaner download for a 64 bit system (Vista). There are several free downloads for 32 bit but the ones that say "free download" for 64 bit start the process then want you to buy something before the job is done. It's quite frustrating. What they are saying is that the download is free but the actual software is not. All I want to do is clean out my registry. Does anyone know if there is a free CC Cleaner download for a 64 bit system?
hi,
There is the free version of Glaryutilities - includes a registry clean module
Glary Utilities
Also Ccleaner - free - includes a registry cleaner module
CCleaner - Home
There is also a free version of Wise Registry cleaner
Free Registry Cleaner, Disk Cleaner - Downloads
All work well on my Vista x64 system
Hope it helps
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
hi,
Glary Utilities
CCleaner - Home
Hope it helps
SIW2
Thanks SIW2. I've already tried these sites and they all take me to Regcure. I hear it's pretty good but I always get the same message that Regcure can only be installed on a 32 bit system. Thanks anyway. I will just have to break down and buy something as soon as I find another job. Talk to you later.
Hi ActionJackson,
That's very strange, none of those links take me to Regcure.
They all go directly to the free download page for those products.
Did you use the exact links I provided? If you did, and you are being sent somewhere else, you may like to scan your pc for infections.
D/l, install , update and scan with these free products
Malwarebytes.org
and
SUPERAntiSpyware.com - Downloads
Hope it helps
SIW2
hi,
Glary Utilities
CCleaner - Home
Hope it helps
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
