Building your own Rig
Jaffa1978
I've been looking a Cases for desktops,i love some of them,with the led lights and windows they can turn what started out as an ugly black box into something really eyecatching.How difficult is it to take everything out then put back together in a new case? I'm itching to try it,but worried I'd mess it up.Been looking at cases on homepage they look amazing:D
    Own
    AMD FX 8120 Black Edition,3.1GHz oc'd to 4GHz
    Gigabyte GA-990FXA-UD7
    Corsair Vengeance 12GB DDR3 1600Mhz
    EVGA GTX 570 HD SuperClocked
    24" BenQ EW2430 LED Monitor
    1920x1080
    2TB Seagate ST2000DM001 Barracuda 7200,SATA 3 6GB/s. 128GB OCZ Octane, 2.5" SSD.
    850W Powercool PCPC850AUBA
    Xclio Touch 767 Full Tower,With Touch Panel.
    Antec Kúhler H2O 620 Watercooler
    Sharkoon FireGlider Gaming Mouse
    Razer Arctosa Black Edition Gaming Keyboard
    Virgin 30-35Mb/s
    Krator N4-21U26W Neso4 Avante Garde 2.1 Speaker
It's really not all that hard to do, since the procedure is the same as when building from new components.
Just be sure to remember the following:
  1. Some new chassis do not come with a PSU, and you old PSU may not fit into a new chassis, so you'll need to confirm this.
  2. When you remove the components from the old chassis, place each individually into an anti-static bag until such time as you are ready to put them into the new chassis
  3. In most cases, it isn't necessary to remove the CPU and Memory from the motherboard when moving to a new chassis, unless you have a monster fan and heatsink that will get in the way of removing the motherboard from the old chassis. If you really must do this, just remember to clean the underside of the heatsink and the top of the CPU properly before applying new thermal paste when placingthem back into the motherboard.
  4. When placing the motherboard into the new chassis, make sure you have the backplate correctly inserted, and that the chassis base standoffs are all in the correct positions corresponding to the mount holes on the motherboard.
  5. When mounting the motherboard, do not over tighten the screws
  6. Take your time. Murphy's Law states "The more you hurry, the greater the possibility of screwing up".
And most importantly, have fun!
Let us know how it went for you.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
Not hard at all, just a little time consuming. Make sure you read up on a couple PC building guides so that you know the basics of assembling a PC before you attempt this though.
When I swap out cases I like to just keep as many components attached as I can (Processor in Motherboard, heatsink still attached, etc), then I just use tape to label where all the wires go and reassemble in the new case.
    Acropolis
    Intel Core i7-6800k @ 4.0 GHz
    ASUS X99-M WS
    32GB Corsair Vengeance 2x16GB
    ASUS GeForce GTX 1080 STRIX
    ASUS ROG Swift PG278Q
    2x 256GB Samsung 850 Pro (RAID 0) 1x 500GB Samsung 850 Evo 2x Western Digital RED 4TB (RAID 1) 50TB File Server (Multiple RAID 6)
    Corsair AX1200i
    Corsair Air 240
    Logitech G502
    Razer Blackwidow X Chroma
    250Mbps Down | 15 Mbps Up
Hello Jaffa1978.
Maybe this basic how to will shed some light on the question at hand.
Biorobotics Lab
And as Dzomlija stated; have fun.
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
cheers barefoot rep'd u,good article:) its changing the motherboard that worries me,the rest doesnt bother me,sounds like you have to be really careful with the mobo.
there's a computer repair shop just along the road from me,but the guy looks more like mr bean,than bill gates and he'd probably want at least £50 for doing it,plus most of the pc's in his shop look like there from the 1980's.
worried about the grounding yourself bit aswell,I've been electricuted 4 or 5 times in the past lol
    Own
    1920x1080
    Virgin 30-35Mb/s
hmmmm...Thanks for the link to that site!
Im now thinking of its manual to assemble and disassemble that very nice black box. heheheh
Im also particular in PSU, it also looks good..
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
It may seem daunting at first, but if you take your time, you'll be fine:)
It's like most things in life, it gets easier with practice ;)
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
It's actually really easy..
To be careful about shocking yourself, or the PC components. just touch the metal part of the Case Frame everytime before you do anything. before you touch any part touch metal on the case first.. just to be safe.
Raidmax makes some ok cases. I'd look into something like the Antec 300, or threee Hundred. it's one of the cheapest, yet best cases around. Has good fans, and some great airflow for a stock case. I'd get that if I was doing another build. or of course what I have now. the Cooler Master 690 Case.. a very good one. but it's pretty big. if you don't have a big custom system. then something like the Antec Three Hundred is Perfect for you.
    Q9650 E0 4.0 GHz @1.304v
    eVGA 750i FTW
    eVGA/MSI GTX 260 SLI
    X-Fi XtremeGamer
    Samsung T240 & 226BW
    1920x1200 & 1680x1050
    PC P&C 750w Silencer PSU
    Logitech MX-518
    Logitech G11
its easy , just get on with it................ ;) granted ive been building gaming rigs for years but we all started somewhere and you'll wonder why you were ever worried.........now getting it to work afterwards..........thats something else ;)
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
the best thing to do is learn what parts are inside the computer, what not to touch and what to touch and then you should be fine
    Toshiba Satellite Pro l300
    Intel(R) Celeron(R) CPU 550 @ 2.00GHz
    Intel Corp. 88395664Q
    DDR2, PC2-5300 (333 MHz), 1024 MBytes, Hyundai Electronics,DDR2, PC2-5300 (333 MHz), 2048 MBytes, Ap
    Realtek HD Audio
    Matte screen
    1024 x 768 x 4294967296 colors
    120gb SATA 2.5inch FUJITSU MHZ2120BH G1 ATA Device
    Notebook
    Fan cooled
    Logitech Cordless Optical
    Logitech Cordless Desktop EX110
    256Kbps
    I like Spore,Rabbits and I'm a Computer Freak.
Thanks guys,going to do quite a bit of reading up on it.Just 1 more question,Could i change my processor to a better one(eg dual core to a quad core),providing i got a better motherboard that was compatible,and if so would i need to change any other parts
    Own
    1920x1080
    Virgin 30-35Mb/s
You can, But you motherboard can only handle so much.
You have to get the right amount pins and stuff
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
Hello Jaffa1978.
You can do whatever you would like to do. Yes if you change the mobo you may have to upgrade some other components. Just take your time and do your homework. There's no need to get in a hurry doing this.
Is this your machine? Look thru some of these links.
SR5027uk - Google Search
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
