can i go 64 bit
gazz496
a mere mortal
Vista Pro
using the system info at the bottom of this can i run the 64 bit operating system? sounds daft i know i just want to be sure i'm not going to run into trouble when i get it tomorrow
thanks to all who help!!
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    8 GB OCZ 1066 HPC REAPER
    Sapphire 4870 HD 1024mb gddr5
    lg flatron 20.1
    western digital 350gb samsung spinpoint 120gb
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
oh and one other question when i do it will i lose all my apps and have to start again if i'm using the upgrade ultimate 64 version?
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    lg flatron 20.1
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
You can run Vista x64 with that hardware. No problem!
You will have to reformat your hard drive and reinstall all your applications to do so.
You cannot just upgrade.
So be sure to backup any data you do not want to lose before installing the x64 version of Vista.
Good luck.
    My Ever Changing Whim!
    Intel Core 2 Quad 9650
    Intel DQ35JO
    6GB Corsair DDR2 800
    ASUS 9800GT Ultimate
    19 inch Sceptre 19 inch Acer
    1 320GB Seagate SATA 1 250GB Western Digital SATA 1 200GB Maxtor SATA 2x160GB Western Digitals SATA 1 320GB Seagate External 1 120GB Western Digital External 1 80GB Westen Digital External 1 4GB Crucial Flash Drive for Ready Boost
    600watt Fortron Source
    Antec
    Fresh Air
    Razer Diamondback
    Microsoft Natural Ergonamic 4000
    My main rig runs Vista Ultimate or Server 2008. Depending on which Acronis image I decide to load.
bugger oh well just didn't want to reinstall all my stuff,
running vista just now but you can get the upgrade versions a little cheaper, will i need my other copy of vista to do this or will it just overwrite the necessary files?
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    lg flatron 20.1
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
If you mean the upgrade version for x64 ***you cannot upgrade from 32bit to 64bit***
So, in the long run it will not matter, other than you'll need to do 2 installations with an upgrade disc (install clean once and upgrade itself with Vista Key) versus a single installation using a full version disc(clean install with a key first time).
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
You will need to "reformat". There is no "overwriteing".
If you have the upgrade disk you will need to use the work around to get a full fresh install.
In a nut shell that is install vista x64 without inputing a product key. Then after that install is done run the install again from within vista this time useing your product key. There is also a tutorial in this site with detailed insructions on this method of installing vista.
    Intel DQ35JO
    Antec
    Fresh Air
    Razer Diamondback
so from what i gather if i get the ultimate version i can only upgrade to the 32 bit version or spend a wee smidgen extra and get the the full version and go 64 bit on a clean install !!
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    lg flatron 20.1
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
You got it.
    Intel DQ35JO
    Antec
    Fresh Air
    Razer Diamondback
right so it's an extra 20 quid then is it worth going to full 64 bit? knowing the industry is going that way anyway will probably be on here more for help on some stuff but there we go thanks all!!
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    lg flatron 20.1
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
thanks bud much appreciated
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    lg flatron 20.1
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
No, I think what was said should be clarified... you can't simply pop in a disk and upgrade a 32 bit install to 64 bit. The system itself has to be completely reinstalled.
What you can do however, is upgrade from say 32 bit home premium to 64 bit ultimate by purchasing the upgrade disk. You just need to completely reinstall the system to do so.
The only keys that don't work for both 32 or 64 bit are the OEM keys I believe.
    Q9450 @3.4Ghz
    Asus P5Q Deluxe
    8GB Corsair Dominator @ 1066
    Asus AH4850
    Samsung 2235BW
    2x Seagate 750GB 1x Seagate 160GB (IDE)
    Cooler Master Real Power Pro 850
    Cooler Master Cosmos
    Cooler Master V8
    Logitech WAVE Cordless
OEM versions require a new purchase to go from 32bit to 64bit.
All other keys should be usable in both 32bit and 64bit installation.s
Again, though, you cannot upgrade from 32bit to 64bit in any way- you must format and install from scratch.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
English sucks as a language, because going from home premium to ultimate is an upgrade. ;)
    Q9450 @3.4Ghz
    Asus P5Q Deluxe
    Asus AH4850
    Samsung 2235BW
    Cooler Master V8
well thanks to everyone for helping me make the change i got a full version and started from scratch and boy is it smooth i'm really glad i made the change to x64 it seems my computer likes it too now to finding the programmes that don't work and hoping some of my not so old games still work too, first app to install was 3ds max and it runs soooooo smooth i am wondering what i was thinking before well that said you've all been a great help and i really appreciate all the advice and tips you gave.
p.s why do so many people complain about installing an OS it's ridiculously simple as it does it all for you i think the only choice it gave me was choosing the partition oh and what i wanted to be known as when i turned it on must be really tough for some people i guess lol.
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    lg flatron 20.1
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
Yes, it's simple but painfully and ridiculously slow.
I believe my new rig took nearly an hour to install Vista. WTF is it doing in that time?
By comparison, an old Athlon XP 1800 machine I installed ubuntu on, the install took about 20 minutes, and that's including time to download it!
    Q9450 @3.4Ghz
    Asus P5Q Deluxe
    Asus AH4850
    Samsung 2235BW
    Cooler Master V8
installing vista home premium 64 bit took all of 25 minutes for me.... was quite fast.... the problem was then doing all the windows updates....including SP1.... that took almost 2 hours in total.....
    Intel Core 2 Duo E8400 3.0 Ghz
    Asus P5K Pro
    2 times 2GB Kingston (paired) DDR2 PC 6400
    9600GT 512MB
    Samsung SyncMaster 226 CW
    1680X1050
    74GB 10.000 rpm WD raptor 750 GB Samsung F1 750 GB Samsung F1 2 WD 500 GB drives
    Recom Power Engine 600 Watt
    Apevia X-cruiser Blue
    Auras CTC-868 CPU cooler; 7 Zalman 120mm, 1 Papst casesooler
    Logitech wireless trackball
    50 mbit synchronous fibreglass connection
