Cannot recognize ethernet or wifi.
macleo
Hola! I got a HP dv6000 and I am having a problemo! Its a newish computer. I bought it nearly new off ebay, and I put vista on it. Vista works and all but it only recognizes the dial up port. The computer has wifi and an ethernet port but it will not detect any network. Does any one know how to work this bad boy?
Did you look in device manager and see any yellow exclamation marks ? You probably need Vista drivers.
On my system , Vista loads it's own drivers for pretty much everything - except the Gigalan drivers, which I have to install.
You might see if there are any for download from HP site for your exact model.
Hope it helps
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Hi macleo
In addition to SIW2's suggestion you should also check that the network adaptors are enabled at BIOS level. Also with Notebook PCs it is normal to have a switch or key combination to enable wireless network.
Hope this helps
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Samsung 32" TV
    68 MB Down 18.5 MB Up
The computer has a switch that says WIRELESS next to it. The light next to it is on either way I flick the switch.
What is device manage and bios?
ok I figure it out. there was a whole bunch of drivers under OTHER with exclamation mark.
I was able to fix most of the driver including internet. But i went to hp web site and it is sayin i have a DV6605us but the label on the screen says DV6000
There are some drivers left and i am using windows to try to find the driver and it says cannot find driver everytime I try it.
Here is a list of the ones not working with yellow exclamaiton mark.
Base system device
Base system device
Coprocessor
Ethernet controller
SM bus controller
So far it appears as if a few drivers were out of data but i fix that so far. it seems to be running decent for a machine with 1gb ram. I just wish i can get ethernet to work, very important to get it working asap
hI macleo,
You may want to run this ...
http://www.vistax64.com/software-tools/176785-vistaforums-sysinfo-tool.html
Once you have all the spec information - you can go to the manufacturer of each component's site and download the latest Vista driver,. The HP site should have drivers for your machine but the actual component manufacturer will have the latest. The same applies for windows update as unfortunately WU tends to lag behind in the driver area.
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    Samsung 32" TV
