Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Loading Dump File [C:\Users\K\Desktop\Mini030110-01.dmp]
Symbol search path is: SRV*d:\symbols*[URL]http://msdl.microsoft.com/download/symbols6[/URL]
Executable search path is:
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0xfffff800`0281e000 PsLoadedModuleList = 0xfffff800`029e2dd0
Debug session time: Mon Mar 1 11:54:21.406 2010 (GMT-5)
System Uptime: 0 days 0:05:47.141
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck F7, {fffffa98103a4858, 2b992ddfa232, ffffd466d2205dcd, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!_MMPTE ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : memory_corruption
Followup: memory_corruption
1: kd> !analyze -v
DRIVER_OVERRAN_STACK_BUFFER (f7)
A driver has overrun a stack-based buffer. This overrun could potentially
allow a malicious user to gain control of this machine.
DESCRIPTION
A driver overran a stack-based buffer (or local variable) in a way that would
have overwritten the function's return address and jumped back to an arbitrary
address when the function returned. This is the classic "buffer overrun"
hacking attack and the system has been brought down to prevent a malicious user
from gaining complete control of it.
Do a kb to get a stack backtrace -- the last routine on the stack before the
buffer overrun handlers and bugcheck call is the one that overran its local
variable(s).
Arguments:
Arg1: fffffa98103a4858, Actual security check cookie from the stack
Arg2: 00002b992ddfa232, Expected security check cookie
Arg3: ffffd466d2205dcd, Complement of the expected security check cookie
Arg4: 0000000000000000, zero
Debugging Details:
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
FAULTING_MODULE: fffff8000281e000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 0
DEFAULT_BUCKET_ID: CODE_CORRUPTION
SECURITY_COOKIE: Expected 00002b992ddfa232 found fffffa98103a4858
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0xF7
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffffa6000b92ab6 to fffff80002878450
STACK_TEXT:
fffffa60`103a3708 fffffa60`00b92ab6 : 00000000`000000f7 fffffa98`103a4858 00002b99`2ddfa232 ffffd466`d2205dcd : nt+0x5a450
fffffa60`103a3710 fffffa60`00b92b4f : fffff880`00340000 fffffa60`00000030 fffffa80`06127c60 fffffa60`1039d000 : CLASSPNP!_report_gsfailure+0x26
fffffa60`103a3750 fffff800`028a3dcd : 00000000`00000000 fffffa80`03127000 fffffa60`103a5000 fffffa60`00ba91f8 : CLASSPNP!_GSHandlerCheck+0x13
fffffa60`103a3780 00000000`00000000 : fffffa80`03127000 fffffa60`103a5000 fffffa60`00ba91f8 fffffa60`103a3840 : nt+0x85dcd
STACK_COMMAND: kb
CHKIMG_EXTENSION: !chkimg -lo 50 -d !CLASSPNP
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
fffffa6000b9118a-fffffa6000b9118d 4 bytes - CLASSPNP!ClassDeviceControl+6a
[ cd 48 89 6e:06 0f a0 03 ]
4 errors : !CLASSPNP (fffffa6000b9118a-fffffa6000b9118d)
MODULE_NAME: memory_corruption
IMAGE_NAME: memory_corruption
FOLLOWUP_NAME: memory_corruption
MEMORY_CORRUPTOR: LARGE
FAILURE_BUCKET_ID: X64_MEMORY_CORRUPTION_LARGE
