Bsod problem
My computer will work fine all the way till the log in. As soon as i click to log into my acc it it locks up and blue screens. Also i cant start it in any safe mode. I tried using the boot cd to run a repair came back with nothing. Tried checking all different sticks of the ram in different slots same error. I ran a memory test and came back with nothing.
this is the error message i keep getting.
the last line thats cut off 0x000000000008
Gee nice sceen shot, but need a do over. Follow these instructions and I will help you
http://www.vistax64.com/crashes-debugging/282419-blue-screen-death-bsod-posting-instructions.html
Did you follow these instructions?
If you create a recovery DVD, you may be able to boot to recovery options
Create Recovery DVD
The Vista recovery disk is used to boot Vista when it won't boot - to run Startup Repair, System Restore, access a Command Line, Recover using a Vista Backup Image, etc.
System Recovery Options
If Vista will not start now, boot the Recovery CD to run Startup Repair which automates System Restore as well as numerous other tests including System File Checker which can repair system files which are not corrupted beyond repair.
If Vista still will not start, try booting into Safe Mode to run sfc /scannow to repair System files.
Special Thanks Given to Seven Forums.
Below is a bulletin distributed by MS to explain the start up procedure when Windows will not boot.
  • Startup Repair. Startup Repair is a Windows recovery tool that can fix certain problems, such as missing or damaged system files, that might prevent Windows from starting. Startup Repair is located on the System Recovery Options menu, which is on the Windows Vista installation disc. If your computer has preinstalled recovery options, it might also be stored on your computer's hard disk. For more information, see Startup Repair: frequently asked questions and What are the system recovery options in Windows Vista? If your computer does not include Startup Repair, your computer manufacturer might have customized or replaced the tool. Check the information that came with your computer or go to the manufacturer's website.
  • Change restart settings in safe mode. If your computer is stuck in a loop where Windows fails, attempts to restart, and then fails again repeatedly, restart your computer in safe mode and select the Disable automatic restart on system failure checkbox. For more information, see Advanced startup options (including safe mode).
  • Reinstall. If no other options have solved the problem, and you are sure that your computer's hardware is functioning normally, you might need to reinstall Windows. A custom (clean) installation of Windows will permanently delete all of the files on your computer and reinstall Windows, so only use this option if all other recovery options have been unsuccessful. After the installation, you will need to reinstall your programs and restore your files from backup copies. For more information, see Installing and reinstalling Windows**.
I tried to use the repair from the boot cd came back with no problems, ran numerous system restores that were successful and just went to bsod on log in again.
system info
vista x64 came installed
asus p5n-d
evga gtx275
8gb ddr2
Do what you need to do to get me that report. I will help you.
Its an essential driver that is probably causing the problem. If it does not work in safe mode its an essential driver. I need the report to try to see which one.
Ok how do i get the report if i cant get into windows, sorry just really confused and frustrated with this whole thing, and thanks a lot for taking the time to help me out.
Im going by what you are telling me
Your quote
Get going again.
Once you get going, go to search type device manager. Then in device manger look for yellow warning markers. If you are lucky you will see one. That is the problem. If you do not see anything, get me the report.
Just do this, same as Vista.
Dump files - Upload to Seven Forums - Windows 7 Forums
Im sorry when i meant it was successful it said it was successful but when i log in after the restore it just bsod again. So since ive gotten the message once ive not been able to get into windows at all.
So after SR you still cannot use computer, at all?
Correct it says the sr was good but then upon log in it just bsod. Everything ive tried just results in bsod upon log in even with each different type of safe mode.
OK
Do you know how to restore to factory settings? You will lose your stuff, but we can save the for you if necessary.
