Cant load camera or printer cds
slaves
Hi All
Is this different to xp for cd loading? on my 32 bit V H Pr :( the discs spin but dont load what must I do??
Also but not so important can I load xp prof as an additional o/s
Cheers
Sorry forgot to mention it has a nero imageburn burn thing on by prev owner could this be involved
Welcome
It may be a hardware isssue (computer is broken) which I cannot help or a driver problem
If driver problem, go to search by the start button and type device manager
In device manager update the drivers for DVD/CD drives. If it says you have the most up to date uninstall and try to install again. Good luck
I would try the DVD in another computer to make sure its not defective.
Are you sure that the printer and camera are compatible with Vista?
As I undersand that, your XP disc works fine and you are facing the problem with Vista Disc.
Well, XP installation disc is a CD that contains max of 700 MB data, but vista installation disc is a DVD that contains 4.7 GB data.
If you have a CD drive/writer then the DVD wont load at all. :)
First confirm if you have a CD or DVD drive?
If it's a DVD, goto device manager, uninstall the DVD driver -> restart the computer -> Goto DVD drive's (manufacturer's) web site-> download the latest Driver. If the problem with driver or software then it should fix.
Else you can contact your manufacturer.
Welcome
Thanks yes no prob with discs on other machine on xp both loaded no probs I will try the second reply
Welcome
Driver is up to date its optiarc dvd rw will it load cds?
----See my reply at Rich 46 but will try what you say tomorrow
A DVD drive should load CDs.
Although not for your computer here are some ideas
Apple Computers: Troubleshooting the slot load optical disc drive
Hi again
I've looked at camera cd and it is w 98 to xp so that wont work I assume vivitar vivicam 5386
But printer bought new and works on xp vist and w7 so that should load
Presume I can also load camera cd if I put windows xp on this machine-- Easy note-- I have a 7 in one cd with licence and sp1 xp pro and home + tech stuff on it
Laptop has 110 g hdd and 1.5 g ram.
Just goes to show you need to look at cd labels! 1st time I have. Cheers:zip:
Hi All
Cheers
Sorted Printer but won't bother with adding xp from what I have seen on google its nothing but grief also I dont have a vista disk
Sounds like your Autoplay does not work. Go to COMPUTER and double click on the CD reader (when the CD is spinning).
    Dell
    Q6600
    HP w2207h
I gave it a go and it made weird grinding noises and eventually said cyclic redundancy
check
So its only xp it works on,left an email with vivitar as seems others are having same prob with vista
Cheers:confused:
PS
Printer loaded by connecting it first then follow instruct then cd loaded--not as fast as xp!!
check so maybe it only works for xp,
Well I received a reply from Vivitar today errr but they are not called that now they cant help with camera driver so, I connected it up and got he pictures on screen but as soon as I disconnected the camera the folder disappeared any ideas anyone?
Cheers.:rolleyes:
I would think that is what happens. Can you not copy the pictures to a permanent folder.
    Dell
    Q6600
    HP w2207h
I will try that tmoz------ also volume very low is there a quick fix for that? everything is full on.
Cheers
For the volume, go to Playback Devices and play with Levels in Properties.
    Dell
    Q6600
    HP w2207h
Good, I am glad you got your pics.
    Dell
    Q6600
    HP w2207h
