can someone help?
andee
Ive installed avg antivirus on a friends machine that's running vista but vista isn't recognising it but it seems to be running correctly.
A pop up appears to upgrade to anti virus 09 but it doesn't tell you who its from.
Is the only solution to use a paid for anti virus as avg is free?
windows xp has no problems with it.
Can some one please help???
Don't accept popup Anti Virus 09 is a rogue software.
I'd also install Malwarebytes Antimalware to make sure your system is clean.
antivirus2009-scanner.com - Malwarebytes Security Forums
There are also Avira AntVir Classic and Avast 4.8 Home, both are free. AntiVir has very good detection, but has nag screen when updating.
    AMD Phenom X4 9950
    Gigabyte GA-MA790GP-DS4H
    G-Skill 8 GB PC2-8500 DDR2 SDRAM memory
    Sapphire Radeon HD 4870 1GB GDDR5
    Onboard Realtek ALC889A
    HP 22" Monitor
    1680 x 1050
    2 Western Digital 500 GB SATA 3G 7200 rpm
    Corsair CMPSU-750TX
    Cooler Master CM 690
    6 120mm case fans + 1 80mm case fan
    Logitech Marbal Trackball
    Logitech Media
    Cable
Zlob Trojan
MalwareBytes can get that for you but I suggest you run a full online scan Here at Eset.com also to make sure you don't have something else.
    Personal Build
    Intel E6750 Core 2 Duo
    Asus Commando MoBo (P965/ICH8R)
    4G's Crucial Ballistix Tracer DDR2 PC26400 RAM
    BFG 8800GTS OC2 320MB
    Creative Sound Blaster X-FI Platinum FATAL1TY (next)
    2 x 22" w2207 LCD Monitors
    1- 1680 x 1050, 1 - 1920 x 1080
    3 x 500G SATA II WD Caviar HDD's
    EnerMax NoiseTaker II 600W
    NZXT Lexa Classic (modified, dual doored & windowed)
    Zalman 9700 CPU cooler, 4-120mm fans, 1-90mm
    Logitech Optical Trackman trackball
    NZXT Lexa Classic Case, Zalman 9700 CPU Cooler, 2 DVD Burners c/w LightScribe (Sony, TSST), Enermax NoiseTaker II 600W PSU with Custom Chrome cable sleeving, Hauppauge HDTV TV Tuner Card, 5.1 Logitech Z5500 speakers, 15 in 1 Multi-card reader
