Arrghh! I'm so wound up! I'm constantly getting BSOD whilst trying to set up raid0 in XP 32bit (to start with). Very sorry for the long post. I just wanted to give you guys as much info as possible.
I'll take it from the beginning so you guys have a better understanding of what I'm doing and want to achieve.
Basically I have an 'upgrade to' version of vista64 which requires XP to be installed before it can run. I've had it running perfect whilst using one HDD but this time I want to use Raid0. As you can tell it's not going to well
First off I formatted my second hard drive to have it ready for raid0. I then created a raid driver floppy using the drivers from the motherboard CD. I went into bios and changed the sata config to RAID saved and exited. Pressed Ctrl+I during post to enter Intel Raid manager. I create the raid0 array and exit the manager. Windows XP setup screen pops up to start the XP installation game. I press F6 when prompted. I then press S and tell set up to load ICH8/ICH9 SATA RAID CONTROLLER drivers from the floppy. Set up does it's thing. It then says Windows is starting then bang BSOD every time. If I revert back to one HDD and change back to IDE under sata config XP installs absolutly fine. No problems. As soon as I try setting up raid. . . . .
I've tried all sorts of things. Memtesting, HDD chkdsk, loading AHCI drivers instead of Raid, taking one stick of memory out, updated bios, ect ect.
All I want to do is get XP installed with on raid0. I can then upgrade to vista64 keeping the array i assume??
Any help would be an absolute god send guys. I really am pulling my hair out. I've never been this stressed before in my life!!! I'm begining to wonder if all this raid0 lark is worth it at all.
Thanks, Staith
Thanks, Staith
- Custom Build
- Intel E8600
- Asus Rampage Formula
- 4Gb OCZ ReaperX DDR2
- ATI Radeon 4870x2
- SupremeFXII
- Dell s2409w
- 1920x1080
- Seagate 160gb Seagate 250gb
- PSU
- Corsair X750
- Case
- XCase Dragon
- Cooling
- Stock air upgrading soon to WC
- Logitech LX7
- Saitek Eclipse
- 20gb Down, 1gb up
- Other Info
- I built this rig more for gaming than anything else.
