Call of Duty 2 acting weird
amplid
Vlaming
Power User
These are the three screens I get when I try running Call of Duty 2:
Pleae help, cause I love the game and haven't played it since I got Vista.
Amplid
    Asus ROG Striker 2 Extreme
    2 x 2Gb Patriot DDR3
    XFX GeForce 9800 GTX+
    Creative Supreme FX 2
    Neovo F417 17''
    Samsung SP2504C SATA 7200rpm
    Pc Power & Cooling 750
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
Have you tried it in win XP SP2 compatibility mode?
    system1 (system2)
    q9650 3ghz (i7 920)
    Asus p5q deluxe (p6t deluxe)
    16gb ddr2 (12gb ddr3)
    Nvidia 8800GTS 640mb (285gtx 1gb)
    on board
    Eizo CG301w, Dell 2407
    2560 x 1600 + 1920 x1200
    Raptor 74gb, Raptor 150gb, 500gb x2, 320gb, 750gb (raptor 150gb, 2x 500gb)
    ocz 600w (ocz750w)
    coolermaster stacker (coolermaster 690)
    many fans
    intellimouse
    apple slim aluminum jobbie
    2mb
    Wacom A3 tablet, Epson 3800
What's that?
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
...or maybe try re-installing it in it's own folder outside Program Files (X86)
    system1 (system2)
    q9650 3ghz (i7 920)
    on board
    ocz 600w (ocz750w)
    many fans
    intellimouse
    2mb
if you right click the COD2 icon there should be a compatibility tab. Within this you have the option to select WinXP and disable Vista functions that may create problems with a program.
    system1 (system2)
    q9650 3ghz (i7 920)
    on board
    ocz 600w (ocz750w)
    many fans
    intellimouse
    2mb
Ok, I saw what you mean and changed it, but now it says that I have got the wrong disk inserted...
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
What do you mean by installing it in it's own folder outside program files? (sorry for the many questions...:p)
Thanks so far
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
No worries matey.
The default location for most games is in the Program Files folder. Vista 64 bit uses Program Files (x86) folder to store all 32 bit programs/applications and games. I have noticed that there can be some conflicts when installing older games to Program Files (x86) as vista can limited the read/write access as a security measure to prevent unauthorised changes - on some games I have noticed crashes during level loads etc.....instead of turning off the security ( a big NO NO in my book ) I find it easier to change the installation location when you install the game. You usually have to confirm or change this location during the install - when prompted I'd recommend using something like c:\games\call of duty2
I hope that makes sense.
    system1 (system2)
    q9650 3ghz (i7 920)
    on board
    ocz 600w (ocz750w)
    many fans
    intellimouse
    2mb
No worries matey.
Even when I was still using Windows XP (or Windows ME and Windows 95 before that), whenever I installed a game, I usually changed the install location to "C:\Games\WhateverGame" to make it easier to find save game files and such. It also made it easier to instantly determine how much space is being taken up by games so that it was a breeze to know what to uninstall in the event that I needed to free up some space for something else.
When I moved to Vista x64 over a year ago, this routine of always installing my games to "C:\Games\WhateverGame" has helped tremendously, and in some cases has let the game work without requiring compatibility mode.
When installing a game, don't blindly click Next all the time. Read what the screens say, and when you get to the "Install To" or "Install Location" screen, you should have a button that you can click to browse for an alternate folder to which you want the game installed. Install to any folder you like, as long as it's outside of the "Programs Files (x86)" or "Program Files" folders...
Happy gaming!
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
I have also found when installing games for my kids to use, sometimes turning off the UAC & install , then turn it back on after install helps, also set shortcut to always "run as administrator" sometimes helps too.
Also forgot some games sometimes put incorrect short cut on desktop, try searching for the game start exe in the program folders & try running from there too, I think we had that issue with "crysis" to start with.
After you get Call Of Duty 2 installed on Vista 64, you must install the Call Of Duty 1.3 patch for the game to run on Windows Vista 64.
I discovered this on my own system.
    Core 2 Duo E6600
    Intel 975XBX2
    8GB's of DDR2 800
    Radeon 3870X2
    HT Omega Claro
    Viewsonic VG2030wm Widescreen LCD
    1680X1050
    120GB 200GB 320GB
    ThermalTake Toughpower 700
    Antec P182
    four 120mm fans
    Microsoft Wireless Intellimous Explorer 2.0
    Microsoft Natural Multimedia Keyboard
    10MB
    16X LG DVDROM & LG Dual Layer DVD Burner Logitech X-540 speakers
