Can a PSU cause heat problems?
I see what your talking about, It's like a plastic glide so you can't mess up. Gonna give this a shot and post back in a bit with results. Thanks for the idea guys.
you got it perfect let us know how it went.
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
Alright, plugging it into the 4 prong got the RPM's at a constant 2290! Thanks for the idea.
However.. I'm still ideling with my cores at 53c+ as if the fan speed didn't make a bit of difference. UGHHH
With the blob method, how much paste exactly did you use? A pea size or a grain of rice size?
For quads, the best method is a thin vertical line applied in the middle and then twisting the heatsink back and forth to evenly spread it.
As you've gathered too much, or too little, will give poor temps.
You haven't adjusted the CPU voltage (vcore) by any chance?
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
well at least we figured out one issue.
now onto the next.
when i replaced mine i just rubbed the paste off my factory heat sink onto the new one and just set it on and wala. i run around 30 - 35 c, never applied any more.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
Then you're bloody lucky ;)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
nope i am bloody good LOL :roflmao:
no really i had just got it delivered and i installed the new fan heat sink before i turned it on. (even though they say they did a burn in on the computer, not sure how when all i ordered was the case, cpu, memory, and mobo)
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
Lmao :) The main thing is that it's working for you, regardless of how :p
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
been building custom computers for myself, family, and friends since 1996.
back in the old days with AMD K6 300mhz cpu's, and IBM CYRIS cpu's. with dos 6.22 and WIN 3.11, also when a BBS was the main thing to have.
remember those days?
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
lol, yeah I do :)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
i actually ran one for 3 years before the internet. i miss those days some times.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
I never changed voltage, didn't know you really could. Heres a link to a picture of speedfan, it lists the voltages and temps. I hope one of you can spot a knot with this. At this point I don't really know what to ask or where to go.
We did the grain of rice size method, then put it on the cpu and took it off and looked. It spread just like we seen it on the few videos we watched.
Imageshack - picsb *edit* Forgot the link lol.
my wife's laptop runs hotter than that.
not sure will look into it.
oops old pic running at 73 at the moment
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
Hello Exidium,
Are these temps idle temps or load temps ?, also what is the ambient temp at your location ?.
One thing i would check is that there is enough pressure being applied to the heatsink, i.e. it's being pushed down hard on to the CPU, in no way should it be loose.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
:roflmao: You brought back happy memories with the mention of the K6
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
