C drive to E drive (data)
gefb
I have just got a Toshiba P300-23L laptop with Vista Home Premium 32 bit, the salesma said to put all my docs and pics on E drive but they automatically go to C drive, can I drag and drop the complete folder from C to E and what can I do to make future docs and pics go to E drive?
    Toshiba P300-23L
    4gb
    320gb C E(data)
Hello Gefb, and welcome to Vista Forums.
A lot of programs use your "Documents" user folder, so it is not advised to move it's location to another drive. Instead, you might consider create a folder on the new drive to store them at, then create a shortcut of that folder and place it in your "Documents" user folder or where you like.
