Hello, i have been trying to delete AVG on my computer for a long time, it began when i installed it, then uninstalled it but all files are left and i cant "uninstall" it again because when i look in Add or remove programs it dont appear on the list and when i run setup.exe it wants to install it but i cant install it either because i need a licensekey for it that i dont have. I used to have Unlocker but it dont work on x64 bit systems so i cant use it either. I cant delete the folder because the program is running like 5 progresses on my computer and when i finish any process they start again within seconds...i need space on my computer and the processes is taking much memory so please help me, how can i delete this ****?
thanks /gabbet
thanks /gabbet
