Call of Duty 4 Problem
raptorpbg
I have a new HP Touchscreen with 4 megs of ram, dual core, and windows vista 64. I load call of duty and it loads but will not run and says their is a missing dll file. from direct x. Obviously Windows vista 64 has direct x 10, and COD4 runs from Direct x 9. When I go to install direct x 9 it says that I cannot install due to another application of direct x running. HELP?
    Fumz' Flux-Capacitor
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    500GB W.D. RE2 Primary 1TB W.D. Caviar GP WD10EACS
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
What is the missing dll file called.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
You will have to search on the COD disc for that dll file and put it in the main folder of COD.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
Yes.. there are a few posts about this if you google it...I had it happen as well... I cant really remember what I did to solve it.. but... Make sure you install in an administrator account, make sure you AV is off when you install...install the Patch as well.. ( I think its like 4.16???) I was getting the error even though the DLL was in the main folder....Try right clicking the game icon and running as administrator....I still have to do that with a few games and RIVA tuner.
By the way.. if you have updated DX..it should be backwards compatible so I dont think it should be a problem...install the patch before you play the game... right after installing the game.
    Q9550 2.83 Quad
    8 GB OCZ 800MHz
    Nvidia 9800 GT 1GB
    LG 24
    2 500 GB 32MB Seagate( Raid 0 ) 1 1000 GB 32MB Seagate
    PC P{ower and Cooler 1000W
    HP d5000t ATX CTO
