Can you help me please ?
mehassan
I have vista operating system on my laptop. I want to install DOS 6.22 as well.
Can I do that? Or is there any way to run it in my laptop?
I will really appreciate you help.
Thanks,
There are several things that you might want to do. Tell me which ones you are interested in, and I will give you more details. You could:
  • Install DOSBOX (basically a DOS emulator that takes a bit of time to get used to)
  • Create a small partition on your hard drive and duel boot Vista nad DOS!
  • Install DOS on an old, small memory stick, and just boot from that when you want to use DOS. This is what I would recommend. It is easy, does not annoy you with bootloaders, and is true DOS. It is also a good way of experimenting with and learning about DOS. I have done this, and it worked very well.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Thank you Richard for quick response.
Can I run any program that work with DOS 6.22 if the third method is used?
If yes, please explain that recommended method.
Kind regards,
Yes you can run any program. Just drop it onto your memory stick in Windows, then run it like any normal application in DOS. I will come back to you on full details on Method 3 this evening, as I have to go out now for a couple of hours.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Insert a suitable memory stick into your computer. PLEASE NOTE: this method will wipe ALL data on the memory stick, so make sure you back it all up first! In theory, you can still use it as a normal memory stick, making sure you don't overwrite any important files etc., but it is slightly more difficult than normal.
Download the HP tool included as an attachment. Although it is HP, it will still work perfectly well on Dell or Acer etc. Once the extraction and install has finished, run:
"C:\DriveKey\HPUSBFW.exe" (assuming you installed it in the default location. HPUSBFW.exe is the GUI version of the command line HPUSBF.exe, and is slightly easier to use.
  • BACKUP YOUR MEMORY STICK DATA!
  • Select your memory stick (get the right one!).
  • Select FAT.
  • Type a short Volume Label if you wish.
  • Check "Create a DOS startup Disk"
  • Browse to your DOS files, the basic DOS files included, or the advanced DOS files included.
  • Click Start
  • When finished, close, and browse memory stick from Computer, to add any extra DOS programs you wish.
Do not worry which set of DOS files you use. You can always add more tools from Windows later.
You may use:
  • Your own DOS files.
  • The basic DOS files (no tools included, you can only view the black screen - you cannot even write a batch file etc.) + your own tools from Windows.
  • The advanced DOS files (basic DOS files plus many tools, Microsoft and useful third party) + your own tools from Windows. Richard Recommend.
To open your new memory stick, when your computer is booting, select Boot Menu then USB bootable media (or similar). You need a compatible motherboard, though all modern motherboards are.
Hope this helps, any problems, post back.
Richard
P.S. In theory at least you could somehow run this from a Virtual PC, and you could in theory still store data on the memory stick, maybe in a new directory.
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
