Can't See My External Drive - PLEASE HELP!
anxieteze
I have a Maxtor external drive that works perfect when plugged into my Airport Wireless box...i can see it with both my Mac and PC...when i check it, it says it is a Fat32 in the Explorer. When i plug it into my computer directly, it tells me its loaded, makes the noise, but i can't find it in My Computer. I am running Win Vista Premium on a Compaq Laptop and I need to move a large music collection and need to plug it direct for speed! Any ideas????:(
have you got alot of removable devices in my computer?
try safely removing all of them then plug your harddrive in
    Toshiba Satellite Pro l300
    Intel(R) Celeron(R) CPU 550 @ 2.00GHz
    Intel Corp. 88395664Q
    DDR2, PC2-5300 (333 MHz), 1024 MBytes, Hyundai Electronics,DDR2, PC2-5300 (333 MHz), 2048 MBytes, Ap
    Realtek HD Audio
    Matte screen
    1024 x 768 x 4294967296 colors
    120gb SATA 2.5inch FUJITSU MHZ2120BH G1 ATA Device
    Notebook
    Fan cooled
    Logitech Cordless Optical
    Logitech Cordless Desktop EX110
    256Kbps
    I like Spore,Rabbits and I'm a Computer Freak.
what operating systems are running on the machines that it WORKS on?
    built myself & slaved over every last friggin wire ;)
    dual AMD opteron 2384 (8 cores)
    tyan THUNDER s2932-e
    8 banks of kingston 4 GB PC6400 800 Mhz (32 GB total)
    NVIDIA GeForce 8600 GT (X2) SLI'd
    creative sounblaster X-fi platinum
    NEC multisync 2490WUXi 24" LCD (X2) & SAMSUNG 46" flat screen LCD TV
    1920X1200 , 1920X1200 , 1920X1080
    2 hitatchi SAS 15000 rpm 6 western digital caviar black 500 GB sata II 7200 rpm
    550w Silencer Turbocool
    lian-li pc-75B
    14 fans & lots of copper :)
    microsoft wireless optical
    microsoft natural ergonomic 4000
    optonline boost ;)
I can ONLY access it through the network, when i plug it directly into my PC it seems to recognize it, but i cannot see it in My Computer. I am running Vista Premium.
Let me guess, you are plugging it through one of the front USB ports, right? if so, try plugging it from one of the back USB ports, from one of the ones that comes from the mobo and not as an attachment.
I have a 320GB WD passport and I had the same problem with my Vista x64 PC, which as of yet, have not been able to understand why it does it because my XP PC has no issues whatsoever with it no matter what USB port I use... Vista is awesome but very finickee (sp?) and temperamental... sometimes, I hate it because of it.
Fastboy42 is right, perhaps you have to many removable devices and there is a conflict of IRQ's, for testing purposes,try removing some of the one not use much by uninstalling them from the DEvice Manager and see what happens. If that fails, try my first tip.
Good Luck
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
Thanks for your responses....i have 3 USB ports and am only using one with a bluetooth mouse device - the ONLY other thing to show up as connected is the Network deveice - will try to plug the drive into a different USB and give it a shot!
What kind of an external drive is it? MOdel & Brand.
Can you post a pic of explorer where it shows all the folders, etc, etc.
    EVGA GTX260
    1680 x 1050
    Logitech G7
    Logitech G15
its a Maxtor OneTouch 4 500GB...in Disk Management there is no letter assigned, just says size and healthy. Not sure how to upload pics. What pain this is.
It probably has no drive letter. Go to Disk Management (diskmgmt.msc in Run), right click on it and assign a drive letter.
    Dell
    Q6600
    HP w2207h
