bsod prob. cause tcpip.sys please help
You have given me in excess of 2 Dozen reports. I spot checked and they were all consistent. A driver was given as the cause. The driver was a lead MS driver and this is rarely the case. Use the driver verifier to detemine the true driver that is the culprit.
Read the precautions and warnings of using the verifier.
Driver Verifier Inst
Since the driver that crashed you has not been listed you should run driver verifier
Please run Verifier with these settings:
Using Driver Verifier is an iffy proposition. Most times it'll crash and it'll tell you what the driver is. But sometimes it'll crash and won't tell you the driver. Other times it'll crash before you can log in to Windows. If you can't get to Safe Mode, then you'll have to resort to offline editing of the registry to disable Driver Verifier.
So, I'd suggest that you first backup your stuff and then make sure you've got access to another computer so you can contact us if problems arise. Then make a System Restore point (so you can restore the system using the Vista/Windows 7 Startup Repair feature).
Then, here's the procedure:
- Go to Start and type in "verifier" (without the quotes) and press Enter
- Select "Create custom settings (for code developers)" and click "Next"
- Select "Select individual settings from a full list" and click "Next"
- Select everything EXCEPT FOR "Low Resource Simulation" and click "Next"
NOTE: You can use Low Resource Simulation if you'd like. From my limited experimentation it makes the BSOD's come faster.
- Select "Select driver names from a list" and click "Next"
Then select all drivers NOT provided by Microsoft and click "Next"
- Select "Finish" on the next page.
Reboot the system and wait for it to crash to the Blue Screen. Continue to use your system normally, and if you know what causes the crash, do that repeatedly. The objective here is to get the system to crash because Driver Verifier is stressing the drivers out. If it doesn't crash for you, then let it run for at least 36 hours of continuous operation (an estimate on my part).
Reboot into Windows (after the crash) and turn off Driver Verifier by going back in and selecting "Delete existing settings" on the first page, then locate and zip up the memory dump file and upload it with your next post.
If you can't get into Windows because it crashes too soon, try it in Safe Mode.
If you can't get into Safe Mode, try using System Restore from your installation DVD to set the system back to the previous restore point that you created.
Enable the driver verifier
www.sevenforums.com/crash-lockup-debug-how/65331-using-driver-verifier-identify-issues-drivers.html
hey thanks a lot richard for getting back to me! but i'm scared to try driver verifier, is there anything else that you can recommend. agian thanks for the help.
    lenovo vista pc
    intel core2 duo cpu [email protected] GHz
    4.0 GB
Well, if my hunch is right and its a driver, this is just a waste of time. But give this a try and lets see
Run a full anti virus scan, update it first
Run a full malwarebytes scan. Donwnload from The malwarebytes site, upate and make full scan
Test your hard drive.
Test Hard Drive www.carrona.org/hddiag.html or this test http://www.tacktech.com/display.cfm?ttid=287
Update Drivers
Code:
 peauth.sys   Mon Oct 23 04:55:32 2006
hardlock.sys Thu Nov 09 06:48:42 2006
PxHelp20.sys Fri Feb 02 16:23:57 2007
e100b325.sys Wed Mar 14 13:29:12 2007
regi.sys     Mon Apr 16 11:19:05 2007
Please remove any CD virtualization programs such as Daemon Tools and Alcohol 120%. They use a driver, found in your dmp, sptd.sys, that is notorious for causing BSODs
http://www.duplexsecure.com/en/downloads
Use this SPTD uninstaller when you're done:
Download memtest86 and test RAM
www.sevenforums.com/tutorials/105647-ram-test-memtest86.html
Run for 8 passes
If passes try a good stick in each slot for 3 passes
If fails do the same for 8 passes.
Memory was mentioned in the report and memory can also cause this problem.
well it's been 3 days since i've had bsod, reading thru other posts gave me an idea to go back and look at any changes i had made. there was one update/patch "hotfix kb981889-v2-x86" so i uninstalled it and have not had any problems since, we'll see.just wanted to thank you for the help so thanks richard.
    lenovo vista pc
    4.0 GB
