BSOD Problem
kamiasss
About 1 or 2 months ago me and my boyfriend decided to play Special Force Online (philippines) so we downloaded it from the site. When we are about to play the game, it ran slow so we asked some of our friends as to what maybe the reason why. One of them mentioned that we should try on updating my pc's video card as it may have been the cause of the game running slow, and this was when all the BSOD started!! T_T
I would get random BSOD's for about 5 or more times a day! It's so frustrating :( may it be playing, just surfing the net or NOTHING! PLS HELP ME!
Here is my pc's information:
Processor: Intel(R) Pentium(R) Dual CPU E2180 @2.00GHz 2.00GHz
Memory(RAM): 1023 MB
System Type: 32-bit Operating System
My display driver: Radeon X1650 Series
Driver Provider: ATI Technologies Inc.
Driver Date: 3/12/2008
Driver Version: 8.474.0.0
(I know it's not a high-end pc but i USED to love it!:(
Also, I've read here on the internet about System Restore, i tried it but NOTHING happened! oh, and i would also like to mention that i am a newbie at computer stuff, just an average user so pls slow down on some of computer- terms thank you!!
THANK YOU!
I received your message that you were not helped. The reason is that you were impatient and kept posting. It appeared to me that you were getting a lot of answers, so I did not even check your thread. In the future be patient and just wait you will be helped. That being said sorry for the delay.
STOP 0x000000D1: DRIVER_IRQL_NOT_LESS_OR_EQUAL Usual causes: Device driver
Code:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp1_Mini111610-08[1].zip\Mini111510-07.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Vista Kernel Version 6000 MP (2 procs) Free x86 compatible
Built by: 6000.16386.x86fre.vista_rtm.061101-2205
Machine Name:
Kernel base = 0x81800000 PsLoadedModuleList = 0x81908ab0
Debug session time: Tue Nov 16 00:05:19.021 2010 (GMT-5)
System Uptime: 0 days 0:48:48.161
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck D1, {8, 2, 1, 822375b2}
Unable to load image \SystemRoot\system32\DRIVERS\Rtlh86.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for Rtlh86.sys
*** ERROR: Module load completed but symbols could not be loaded for Rtlh86.sys
Unable to load image \SystemRoot\system32\DRIVERS\Epfwndis.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for Epfwndis.sys
*** ERROR: Module load completed but symbols could not be loaded for Epfwndis.sys
*** WARNING: Unable to verify timestamp for epfwtdi.sys
*** ERROR: Module load completed but symbols could not be loaded for epfwtdi.sys
*** WARNING: Unable to verify timestamp for XDva369.sys
*** ERROR: Module load completed but symbols could not be loaded for XDva369.sys
Probably caused by : Rtlh86.sys ( Rtlh86+6175 )
Followup: MachineOwner
1: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high.  This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 00000008, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000001, value 0 = read operation, 1 = write operation
Arg4: 822375b2, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from 819275a0
Unable to read MiSystemVaType memory at 81908680
 00000008
CURRENT_IRQL:  2
FAULTING_IP:
ndis!ndisXlateSendCompleteNetBufferListToPacket+36
822375b2 c7400836434f4d  mov     dword ptr [eax+8],4D4F4336h
CUSTOMER_CRASH_COUNT:  7
DEFAULT_BUCKET_ID:  COMMON_SYSTEM_FAULT
BUGCHECK_STR:  0xD1
PROCESS_NAME:  BandMaster.exe
TRAP_FRAME:  978a1014 -- (.trap 0xffffffff978a1014)
ErrCode = 00000002
eax=00000000 ebx=00000000 ecx=978a10b0 edx=85b7a058 esi=91254a78 edi=00000002
eip=822375b2 esp=978a1088 ebp=978a1090 iopl=0         nv up ei pl zr na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010246
ndis!ndisXlateSendCompleteNetBufferListToPacket+0x36:
822375b2 c7400836434f4d  mov     dword ptr [eax+8],4D4F4336h ds:0023:00000008=????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from 822375b2 to 818494d4
STACK_TEXT:
978a1014 822375b2 badb0d00 85b7a058 00000002 nt!KiTrap0E+0x2ac
978a1090 822da920 91254a78 978a10b0 978a10c0 ndis!ndisXlateSendCompleteNetBufferListToPacket+0x36
978a10b4 822d941e 85b7b008 00000000 00000001 ndis!ndisMSendNetBufferListsCompleteToNdisPackets+0x56
978a10e8 822d95c8 8598b0e8 91254a78 00000001 ndis!ndisMSendCompleteNetBufferListsInternal+0xb8
978a1108 825bd175 8598b0e8 91254a78 00000001 ndis!NdisMSendNetBufferListsComplete+0x70
WARNING: Stack unwind information not available. Following frames may be wrong.
978a113c 825b8bf5 00000000 00000000 00000000 Rtlh86+0x6175
978a1164 825b96e4 02a4a008 00000000 00000000 Rtlh86+0x1bf5
978a1180 822d9521 85a4a008 91254a78 00000000 Rtlh86+0x26e4
978a11a8 8223baa4 8598b0e8 91254a78 00000000 ndis!ndisMSendNBLToMiniport+0xb4
978a11e8 8223b9d0 8598b0e8 008a124c 00000001 ndis!ndisMSendPacketsToNetBufferLists+0x92
978a1224 822da9fd 85b7b008 978a124c 00000001 ndis!ndisSendPacketsWithPause+0x236
978a1240 88d39246 85b7b008 85b7a058 85b79580 ndis!ndisSendWithPause+0x48
978a1264 88d3a193 85b7a058 8597e008 8597e008 Epfwndis+0x3246
978a1280 88d3a1dc 85b79580 8597e008 00000001 Epfwndis+0x4193
978a1294 88d372b1 85b79580 8597e008 859aa0e8 Epfwndis+0x41dc
978a12b0 822dc8eb 00000000 978a12f8 00000001 Epfwndis+0x12b1
978a12d8 822dc732 978a12fc 978a12f8 00000001 ndis!ndisMSendPacketsXToMiniport+0x141
978a1340 82215ae4 859aa0e8 98432928 00000000 ndis!ndisMSendNetBufferListsToPackets+0x84
978a1360 82215b98 98432928 98432928 00000000 ndis!ndisFilterSendNetBufferLists+0x8b
978a1378 88897e20 85edc190 98432928 00000000 ndis!NdisFSendNetBufferLists+0x18
978a13f4 82215b76 85eded60 98432928 00000000 pacer!PcFilterSendNetBufferLists+0x232
978a1410 822d964a 98432928 98432928 00000000 ndis!ndisSendNBLToFilter+0x87
978a1434 889ef453 98495008 98432928 00000000 ndis!NdisSendNetBufferLists+0x4f
978a14cc 889ed935 8a59fb70 00000000 978a1650 tcpip!FlSendPackets+0x4b7
978a150c 889eef6a 88a389c8 00000000 00000000 tcpip!IppFragmentPackets+0x203
978a1544 889ee601 88a389c8 978a1650 88a389c8 tcpip!IppDispatchSendPacketHelper+0x259
978a15dc 889ede01 008a1650 00000000 98432ee8 tcpip!IppPacketizeDatagrams+0x7ea
978a1734 889f02ea 00000000 00000004 88a389c8 tcpip!IppSendDatagramsCommon+0x4ab
978a1754 889d5efa 85ef2150 978a17e0 844cac20 tcpip!IpNlpSendDatagrams+0x4b
978a18f0 8895ac2e 85ef21dc 85ef21e0 844cac20 tcpip!UdpSendMessages+0x9e2
978a1938 88961d2a 8446ebd8 844cac00 912dcbc0 tdx!TdxSendDatagramTransportAddress+0x206
978a1954 81867cc9 85f17810 844cac20 844cac20 tdx!TdxTdiDispatchInternalDeviceControl+0x5c
978a196c 8893dd2a 978a19c4 88939060 85ef69d0 nt!IofCallDriver+0x63
978a1974 88939060 85ef69d0 844cac20 88943e00 epfwtdi+0x7d2a
978a19c4 8893fa3c 85ef69d0 844cac20 88943d00 epfwtdi+0x3060
978a19d8 81867cc9 85ef69d0 844cac20 844cad80 epfwtdi+0x9a3c
978a19f0 888c79de 97029025 00000001 0012f790 nt!IofCallDriver+0x63
978a1a58 888bd3d0 0012f7e6 00000003 888bd3d0 afd!AfdFastDatagramSend+0x5ba
978a1bd8 819cc3d2 843dcc01 00000001 0012f758 afd!AfdFastIoDeviceControl+0x3c1
978a1c80 81a20abe 85e79200 000003b0 00000000 nt!IopXxxControlFile+0x2cf
978a1cb4 9b674ff8 000006a4 000003b0 00000000 nt!NtDeviceIoControlFile+0x2a
978a1d34 818461fa 000006a4 000003b0 00000000 XDva369+0xff8
978a1d34 77ae0f34 000006a4 000003b0 00000000 nt!KiFastCallEntry+0x12a
0012f810 00000000 00000000 00000000 00000000 0x77ae0f34
STACK_COMMAND:  kb
FOLLOWUP_IP:
Rtlh86+6175
825bd175 ??              ???
SYMBOL_STACK_INDEX:  5
SYMBOL_NAME:  Rtlh86+6175
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: Rtlh86
IMAGE_NAME:  Rtlh86.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  45190cfb
FAILURE_BUCKET_ID:  0xD1_Rtlh86+6175
1: kd> lmtsmn
start    end        module name
8047f000 804c2000   acpi     acpi.sys     Thu Nov 02 04:35:03 2006 (4549ADB7)
888a9000 888f0000   afd      afd.sys      Thu Nov 02 04:58:41 2006 (4549B341)
8040d000 80415000   atapi    atapi.sys    Thu Nov 02 04:51:34 2006 (4549B196)
82357000 82375000   ataport  ataport.SYS  Thu Nov 02 04:51:34 2006 (4549B196)
88f35000 89400000   atikmdag atikmdag.sys Wed Mar 12 17:30:59 2008 (47D84B93)
865e1000 865e8000   Beep     Beep.SYS     Thu Nov 02 04:51:03 2006 (4549B177)
80666000 8066e000   BOOTVID  BOOTVID.dll  Thu Nov 02 05:39:29 2006 (4549BCD1)
91d98000 91db1000   bowser   bowser.sys   Thu Nov 02 04:31:11 2006 (4549ACCF)
864bc000 864c6000   BthEnum  BthEnum.sys  Thu Nov 02 04:55:22 2006 (4549B27A)
895fd000 8960b000   bthmodem bthmodem.sys Thu Nov 02 04:55:22 2006 (4549B27A)
8960b000 89625000   bthpan   bthpan.sys   Thu Nov 02 04:55:27 2006 (4549B27F)
89793000 897cd000   bthport  bthport.sys  Thu Nov 02 04:55:21 2006 (4549B279)
897cd000 897d9000   BTHUSB   BTHUSB.sys   Thu Nov 02 04:55:19 2006 (4549B277)
8e410000 8e41e000   cdd      cdd.dll      unavailable (00000000)
9791a000 97930000   cdfs     cdfs.sys     Thu Nov 02 04:30:50 2006 (4549ACBA)
88d41000 88d59000   cdrom    cdrom.sys    Thu Nov 02 04:51:44 2006 (4549B1A0)
8054a000 8062b000   CI       CI.dll       Thu Nov 02 05:42:45 2006 (4549BD95)
8278b000 827ac000   CLASSPNP CLASSPNP.SYS Thu Nov 02 04:51:34 2006 (4549B196)
8062b000 80666000   CLFS     CLFS.SYS     Thu Nov 02 04:30:52 2006 (4549ACBC)
8663e000 8664b000   crashdmp crashdmp.sys Thu Nov 02 04:51:36 2006 (4549B198)
82782000 8278b000   crcdisk  crcdisk.sys  Thu Nov 02 04:52:27 2006 (4549B1CB)
897e9000 89800000   dfsc     dfsc.sys     Thu Nov 02 04:31:04 2006 (4549ACC8)
827ac000 827bd000   disk     disk.sys     Thu Nov 02 04:51:40 2006 (4549B19C)
88b61000 88b86000   drmk     drmk.sys     Thu Nov 02 05:20:49 2006 (4549B871)
866f0000 866f8000   dump_atapi dump_atapi.sys Thu Nov 02 04:51:34 2006 (4549B196)
88a6f000 88a7a000   dump_dumpata dump_dumpata.sys Thu Nov 02 04:51:34 2006 (4549B196)
864b2000 864bc000   Dxapi    Dxapi.sys    Thu Nov 02 04:38:17 2006 (4549AE79)
88e99000 88f35000   dxgkrnl  dxgkrnl.sys  Thu Nov 02 04:38:46 2006 (4549AE96)
906f4000 907c0000   eamon    eamon.sys    Fri Sep 11 01:12:15 2009 (4AA9DC2F)
827bd000 827e2000   ecache   ecache.sys   Thu Nov 02 04:52:42 2006 (4549B1DA)
8f403000 8f420000   ehdrv    ehdrv.sys    Fri Sep 11 01:12:49 2009 (4AA9DC51)
90633000 90656000   epfw     epfw.sys     Fri Sep 11 01:06:57 2009 (4AA9DAF1)
88d36000 88d41000   Epfwndis Epfwndis.sys Thu Apr 09 08:42:36 2009 (49DDED3C)
88936000 88949000   epfwtdi  epfwtdi.sys  Fri Sep 11 01:06:55 2009 (4AA9DAEF)
82316000 82326000   fileinfo fileinfo.sys Thu Nov 02 04:36:47 2006 (4549AE1F)
82326000 82357000   fltmgr   fltmgr.sys   Thu Nov 02 04:30:58 2006 (4549ACC2)
8677f000 86788000   Fs_Rec   Fs_Rec.SYS   unavailable (00000000)
8896c000 88985000   fwpkclnt fwpkclnt.sys Thu Nov 02 04:57:26 2006 (4549B2F6)
81b95000 81bc9000   hal      halmacpi.dll Thu Nov 02 04:30:18 2006 (4549AC9A)
8641f000 86431000   HDAudBus HDAudBus.sys Mon Oct 16 12:29:50 2006 (4533B37E)
88bb3000 88bf2000   HdAudio  HdAudio.sys  Wed Nov 01 21:43:11 2006 (45494D2F)
91e4c000 91eb2000   HTTP     HTTP.sys     Thu Nov 02 04:57:06 2006 (4549B2E2)
88d7e000 88d91000   i8042prt i8042prt.sys Thu Nov 02 04:51:12 2006 (4549B180)
80423000 8042a000   intelide intelide.sys Thu Nov 02 04:51:35 2006 (4549B197)
86598000 865a6000   intelppm intelppm.sys Thu Nov 02 04:30:18 2006 (4549AC9A)
86695000 866a0000   kbdclass kbdclass.sys Thu Nov 02 04:51:09 2006 (4549B17D)
806c6000 806ce000   kdcom    kdcom.dll    Thu Nov 02 05:42:20 2006 (4549BD7C)
88c26000 88c50000   ks       ks.sys       Thu Nov 02 04:51:18 2006 (4549B186)
8203c000 820a6000   ksecdd   ksecdd.sys   Thu Nov 02 04:43:45 2006 (4549AFC1)
824b3000 824c3000   lltdio   lltdio.sys   Thu Nov 02 04:56:48 2006 (4549B2D0)
89512000 8952d000   luafv    luafv.sys    Thu Nov 02 04:33:07 2006 (4549AD43)
80677000 806c6000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Thu Nov 02 05:40:10 2006 (4549BCFA)
896c3000 896d0000   modem    modem.sys    Thu Nov 02 04:58:52 2006 (4549B34C)
88dc7000 88dd6000   monitor  monitor.sys  Thu Nov 02 04:54:05 2006 (4549B22D)
88d73000 88d7e000   mouclass mouclass.sys Thu Nov 02 04:51:09 2006 (4549B17D)
8042a000 8043a000   mountmgr mountmgr.sys Thu Nov 02 04:51:06 2006 (4549B17A)
91d84000 91d98000   mpsdrv   mpsdrv.sys   Thu Nov 02 04:56:32 2006 (4549B2C0)
91d65000 91d84000   mrxdav   mrxdav.sys   Thu Nov 02 04:31:24 2006 (4549ACDC)
91d47000 91d65000   mrxsmb   mrxsmb.sys   Thu Nov 02 04:31:20 2006 (4549ACD8)
91d0e000 91d47000   mrxsmb10 mrxsmb10.sys Thu Nov 02 04:31:25 2006 (4549ACDD)
91cfc000 91d0e000   mrxsmb20 mrxsmb20.sys Thu Nov 02 04:31:16 2006 (4549ACD4)
88c5d000 88c68000   Msfs     Msfs.SYS     unavailable (00000000)
8046e000 80476000   msisadrv msisadrv.sys Thu Nov 02 04:35:08 2006 (4549ADBC)
88d0b000 88d36000   msiscsi  msiscsi.sys  Thu Nov 02 04:52:40 2006 (4549B1D8)
821e7000 82212000   msrpc    msrpc.sys    unavailable (00000000)
864d0000 864da000   mssmbios mssmbios.sys Thu Nov 02 04:35:13 2006 (4549ADC1)
827e2000 827f1000   mup      mup.sys      Thu Nov 02 04:31:04 2006 (4549ACC8)
82212000 82316000   ndis     ndis.sys     Thu Nov 02 04:57:33 2006 (4549B2FD)
88c9e000 88ca9000   ndistapi ndistapi.sys Thu Nov 02 04:58:07 2006 (4549B31F)
88c7b000 88c9e000   ndiswan  ndiswan.sys  Thu Nov 02 04:58:13 2006 (4549B325)
824f3000 82503000   NDProxy  NDProxy.SYS  Thu Nov 02 04:58:08 2006 (4549B320)
88949000 88957000   netbios  netbios.sys  Thu Nov 02 04:57:26 2006 (4549B2F6)
888f0000 88922000   netbt    netbt.sys    Thu Nov 02 04:57:18 2006 (4549B2EE)
821ae000 821e7000   NETIO    NETIO.SYS    Thu Nov 02 04:58:01 2006 (4549B319)
88a56000 88a64000   Npfs     Npfs.SYS     Thu Nov 02 04:30:57 2006 (4549ACC1)
864da000 864e4000   nsiproxy nsiproxy.sys Thu Nov 02 04:57:30 2006 (4549B2FA)
81800000 81b95000   nt       ntkrnlmp.exe Thu Nov 02 04:33:48 2006 (4549AD6C)
820a6000 821ae000   Ntfs     Ntfs.sys     Thu Nov 02 04:31:39 2006 (4549ACEB)
865da000 865e1000   Null     Null.SYS     unavailable (00000000)
88893000 888a9000   pacer    pacer.sys    Thu Nov 02 04:57:33 2006 (4549B2FD)
88d91000 88da9000   parport  parport.sys  Thu Nov 02 04:51:29 2006 (4549B191)
827f1000 82800000   partmgr  partmgr.sys  Thu Nov 02 04:51:47 2006 (4549B1A3)
865be000 865c5000   parvdm   parvdm.sys   unavailable (00000000)
80449000 8046e000   pci      pci.sys      Thu Nov 02 04:35:13 2006 (4549ADC1)
80415000 80423000   PCIIDEX  PCIIDEX.SYS  Thu Nov 02 04:51:34 2006 (4549B196)
97d75000 97e53000   peauth   peauth.sys   Mon Oct 23 04:55:32 2006 (453C8384)
88b86000 88bb3000   portcls  portcls.sys  Thu Nov 02 04:55:02 2006 (4549B266)
8066e000 80677000   PSHED    PSHED.dll    Thu Nov 02 05:42:51 2006 (4549BD9B)
86788000 86791000   rasacd   rasacd.sys   Thu Nov 02 04:58:13 2006 (4549B325)
88ca9000 88cc0000   rasl2tp  rasl2tp.sys  Thu Nov 02 04:58:13 2006 (4549B325)
88da9000 88db8000   raspppoe raspppoe.sys Thu Nov 02 04:58:12 2006 (4549B324)
88c68000 88c7b000   raspptp  raspptp.sys  Thu Nov 02 04:58:14 2006 (4549B326)
88845000 88880000   rdbss    rdbss.sys    Thu Nov 02 04:31:24 2006 (4549ACDC)
866e0000 866e8000   RDPCDD   RDPCDD.sys   Thu Nov 02 05:02:01 2006 (4549B409)
866e8000 866f0000   rdpencdd rdpencdd.sys Thu Nov 02 05:02:01 2006 (4549B409)
89625000 89636000   rfcomm   rfcomm.sys   Thu Nov 02 04:55:22 2006 (4549B27A)
90400000 90413000   rspndr   rspndr.sys   Thu Nov 02 04:56:48 2006 (4549B2D0)
825b7000 825c6000   Rtlh86   Rtlh86.sys   Tue Sep 26 07:20:27 2006 (45190CFB)
8f77e000 8f788000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
864c6000 864d0000   serenum  serenum.sys  Thu Nov 02 04:51:25 2006 (4549B18D)
88d59000 88d73000   serial   serial.sys   Thu Nov 02 04:51:29 2006 (4549B191)
88922000 88936000   smb      smb.sys      Thu Nov 02 04:57:10 2006 (4549B2E6)
80405000 8040d000   spldr    spldr.sys    Wed Oct 25 18:40:44 2006 (453FE7EC)
91f32000 91fc0000   spsys    spsys.sys    Wed Oct 25 18:43:28 2006 (453FE890)
91c4c000 91c98000   srv      srv.sys      Thu Nov 02 04:31:55 2006 (4549ACFB)
91cd8000 91cfc000   srv2     srv2.sys     Thu Nov 02 04:31:46 2006 (4549ACF2)
91df1000 91e0c000   srvnet   srvnet.sys   Thu Nov 02 04:31:43 2006 (4549ACEF)
88ccb000 88d0b000   storport storport.sys Thu Nov 02 04:51:45 2006 (4549B1A1)
86730000 86731380   swenum   swenum.sys   Thu Nov 02 04:51:15 2006 (4549B183)
88985000 88a56000   tcpip    tcpip.sys    Thu Nov 02 04:58:31 2006 (4549B337)
88ac7000 88ad2000   tcpipreg tcpipreg.sys Thu Nov 02 04:57:46 2006 (4549B30A)
88cc0000 88ccb000   TDI      TDI.SYS      Thu Nov 02 04:58:46 2006 (4549B346)
88957000 8896c000   tdx      tdx.sys      Thu Nov 02 04:57:34 2006 (4549B2FE)
88db8000 88dc7000   termdd   termdd.sys   Thu Nov 02 05:02:00 2006 (4549B408)
8e400000 8e409000   TSDDD    TSDDD.dll    unavailable (00000000)
8676d000 86776000   tunmp    tunmp.sys    Thu Nov 02 04:57:23 2006 (4549B2F3)
865a6000 865b1000   tunnel   tunnel.sys   Thu Nov 02 04:57:29 2006 (4549B2F9)
88c50000 88c5d000   umbus    umbus.sys    Thu Nov 02 04:55:24 2006 (4549B27C)
82000000 82001700   USBD     USBD.SYS     Thu Nov 02 04:55:00 2006 (4549B264)
86406000 86414000   usbehci  usbehci.sys  Thu Nov 02 04:55:04 2006 (4549B268)
88bf2000 88c26000   usbhub   usbhub.sys   Thu Nov 02 04:55:20 2006 (4549B278)
86501000 8653e000   USBPORT  USBPORT.SYS  Thu Nov 02 04:55:09 2006 (4549B26D)
86414000 8641f000   usbuhci  usbuhci.sys  Thu Nov 02 04:55:04 2006 (4549B268)
88b55000 88b61000   vga      vga.sys      Thu Nov 02 04:53:56 2006 (4549B224)
88b34000 88b55000   VIDEOPRT VIDEOPRT.SYS Thu Nov 02 04:54:07 2006 (4549B22F)
8043a000 80449000   volmgr   volmgr.sys   Thu Nov 02 04:51:44 2006 (4549B1A0)
82375000 823bf000   volmgrx  volmgrx.sys  Thu Nov 02 04:51:54 2006 (4549B1AA)
82006000 8203c000   volsnap  volsnap.sys  Thu Nov 02 04:52:11 2006 (4549B1BB)
88880000 88893000   wanarp   wanarp.sys   Thu Nov 02 04:58:13 2006 (4549B325)
86431000 8643e000   watchdog watchdog.sys Thu Nov 02 04:37:44 2006 (4549AE58)
804cf000 8054a000   Wdf01000 Wdf01000.sys Thu Nov 02 04:54:18 2006 (4549B23A)
804c2000 804cf000   WDFLDR   WDFLDR.SYS   Thu Nov 02 04:54:05 2006 (4549B22D)
8e600000 8e7ff000   win32k   win32k.sys   Thu Nov 02 04:38:58 2006 (4549AEA2)
80476000 8047f000   WMILIB   WMILIB.SYS   Thu Nov 02 04:54:53 2006 (4549B25D)
9b674000 9b685880   XDva369  XDva369.sys  Tue Oct 05 20:03:32 2010 (4CABBCD4)
Unloaded modules:
86700000 86708000   drmkaud.sys
    Timestamp: unavailable (00000000)
    Checksum:  00000000
8663e000 8664b000   crashdmp.sys
    Checksum:  00000000
8662c000 86637000   dump_ataport
    Checksum:  00000000
86700000 86708000   dump_atapi.s
    Checksum:  00000000
823bf000 82400000   royal.sys
    Checksum:  00000000
Causes update driver
Rtlh86.sys
Rtlh86.sys file description
Productname: Realtek 8101E/8168/8169 PCI/PCIe Adapters
Description: Realtek 8101E/8168/8169 NDIS6 32-bit Driver
Company: Realtek Corporation
Update outdated drivers. I have never seen so many.
Code:
The reports that you have submitted reveal clues to the cause of your problem. They do not give a definitive answer. The more reports that we receive the more clues are made available improving our chances of finding a solution to your problem. You may have to experience several more BSODs until the final answer is discovered.
If overclocking restore normal settings
SFC /scannow
System Files - SFC Command
Scan with your Anti Virus
Update outdated listed drivers. If I have inadvertently listed any Microsoft Drivers, they can be ignored. If the list is extensive I have included the driver verifier test so that you may determine which drivers are in need of immediate attention.
How to Find Drivers
search Google for the name of the driver
- compare the Google results with what's installed on your system to figure out which device/program it belongs to
- visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
- if there are difficulties in locating them, post back with questions and someone - will help you search Google for the name of the driver
- - if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program.
- The most common drivers are listed on this page: http://www.carrona.org/dvrref.html
- - Driver manufacturer links are on this page: http://www.carrona.org/drvrdown.html
To remove any left over driver remnants, especially from graphics cards, use driver sweeper
www.guru3d.com/category/driversweeper/
You can also locate information about your driver using this information
http://www.sevenforums.com/tutorials/96442-device-manager-finding-unknown-devices.html
Sir richc46, thank you for the reply and I'm sorry for being impatient. :( i will do my best on following your instructions. Will update if i have problems in solving this on my own. Again, thank you for your help!
No aplogy necessary, just wanted you to know that if you post several times, it looks like you are being helped and can be missed.
If you have any questions, just post
Hello again. As i have said, i will post again if i am having difficulties. The realtek device that is installed in my system is Realtek RTL8101 Family PCI-E Fast Ethernet NIC (NDIS 6.0)
I understand that i should update this by going to the Realtek website. However, upon searching the site i discovered that there's no available downloaded update driver for this.
So i searched in Google and This site appeared HP® - Laptops, Desktop, Printers, Servers, and more
It's a Hp Site. I was wondering if the offered driver download here is okay? I mean, is it my right choice? Sorry for the inconvenience everyone, just trying to fix my pc.. Thank you!
No inconvenience,
Give me the name and model of your computer. So that I can be sure that we are getting the correct driver.
eg
dell xps420 (thats mine by the way)
It getting late
If no reply tonight look again tomorrow.
If no answer in 15 will talk tomorrwow
Will try to find.
No, the computer name
Oh, i don't know if i understand that clearly, yours was dell right? meaning all of it was made by dell? but this computer was assembled with different brands and models for the parts... So i don't know what should i answer to your question.. >.< It's ok if you can't reply right away, its getting late, but here it is noon. thank you very much!
What is the make of the computer?
Dell
Toshiba
Sony
etc
or was it custom made by you or family?
Download and give me a screen shot of the report
http://www.piriform.com/speccy
Yes it was custom made. There are computer shops here wherein you could have your own pc by them assembling the parts according to your budget. The report will come right away as soon as its finished.
This is giving me a headache. I have a question, will reformatting solve the problem? I honestly can't fix this on my own so i think i should consult this to computer programmers.. I have talked to one and he said he'll reformat it. Will it make any sense? Thank you for all the effort but, I guess i just can't do it alone.. :(
