Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\FUBAR-RC1-Desktop\TempDUMP\DATA\01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x86 compatible
Built by: 6002.18005.x86fre.lh_sp2rtm.090410-1830
Machine Name:
Kernel base = 0x82a04000 PsLoadedModuleList = 0x82b1bc70
Debug session time: Mon Jul 13 12:18:15.940 2009 (GMT-4)
System Uptime: 0 days 0:19:23.632
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 7F, {d, 0, 0, 0}
Probably caused by : amdk8.sys ( amdk8!C1Idle+5 )
Followup: MachineOwner
1: kd> !thread;!analyze -v;r;kv;lmtn;lmtsmn;.bugcheck;.logclose;q
GetPointerFromAddress: unable to read from 82b3b86c
THREAD 805d11e0 Cid 0000.0000 Teb: 00000000 Win32Thread: 00000000 RUNNING on processor 1
Not impersonating
GetUlongFromAddress: unable to read from 82b13394
Owning Process 82b00900 Image: <Unknown>
Attached Process 84d65910 Image: System
ffdf0000: Unable to get shared data
Wait Start TickCount 73809
Context Switch Count 921660
ReadMemory error: Cannot get nt!KeMaximumIncrement value.
UserTime 00:00:00.000
KernelTime 00:00:00.000
Win32 Start Address nt!KiIdleLoop (0x82aac834)
Stack Init 805e9000 Current 805e8d4c Base 805e9000 Limit 805e6000 Call 0
Priority 0 BasePriority 0 PriorityDecrement 0 IoPriority 0 PagePriority 0
ChildEBP RetAddr Args to Child
805e8c00 87a7759d badb0d00 00000000 805e8c48 nt!KiSystemFatalException+0xf (FPO: [0,0] TrapFrame @ 805e8c00)
WARNING: Frame IP not in any known module. Following frames may be wrong.
805e8c70 85419008 00000000 84d5d7f8 82b07c08 0x87a7759d
805e8c9c 82aacfe3 84d64282 805e8cdc 00000004 0x85419008
805e8ce4 8a951c0b 82ab4d46 87a389d0 805cef90 nt!EtwpCCSwapTrace+0x3b1
805e8ce8 82ab4d46 87a389d0 805cef90 805e8d50 amdk8!C1Idle+0x5 (FPO: [0,0,0])
805e8cf8 82ab4c94 87a8b008 00000000 878042d8 nt!PpmCallIdleHandler+0x2e
805e8d50 82aac841 00000000 0000000e 46633247 nt!PoIdle+0x2d1
805e8d54 00000000 0000000e 46633247 36456234 nt!KiIdleLoop+0xd (FPO: [0,0,0])
UNEXPECTED_KERNEL_MODE_TRAP (7f)
This means a trap occurred in kernel mode, and it's a trap of a kind
that the kernel isn't allowed to have/catch (bound trap) or that
is always instant death (double fault). The first number in the
bugcheck params is the number of the trap (8 = double fault, etc)
Consult an Intel x86 family manual to learn more about what these
traps are. Here is a *portion* of those codes:
If kv shows a taskGate
use .tss on the part before the colon, then kv.
Else if kv shows a trapframe
use .trap on that value
Else
.trap on the appropriate frame will show where the trap was taken
(on x86, this will be the ebp that goes with the procedure KiTrap)
Endif
kb will then show the corrected stack.
Arguments:
Arg1: 0000000d, EXCEPTION_GP_FAULT
Arg2: 00000000
Arg3: 00000000
Arg4: 00000000
Debugging Details:
BUGCHECK_STR: 0x7f_d
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from 87a7759d to 82a5272f
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
amdk8!C1Idle+5
8a951c0b 33c0 xor eax,eax
SYMBOL_STACK_INDEX: 4
SYMBOL_NAME: amdk8!C1Idle+5
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: amdk8
IMAGE_NAME: amdk8.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 47918a38
FAILURE_BUCKET_ID: 0x7f_d_amdk8!C1Idle+5
eax=805cd120 ebx=00000000 ecx=82b04200 edx=00000123 esi=805cd13c edi=00000000
eip=82a5272f esp=805e8be8 ebp=805e8c00 iopl=0 nv up di pl nz na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000006
nt!KiSystemFatalException+0xf:
82a5272f c3 ret
start end module name
8060c000 80613000 kdcom kdcom.dll Sat Apr 11 02:25:29 2009 (49E037D9)
80613000 80624000 PSHED PSHED.dll Sat Apr 11 02:25:32 2009 (49E037DC)
80624000 8062c000 BOOTVID BOOTVID.dll Sat Jan 19 02:27:15 2008 (4791A653)
8062c000 8066d000 CLFS CLFS.SYS Sat Apr 11 00:13:51 2009 (49E018FF)
8066d000 8074d000 CI CI.dll Sat Apr 11 02:25:22 2009 (49E037D2)
8074d000 807c9000 Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
807c9000 807d6000 WDFLDR WDFLDR.SYS Sat Jan 19 00:52:19 2008 (47919013)
80c02000 80c48000 acpi acpi.sys Sat Apr 11 00:19:03 2009 (49E01A37)
80c48000 80c51000 WMILIB WMILIB.SYS Sat Jan 19 00:53:08 2008 (47919044)
80c51000 80c59000 msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
80c59000 80c80000 pci pci.sys Sat Apr 11 00:19:16 2009 (49E01A44)
80c80000 80c8f000 partmgr partmgr.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
80c8f000 80c91900 compbatt compbatt.sys Sat Jan 19 00:32:47 2008 (47918B7F)
80c92000 80c9c000 BATTC BATTC.SYS Sat Jan 19 00:32:45 2008 (47918B7D)
80c9c000 80cab000 volmgr volmgr.sys Sat Jan 19 00:49:51 2008 (47918F7F)
80cab000 80cf5000 volmgrx volmgrx.sys Sat Apr 11 00:39:25 2009 (49E01EFD)
80cf5000 80cfc000 pciide pciide.sys Sat Apr 11 00:39:10 2009 (49E01EEE)
80cfc000 80d0a000 PCIIDEX PCIIDEX.SYS Sat Apr 11 00:39:09 2009 (49E01EED)
80d0a000 80d1a000 mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
80d1a000 80d22000 atapi atapi.sys Sat Apr 11 00:39:09 2009 (49E01EED)
80d22000 80d40000 ataport ataport.SYS Sat Apr 11 00:39:10 2009 (49E01EEE)
80d40000 80d4d000 nvstor nvstor.sys Tue Oct 03 20:25:15 2006 (4522FF6B)
80d4d000 80d8e000 storport storport.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
80d8e000 80dab000 nvstor32 nvstor32.sys Thu Aug 09 14:11:36 2007 (46BB58D8)
80dab000 80ddd000 fltmgr fltmgr.sys Sat Apr 11 00:13:59 2009 (49E01907)
80ddd000 80ded000 fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
80ded000 80df5de0 PxHelp20 PxHelp20.sys Wed Jun 20 18:26:00 2007 (4679A978)
80e0f000 80e80000 ksecdd ksecdd.sys Sat Apr 11 00:30:03 2009 (49E01CCB)
80e80000 80f8b000 ndis ndis.sys Sat Apr 11 00:45:52 2009 (49E02080)
80f8b000 80fb6000 msrpc msrpc.sys Sat Apr 11 00:37:32 2009 (49E01E8C)
80fb6000 80ff1000 NETIO NETIO.SYS Sat Apr 11 00:46:21 2009 (49E0209D)
82a04000 82dbd000 nt ntkrpamp.exe Sat Apr 11 00:16:30 2009 (49E0199E)
82dbd000 82df0000 hal halmacpi.dll Sat Apr 11 00:13:13 2009 (49E018D9)
8a804000 8a8ec000 tcpip tcpip.sys Sat Apr 11 00:46:42 2009 (49E020B2)
8a8ec000 8a907000 fwpkclnt fwpkclnt.sys Sat Apr 11 00:45:42 2009 (49E02076)
8a907000 8a912000 tunnel tunnel.sys Sat Jan 19 00:55:50 2008 (479190E6)
8a939000 8a942000 tunmp tunmp.sys Sat Jan 19 00:55:40 2008 (479190DC)
8a94f000 8a95f000 amdk8 amdk8.sys Sat Jan 19 00:27:20 2008 (47918A38)
8a95f000 8a979000 serial serial.sys Sat Jan 19 00:49:34 2008 (47918F6E)
8a979000 8a983000 serenum serenum.sys Sat Jan 19 00:49:29 2008 (47918F69)
8a983000 8a99b000 parport parport.sys Sat Jan 19 00:49:32 2008 (47918F6C)
8a99b000 8a9ae000 i8042prt i8042prt.sys Sat Jan 19 00:49:17 2008 (47918F5D)
8a9ae000 8a9b9000 kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
8a9b9000 8a9c3000 usbohci usbohci.sys Sat Apr 11 00:42:52 2009 (49E01FCC)
8a9c3000 8a9ff000 rdbss rdbss.sys Sat Apr 11 00:14:26 2009 (49E01922)
8aa08000 8ab18000 Ntfs Ntfs.sys Sat Apr 11 00:14:34 2009 (49E0192A)
8ab18000 8ab51000 volsnap volsnap.sys Sat Apr 11 00:39:37 2009 (49E01F09)
8ab51000 8ab59000 spldr spldr.sys Thu Jun 21 20:29:17 2007 (467B17DD)
8ab59000 8ab68000 mup mup.sys Sat Apr 11 00:14:12 2009 (49E01914)
8ab68000 8ab8f000 ecache ecache.sys Sat Apr 11 00:40:12 2009 (49E01F2C)
8ab8f000 8aba0000 disk disk.sys Sat Apr 11 00:39:14 2009 (49E01EF2)
8aba0000 8abc1000 CLASSPNP CLASSPNP.SYS Sat Apr 11 00:39:05 2009 (49E01EE9)
8abc1000 8abca000 crcdisk crcdisk.sys Thu Nov 02 04:52:27 2006 (4549B1CB)
8e80b000 8e849000 USBPORT USBPORT.SYS Sat Apr 11 00:42:55 2009 (49E01FCF)
8e858000 8e867000 usbehci usbehci.sys Sat Apr 11 00:42:52 2009 (49E01FCC)
8e876000 8e881000 usbuhci usbuhci.sys Sat Jan 19 00:53:20 2008 (47919050)
8e8ae000 8e8fa000 HSXHWBS2 HSXHWBS2.sys Wed Jun 20 14:28:36 2007 (467971D4)
8e8fa000 8e924000 ks ks.sys Sat Apr 11 00:38:47 2009 (49E01ED7)
8e924000 8e9b1000 HDAudBus HDAudBus.sys Sat Apr 11 00:42:41 2009 (49E01FC1)
8e9b1000 8e9c9000 cdrom cdrom.sys Sat Apr 11 00:39:17 2009 (49E01EF5)
8e9c9000 8e9df000 cdfs cdfs.sys Sat Jan 19 00:28:02 2008 (47918A62)
8ea00000 8ea0a000 GEARAspiWDM GEARAspiWDM.sys Thu Mar 19 11:32:37 2009 (49C26595)
8ea0c000 8eb0f000 HSX_DPV HSX_DPV.sys Wed Jun 20 14:29:51 2007 (4679721F)
8eb0f000 8ebc4000 HSX_CNXT HSX_CNXT.sys Wed Jun 20 14:28:20 2007 (467971C4)
8ebc4000 8ebd1000 modem modem.sys Sat Jan 19 00:57:16 2008 (4791913C)
8ebe0000 8ebef300 ohci1394 ohci1394.sys Sat Apr 11 00:43:04 2009 (49E01FD8)
8ebf0000 8ebfd080 1394BUS 1394BUS.SYS Sat Jan 19 00:53:27 2008 (47919057)
8ec07000 8f3685c0 nvlddmkm nvlddmkm.sys Fri Mar 27 14:52:31 2009 (49CD206F)
8f369000 8f36a040 nvBridge nvBridge.kmd Fri Mar 27 14:16:24 2009 (49CD17F8)
8f36b000 8f3a0000 usbhub usbhub.sys Sat Apr 11 00:43:14 2009 (49E01FE2)
8f3a0000 8f3c1000 VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
8f3c1000 8f3d0000 monitor monitor.sys Sat Jan 19 00:52:19 2008 (47919013)
8f3d0000 8f3e1000 NDProxy NDProxy.SYS Sat Jan 19 00:56:28 2008 (4791910C)
8f3e1000 8f3ed000 vga vga.sys Sat Jan 19 00:52:06 2008 (47919006)
8f3ed000 8f3ff000 WUDFPf WUDFPf.sys Sat Jan 19 00:52:49 2008 (47919031)
8f400000 8f401380 swenum swenum.sys Sat Jan 19 00:49:20 2008 (47918F60)
8f402000 8f40c000 mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
8f40f000 8f4ae000 dxgkrnl dxgkrnl.sys Sat Apr 11 00:23:43 2009 (49E01B4F)
8f4ae000 8f4ba000 watchdog watchdog.sys Sat Apr 11 00:22:43 2009 (49E01B13)
8f4ba000 8f506000 yk60x86 yk60x86.sys Thu Dec 06 07:25:16 2007 (4757EA2C)
8f506000 8f50a880 hamachi hamachi.sys Wed Aug 15 19:05:00 2007 (46C3869C)
8f515000 8f544000 msiscsi msiscsi.sys Sat Apr 11 00:40:07 2009 (49E01F27)
8f544000 8f54f000 TDI TDI.SYS Sat Jan 19 00:57:10 2008 (47919136)
8f54f000 8f566000 rasl2tp rasl2tp.sys Sat Jan 19 00:56:33 2008 (47919111)
8f566000 8f573000 umbus umbus.sys Sat Jan 19 00:53:40 2008 (47919064)
8f575000 8f580000 ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
8f580000 8f5a3000 ndiswan ndiswan.sys Sat Apr 11 00:46:31 2009 (49E020A7)
8f5a3000 8f5b7000 raspptp raspptp.sys Sat Jan 19 00:56:34 2008 (47919112)
8f5b7000 8f5c7000 termdd termdd.sys Sat Apr 11 00:51:14 2009 (49E021C2)
8f5d0000 8f5df000 raspppoe raspppoe.sys Sat Apr 11 00:46:30 2009 (49E020A6)
8f5df000 8f5f4000 rassstp rassstp.sys Sat Apr 11 00:46:40 2009 (49E020B0)
8f5f4000 8f5ff000 mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
92404000 92610280 RTKVHDA RTKVHDA.sys Fri Jun 13 05:10:04 2008 (4852396C)
92611000 9263e000 portcls portcls.sys Sat Apr 11 00:42:48 2009 (49E01FC8)
9263e000 92663000 drmk drmk.sys Sat Jan 19 01:53:02 2008 (47919E4E)
92672000 9267b000 Fs_Rec Fs_Rec.SYS Sat Jan 19 00:27:57 2008 (47918A5D)
9267b000 92682000 Null Null.SYS Sat Jan 19 00:49:12 2008 (47918F58)
92682000 92689000 Beep Beep.SYS Sat Jan 19 00:49:10 2008 (47918F56)
92692000 92698380 HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
92699000 926a1000 RDPCDD RDPCDD.sys Sat Jan 19 01:01:08 2008 (47919224)
926a1000 926a9000 rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
926a9000 926b4000 Msfs Msfs.SYS Sat Jan 19 00:28:08 2008 (47918A68)
926b4000 926c2000 Npfs Npfs.SYS Sat Apr 11 00:14:01 2009 (49E01909)
926c2000 926cb000 rasacd rasacd.sys Sat Jan 19 00:56:31 2008 (4791910F)
926cb000 926e1000 tdx tdx.sys Sat Apr 11 00:45:56 2009 (49E02084)
926e1000 926f9e00 avgtdix avgtdix.sys Mon Apr 06 09:42:27 2009 (49DA06C3)
926fa000 9272c000 netbt netbt.sys Sat Apr 11 00:45:35 2009 (49E0206F)
9272c000 92740000 smb smb.sys Sat Apr 11 00:45:22 2009 (49E02062)
92740000 92788000 afd afd.sys Sat Apr 11 00:47:01 2009 (49E020C5)
92788000 92791000 ws2ifsl ws2ifsl.sys Sat Jan 19 00:56:49 2008 (47919121)
92791000 927a7000 pacer pacer.sys Sat Apr 11 00:45:51 2009 (49E0207F)
927a7000 927b5000 netbios netbios.sys Sat Jan 19 00:55:45 2008 (479190E1)
927b5000 927b9720 pstrip pstrip.sys Mon Nov 08 07:02:53 2004 (418F606D)
927ba000 927cd000 wanarp wanarp.sys Sat Jan 19 00:56:31 2008 (4791910F)
927cd000 927d7000 nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
927d7000 927ee000 dfsc dfsc.sys Sat Apr 11 00:14:12 2009 (49E01914)
927ee000 927f3280 avgmfx86 avgmfx86.sys Sat Jun 06 23:38:40 2009 (4A2B3640)
92a05000 92a55580 avgldx86 avgldx86.sys Tue Jun 23 08:46:08 2009 (4A40CE90)
92a56000 92a5f000 hidusb hidusb.sys Sat Apr 11 00:42:48 2009 (49E01FC8)
92a5f000 92a6f000 HIDCLASS HIDCLASS.SYS Sat Apr 11 00:42:47 2009 (49E01FC7)
92a6f000 92a70700 USBD USBD.SYS Sat Jan 19 00:53:17 2008 (4791904D)
92a71000 92a7e000 libusb0 libusb0.sys Tue Mar 20 06:33:27 2007 (45FFB877)
92a7e000 92a86000 mouhid mouhid.sys Sat Jan 19 00:49:16 2008 (47918F5C)
92a86000 92a9b000 USBSTOR USBSTOR.SYS Sat Apr 11 00:42:55 2009 (49E01FCF)
92a9b000 92aa8000 crashdmp crashdmp.sys Sat Apr 11 00:39:12 2009 (49E01EF0)
92aa8000 92ab2000 dump_diskdump dump_diskdump.sys Sat Apr 11 00:39:11 2009 (49E01EEF)
92ab2000 92acf000 dump_nvstor32 dump_nvstor32.sys Thu Aug 09 14:11:36 2007 (46BB58D8)
92acf000 92ad9000 Dxapi Dxapi.sys Sat Jan 19 00:36:12 2008 (47918C4C)
92ad9000 92af4000 luafv luafv.sys Sat Jan 19 00:30:35 2008 (47918AFB)
92afc000 92b02000 vmnetbridge vmnetbridge.sys Thu May 22 06:33:38 2008 (48354C02)
92b02000 92b04f00 VMNET VMNET.SYS Thu May 22 06:33:05 2008 (48354BE1)
92b05000 92b0c000 elagopro elagopro.sys Mon Mar 05 03:54:43 2007 (45EBDAD3)
92b0c000 92b1c000 lltdio lltdio.sys Sat Jan 19 00:55:03 2008 (479190B7)
92b1c000 92b46000 nwifi nwifi.sys Sat Apr 11 00:43:27 2009 (49E01FEF)
92b46000 92b50000 ndisuio ndisuio.sys Sat Jan 19 00:55:40 2008 (479190DC)
92b50000 92b63000 rspndr rspndr.sys Sat Jan 19 00:55:03 2008 (479190B7)
92b63000 92b8a000 srv2 srv2.sys Sat Apr 11 00:15:02 2009 (49E01946)
92b8a000 92bd6000 srv srv.sys Sat Apr 11 00:15:17 2009 (49E01955)
92bd6000 92be0000 hcmon hcmon.sys Sun Oct 12 14:46:10 2008 (48F245F2)
92be0000 92be7000 parvdm parvdm.sys Sat Jan 19 00:49:28 2008 (47918F68)
92be7000 92bf2c80 vmci vmci.sys Sun Oct 12 14:25:32 2008 (48F2411C)
9a2f0000 9a4f2000 win32k win32k.sys unavailable (00000000)
9a510000 9a519000 TSDDD TSDDD.dll unavailable (00000000)
9a530000 9a53e000 cdd cdd.dll unavailable (00000000)
9a540000 9a58c000 ATMFD ATMFD.DLL unavailable (00000000)
9d003000 9d0b3000 spsys spsys.sys Tue Mar 10 13:10:28 2009 (49B69F04)
9d0b3000 9d11e000 HTTP HTTP.sys Sat Apr 11 00:45:29 2009 (49E02069)
9d11e000 9d13b000 srvnet srvnet.sys Sat Apr 11 00:15:01 2009 (49E01945)
9d13b000 9d154000 bowser bowser.sys Sat Jan 19 00:28:26 2008 (47918A7A)
9d154000 9d169000 mpsdrv mpsdrv.sys Sat Jan 19 00:54:45 2008 (479190A5)
9d169000 9d18a000 mrxdav mrxdav.sys Sat Apr 11 00:14:39 2009 (49E0192F)
9d18a000 9d1a9000 mrxsmb mrxsmb.sys Sat Apr 11 00:14:27 2009 (49E01923)
9d1a9000 9d1e2000 mrxsmb10 mrxsmb10.sys Sat Apr 11 00:14:34 2009 (49E0192A)
9d1e2000 9d1fa000 mrxsmb20 mrxsmb20.sys Sat Apr 11 00:14:28 2009 (49E01924)
9d1fa000 9d1fc000 VMparport VMparport.sys Sun Oct 12 14:24:40 2008 (48F240E8)
9e201000 9e2d0b00 vmx86 vmx86.sys Sun Oct 12 16:19:37 2008 (48F25BD9)
9e2d1000 9e2d2500 elaunidr elaunidr.sys Sun Feb 18 13:31:02 2007 (45D89B66)
9e2d3000 9e2d4580 KeyAgent KeyAgent.sys Fri Dec 07 04:12:01 2007 (47590E61)
9e2d5000 9e2d6980 MacHALDriver MacHALDriver.sys Wed Oct 31 19:04:14 2007 (472909EE)
9e2d7000 9e2da180 mdmxsdk mdmxsdk.sys Mon Jun 19 17:26:59 2006 (449716A3)
9e2db000 9e3b9000 peauth peauth.sys Mon Oct 23 04:55:32 2006 (453C8384)
9e3b9000 9e3c3000 secdrv secdrv.SYS Wed Sep 13 09:18:32 2006 (45080528)
9e3c3000 9e3cf000 tcpipreg tcpipreg.sys Sat Apr 11 00:46:06 2009 (49E0208E)
9e3cf000 9e3d3c80 vmnetuserif vmnetuserif.sys Sun Oct 12 15:10:33 2008 (48F24BA9)
9e3d4000 9e3dc000 xaudio xaudio.sys Fri Jun 29 20:11:00 2007 (46859F94)
9e3dc000 9e3f0580 WUDFRd WUDFRd.sys Sat Jan 19 00:53:04 2008 (47919040)
Unloaded modules:
9e3f1000 9e3f9000 drmkaud.sys
Timestamp: unavailable (00000000)
Checksum: 00000000
92af4000 92afc000 drmkaud.sys
Checksum: 00000000
8abca000 8abd7000 crashdmp.sys
Checksum: 00000000
8abd7000 8abe1000 dump_storpor
Checksum: 00000000
8abe1000 8abfe000 dump_nvstor3
Checksum: 00000000
92689000 92692000 kbdhid.sys
Checksum: 00000000
92670000 92672000 usbd.sys
Checksum: 00000000
92663000 92670000 libusb0.sys
Checksum: 00000000
8f5cd000 8f5cf000 usbd.sys
Checksum: 00000000
8f3d4000 8f3e1000 libusb0.sys
Checksum: 00000000
8f5cb000 8f5cd000 usbd.sys
Checksum: 00000000
8f3c7000 8f3d4000 libusb0.sys
Checksum: 00000000
8f5c9000 8f5cb000 usbd.sys
Checksum: 00000000
8f3ba000 8f3c7000 libusb0.sys
Checksum: 00000000
8f5c7000 8f5c9000 usbd.sys
Checksum: 00000000
8f3ad000 8f3ba000 libusb0.sys
Checksum: 00000000
8f573000 8f575000 usbd.sys
Checksum: 00000000
8f3a0000 8f3ad000 libusb0.sys
Checksum: 00000000
Checksum: 00000000
8f566000 8f573000 libusb0.sys
Checksum: 00000000
8f40d000 8f40f000 usbd.sys
Checksum: 00000000
8f400000 8f40d000 libusb0.sys
Checksum: 00000000
8f5c4000 8f5c6000 usbd.sys
Checksum: 00000000
8f5b7000 8f5c4000 libusb0.sys
Checksum: 00000000
8f5ec000 8f5ee000 usbd.sys
Checksum: 00000000
8f5df000 8f5ec000 libusb0.sys
Checksum: 00000000
8f5ce000 8f5d0000 usbd.sys
Checksum: 00000000
8f5c1000 8f5ce000 libusb0.sys
Checksum: 00000000
8f5bf000 8f5c1000 usbd.sys
Checksum: 00000000
8f5b2000 8f5bf000 libusb0.sys
Checksum: 00000000
8f5b0000 8f5b2000 usbd.sys
Checksum: 00000000
8f5a3000 8f5b0000 libusb0.sys
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
8f513000 8f515000 usbd.sys
Checksum: 00000000
8f506000 8f513000 libusb0.sys
Checksum: 00000000
8ebde000 8ebe0000 usbd.sys
Checksum: 00000000
8ebd1000 8ebde000 libusb0.sys
Checksum: 00000000
8e8ac000 8e8ae000 usbd.sys
Checksum: 00000000
8e89f000 8e8ac000 libusb0.sys
Checksum: 00000000
8e89d000 8e89f000 usbd.sys
Checksum: 00000000
8e890000 8e89d000 libusb0.sys
Checksum: 00000000
8e88e000 8e890000 usbd.sys
Checksum: 00000000
8e881000 8e88e000 libusb0.sys
Checksum: 00000000
8e874000 8e876000 usbd.sys
Checksum: 00000000
8e867000 8e874000 libusb0.sys
Checksum: 00000000
8e856000 8e858000 usbd.sys
Checksum: 00000000
8e849000 8e856000 libusb0.sys
Checksum: 00000000
8aa04000 8aa06000 usbd.sys
Checksum: 00000000
8a942000 8a94f000 libusb0.sys
Checksum: 00000000
Unloaded modules:
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Bugcheck code 0000007F
Arguments 0000000d 00000000 00000000 00000000
Closing open log file C:\Users\FUBAR-RC1-Desktop\TempDUMP\DATA\$99-dbug.txt
Opened log file 'C:\Users\FUBAR-RC1-Desktop\TempDUMP\DATA\$99-dbug.txt'
Loading Dump File [C:\Users\FUBAR-RC1-Desktop\TempDUMP\DATA\02.dmp]
Machine Name:
Kernel base = 0x82a52000 PsLoadedModuleList = 0x82b69c70
Debug session time: Tue Jul 14 15:09:54.032 2009 (GMT-4)
System Uptime: 0 days 2:10:10.561
GetPointerFromAddress: unable to read from 82b8986c
Not impersonating
GetUlongFromAddress: unable to read from 82b61394
Owning Process 82b4e900 Image: <Unknown>
Wait Start TickCount 499789
Context Switch Count 12282284
Win32 Start Address nt!KiIdleLoop (0x82afa834)
805e8c00 85b1f59d badb0d00 00000000 805e8c48 nt!KiSystemFatalException+0xf (FPO: [0,0] TrapFrame @ 805e8c00)
805e8c70 805e8cf8 8a94ea9c badb0d00 00000000 0x85b1f59d
805e8ce4 8a94fc0b 82b02d46 87861008 805cef90 0x805e8cf8
805e8ce8 82b02d46 87861008 805cef90 805e8d50 amdk8!C1Idle+0x5 (FPO: [0,0,0])
805e8cf8 82b02c94 8787c090 00000000 8877fae8 nt!PpmCallIdleHandler+0x2e
805e8d50 82afa841 00000000 0000000e ffffffff nt!PoIdle+0x2d1
805e8d54 00000000 0000000e ffffffff ffffffff nt!KiIdleLoop+0xd (FPO: [0,0,0])
Else
Endif
Arguments:
Arg2: 00000000
Arg3: 00000000
Arg4: 00000000
Debugging Details:
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from 85b1f59d to 82aa072f
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
amdk8!C1Idle+5
8a94fc0b 33c0 xor eax,eax
SYMBOL_STACK_INDEX: 3
MODULE_NAME: amdk8
eax=805cd120 ebx=00000000 ecx=82b52200 edx=000000ff esi=805cd13c edi=00000000
eip=82aa072f esp=805e8be8 ebp=805e8c00 iopl=0 nv up di pl nz ac pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000016
82aa072f c3 ret
80604000 8060b000 kdcom kdcom.dll Sat Apr 11 02:25:29 2009 (49E037D9)
8060b000 8061c000 PSHED PSHED.dll Sat Apr 11 02:25:32 2009 (49E037DC)
8061c000 80624000 BOOTVID BOOTVID.dll Sat Jan 19 02:27:15 2008 (4791A653)
80624000 80665000 CLFS CLFS.SYS Sat Apr 11 00:13:51 2009 (49E018FF)
80665000 80745000 CI CI.dll Sat Apr 11 02:25:22 2009 (49E037D2)
80745000 807c1000 Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
807c1000 807ce000 WDFLDR WDFLDR.SYS Sat Jan 19 00:52:19 2008 (47919013)
807ce000 807f5000 srv2 srv2.sys Sat Apr 11 00:15:02 2009 (49E01946)
80c00000 80c08de0 PxHelp20 PxHelp20.sys Wed Jun 20 18:26:00 2007 (4679A978)
80c0d000 80c53000 acpi acpi.sys Sat Apr 11 00:19:03 2009 (49E01A37)
80c53000 80c5c000 WMILIB WMILIB.SYS Sat Jan 19 00:53:08 2008 (47919044)
80c5c000 80c64000 msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
80c64000 80c8b000 pci pci.sys Sat Apr 11 00:19:16 2009 (49E01A44)
80c8b000 80c9a000 partmgr partmgr.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
80c9a000 80c9c900 compbatt compbatt.sys Sat Jan 19 00:32:47 2008 (47918B7F)
80c9d000 80ca7000 BATTC BATTC.SYS Sat Jan 19 00:32:45 2008 (47918B7D)
80ca7000 80cb6000 volmgr volmgr.sys Sat Jan 19 00:49:51 2008 (47918F7F)
80cb6000 80d00000 volmgrx volmgrx.sys Sat Apr 11 00:39:25 2009 (49E01EFD)
80d00000 80d07000 pciide pciide.sys Sat Apr 11 00:39:10 2009 (49E01EEE)
80d07000 80d15000 PCIIDEX PCIIDEX.SYS Sat Apr 11 00:39:09 2009 (49E01EED)
80d15000 80d25000 mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
80d25000 80d2d000 atapi atapi.sys Sat Apr 11 00:39:09 2009 (49E01EED)
80d2d000 80d4b000 ataport ataport.SYS Sat Apr 11 00:39:10 2009 (49E01EEE)
80d4b000 80d58000 nvstor nvstor.sys Tue Oct 03 20:25:15 2006 (4522FF6B)
80d58000 80d99000 storport storport.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
80d99000 80db6000 nvstor32 nvstor32.sys Thu Aug 09 14:11:36 2007 (46BB58D8)
80db6000 80de8000 fltmgr fltmgr.sys Sat Apr 11 00:13:59 2009 (49E01907)
80de8000 80df8000 fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
80e05000 80e76000 ksecdd ksecdd.sys Sat Apr 11 00:30:03 2009 (49E01CCB)
80e76000 80f81000 ndis ndis.sys Sat Apr 11 00:45:52 2009 (49E02080)
80f81000 80fac000 msrpc msrpc.sys Sat Apr 11 00:37:32 2009 (49E01E8C)
80fac000 80fe7000 NETIO NETIO.SYS Sat Apr 11 00:46:21 2009 (49E0209D)
80fe7000 80ff7000 termdd termdd.sys Sat Apr 11 00:51:14 2009 (49E021C2)
82a1f000 82a52000 hal halmacpi.dll Sat Apr 11 00:13:13 2009 (49E018D9)
82a52000 82e0b000 nt ntkrpamp.exe Sat Apr 11 00:16:30 2009 (49E0199E)
8a809000 8a8f1000 tcpip tcpip.sys Sat Apr 11 00:46:42 2009 (49E020B2)
8a8f1000 8a90c000 fwpkclnt fwpkclnt.sys Sat Apr 11 00:45:42 2009 (49E02076)
8a90c000 8a917000 tunnel tunnel.sys Sat Jan 19 00:55:50 2008 (479190E6)
8a917000 8a922000 usbuhci usbuhci.sys Sat Jan 19 00:53:20 2008 (47919050)
8a926000 8a935000 usbehci usbehci.sys Sat Apr 11 00:42:52 2009 (49E01FCC)
8a935000 8a94a000 rassstp rassstp.sys Sat Apr 11 00:46:40 2009 (49E020B0)
8a94d000 8a95d000 amdk8 amdk8.sys Sat Jan 19 00:27:20 2008 (47918A38)
8a95d000 8a977000 serial serial.sys Sat Jan 19 00:49:34 2008 (47918F6E)
8a977000 8a981000 serenum serenum.sys Sat Jan 19 00:49:29 2008 (47918F69)
8a981000 8a999000 parport parport.sys Sat Jan 19 00:49:32 2008 (47918F6C)
8a999000 8a9ac000 i8042prt i8042prt.sys Sat Jan 19 00:49:17 2008 (47918F5D)
8a9ac000 8a9b7000 kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
8a9b7000 8a9c1000 usbohci usbohci.sys Sat Apr 11 00:42:52 2009 (49E01FCC)
8a9c1000 8a9ff000 USBPORT USBPORT.SYS Sat Apr 11 00:42:55 2009 (49E01FCF)
8aa00000 8ab10000 Ntfs Ntfs.sys Sat Apr 11 00:14:34 2009 (49E0192A)
8ab10000 8ab49000 volsnap volsnap.sys Sat Apr 11 00:39:37 2009 (49E01F09)
8ab49000 8ab51000 spldr spldr.sys Thu Jun 21 20:29:17 2007 (467B17DD)
8ab51000 8ab60000 mup mup.sys Sat Apr 11 00:14:12 2009 (49E01914)
8ab60000 8ab87000 ecache ecache.sys Sat Apr 11 00:40:12 2009 (49E01F2C)
8ab87000 8ab98000 disk disk.sys Sat Apr 11 00:39:14 2009 (49E01EF2)
8ab98000 8abb9000 CLASSPNP CLASSPNP.SYS Sat Apr 11 00:39:05 2009 (49E01EE9)
8abb9000 8abc2000 crcdisk crcdisk.sys Thu Nov 02 04:52:27 2006 (4549B1CB)
8abc2000 8abd5000 rspndr rspndr.sys Sat Jan 19 00:55:03 2008 (479190B7)
8abf6000 8abff000 tunmp tunmp.sys Sat Jan 19 00:55:40 2008 (479190DC)
8f40b000 8f457000 HSXHWBS2 HSXHWBS2.sys Wed Jun 20 14:28:36 2007 (467971D4)
8f457000 8f481000 ks ks.sys Sat Apr 11 00:38:47 2009 (49E01ED7)
8f481000 8f584000 HSX_DPV HSX_DPV.sys Wed Jun 20 14:29:51 2007 (4679721F)
8f584000 8f59b000 rasl2tp rasl2tp.sys Sat Jan 19 00:56:33 2008 (47919111)
8f59b000 8f5be000 ndiswan ndiswan.sys Sat Apr 11 00:46:31 2009 (49E020A7)
8f5be000 8f5cb000 umbus umbus.sys Sat Jan 19 00:53:40 2008 (47919064)
8f5cb000 8f5df000 raspptp raspptp.sys Sat Jan 19 00:56:34 2008 (47919112)
8f5e5000 8f5f4000 raspppoe raspppoe.sys Sat Apr 11 00:46:30 2009 (49E020A6)
8f601000 8f6b6000 HSX_CNXT HSX_CNXT.sys Wed Jun 20 14:28:20 2007 (467971C4)
8f6b6000 8f6c3000 modem modem.sys Sat Jan 19 00:57:16 2008 (4791913C)
8f6c3000 8f6ce000 ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
8f6d0000 8f6d1380 swenum swenum.sys Sat Jan 19 00:49:20 2008 (47918F60)
8f6d2000 8f6e1300 ohci1394 ohci1394.sys Sat Apr 11 00:43:04 2009 (49E01FD8)
8f6e2000 8f6ef080 1394BUS 1394BUS.SYS Sat Jan 19 00:53:27 2008 (47919057)
8f6f0000 8f77d000 HDAudBus HDAudBus.sys Sat Apr 11 00:42:41 2009 (49E01FC1)
8f77d000 8f795000 cdrom cdrom.sys Sat Apr 11 00:39:17 2009 (49E01EF5)
8f795000 8f79f000 GEARAspiWDM GEARAspiWDM.sys Thu Mar 19 11:32:37 2009 (49C26595)
8f79f000 8f7eb000 yk60x86 yk60x86.sys Thu Dec 06 07:25:16 2007 (4757EA2C)
8f7eb000 8f7f6000 TDI TDI.SYS Sat Jan 19 00:57:10 2008 (47919136)
8f7f6000 8f800000 mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
8f800000 8f804880 hamachi hamachi.sys Wed Aug 15 19:05:00 2007 (46C3869C)
8f806000 8ff25460 nvlddmkm nvlddmkm.sys Thu Jun 19 13:54:21 2008 (485A9D4D)
8ff26000 8ffc5000 dxgkrnl dxgkrnl.sys Sat Apr 11 00:23:43 2009 (49E01B4F)
8ffc5000 8ffd1000 watchdog watchdog.sys Sat Apr 11 00:22:43 2009 (49E01B13)
8ffd1000 90000000 msiscsi msiscsi.sys Sat Apr 11 00:40:07 2009 (49E01F27)
90009000 9003e000 usbhub usbhub.sys Sat Apr 11 00:43:14 2009 (49E01FE2)
9003e000 9004e000 lltdio lltdio.sys Sat Jan 19 00:55:03 2008 (479190B7)
9004e000 90078000 nwifi nwifi.sys Sat Apr 11 00:43:27 2009 (49E01FEF)
90078000 90082000 ndisuio ndisuio.sys Sat Jan 19 00:55:40 2008 (479190DC)
90089000 90095000 vga vga.sys Sat Jan 19 00:52:06 2008 (47919006)
90095000 900b6000 VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
900b6000 900c5000 monitor monitor.sys Sat Jan 19 00:52:19 2008 (47919013)
900c5000 900d6000 NDProxy NDProxy.SYS Sat Jan 19 00:56:28 2008 (4791910C)
900d6000 900e9000 wanarp wanarp.sys Sat Jan 19 00:56:31 2008 (4791910F)
900e9000 90125000 rdbss rdbss.sys Sat Apr 11 00:14:26 2009 (49E01922)
90125000 9013c000 dfsc dfsc.sys Sat Apr 11 00:14:12 2009 (49E01914)
9013c000 9018c580 avgldx86 avgldx86.sys Tue Jun 23 08:46:08 2009 (4A40CE90)
9018d000 901a2000 USBSTOR USBSTOR.SYS Sat Apr 11 00:42:55 2009 (49E01FCF)
901a2000 901ac000 dump_diskdump dump_diskdump.sys Sat Apr 11 00:39:11 2009 (49E01EEF)
901ac000 901c9000 dump_nvstor32 dump_nvstor32.sys Thu Aug 09 14:11:36 2007 (46BB58D8)
901c9000 901d3000 Dxapi Dxapi.sys Sat Jan 19 00:36:12 2008 (47918C4C)
901d3000 901ee000 luafv luafv.sys Sat Jan 19 00:30:35 2008 (47918AFB)
901ee000 901f5000 elagopro elagopro.sys Mon Mar 05 03:54:43 2007 (45EBDAD3)
93000000 93005280 avgmfx86 avgmfx86.sys Sat Jun 06 23:38:40 2009 (4A2B3640)
93006000 9300c000 vmnetbridge vmnetbridge.sys Thu May 22 06:33:38 2008 (48354C02)
9300c000 93218280 RTKVHDA RTKVHDA.sys Fri Jun 13 05:10:04 2008 (4852396C)
93219000 93246000 portcls portcls.sys Sat Apr 11 00:42:48 2009 (49E01FC8)
93246000 9326b000 drmk drmk.sys Sat Jan 19 01:53:02 2008 (47919E4E)
9326b000 93278000 crashdmp crashdmp.sys Sat Apr 11 00:39:12 2009 (49E01EF0)
9327a000 93283000 Fs_Rec Fs_Rec.SYS Sat Jan 19 00:27:57 2008 (47918A5D)
93283000 9328a000 Null Null.SYS Sat Jan 19 00:49:12 2008 (47918F58)
9328a000 93291000 Beep Beep.SYS Sat Jan 19 00:49:10 2008 (47918F56)
9329a000 932a0380 HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
932a1000 932a9000 RDPCDD RDPCDD.sys Sat Jan 19 01:01:08 2008 (47919224)
932a9000 932b1000 rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
932b1000 932bc000 Msfs Msfs.SYS Sat Jan 19 00:28:08 2008 (47918A68)
932bc000 932ca000 Npfs Npfs.SYS Sat Apr 11 00:14:01 2009 (49E01909)
932ca000 932d3000 rasacd rasacd.sys Sat Jan 19 00:56:31 2008 (4791910F)
932d3000 932e9000 tdx tdx.sys Sat Apr 11 00:45:56 2009 (49E02084)
932e9000 93301e00 avgtdix avgtdix.sys Mon Apr 06 09:42:27 2009 (49DA06C3)
93302000 93334000 netbt netbt.sys Sat Apr 11 00:45:35 2009 (49E0206F)
93334000 93348000 smb smb.sys Sat Apr 11 00:45:22 2009 (49E02062)
93348000 93390000 afd afd.sys Sat Apr 11 00:47:01 2009 (49E020C5)
93390000 93399000 hidusb hidusb.sys Sat Apr 11 00:42:48 2009 (49E01FC8)
93399000 933a9000 HIDCLASS HIDCLASS.SYS Sat Apr 11 00:42:47 2009 (49E01FC7)
933a9000 933aa700 USBD USBD.SYS Sat Jan 19 00:53:17 2008 (4791904D)
933ab000 933b4000 ws2ifsl ws2ifsl.sys Sat Jan 19 00:56:49 2008 (47919121)
933b4000 933c1000 libusb0 libusb0.sys Tue Mar 20 06:33:27 2007 (45FFB877)
933c1000 933d7000 pacer pacer.sys Sat Apr 11 00:45:51 2009 (49E0207F)
933d7000 933df000 mouhid mouhid.sys Sat Jan 19 00:49:16 2008 (47918F5C)
933df000 933ed000 netbios netbios.sys Sat Jan 19 00:55:45 2008 (479190E1)
933ed000 933f1720 pstrip pstrip.sys Mon Nov 08 07:02:53 2004 (418F606D)
933f2000 933fc000 nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
933fc000 933fef00 VMNET VMNET.SYS Thu May 22 06:33:05 2008 (48354BE1)
9aa70000 9ac72000 win32k win32k.sys unavailable (00000000)
9ac90000 9ac99000 TSDDD TSDDD.dll unavailable (00000000)
9acb0000 9acbe000 cdd cdd.dll unavailable (00000000)
9acc0000 9ad0c000 ATMFD ATMFD.DLL unavailable (00000000)
9d608000 9d6b8000 spsys spsys.sys Tue Mar 10 13:10:28 2009 (49B69F04)
9d6b8000 9d723000 HTTP HTTP.sys Sat Apr 11 00:45:29 2009 (49E02069)
9d723000 9d740000 srvnet srvnet.sys Sat Apr 11 00:15:01 2009 (49E01945)
9d740000 9d759000 bowser bowser.sys Sat Jan 19 00:28:26 2008 (47918A7A)
9d759000 9d76e000 mpsdrv mpsdrv.sys Sat Jan 19 00:54:45 2008 (479190A5)
9d76e000 9d78f000 mrxdav mrxdav.sys Sat Apr 11 00:14:39 2009 (49E0192F)
9d78f000 9d7ae000 mrxsmb mrxsmb.sys Sat Apr 11 00:14:27 2009 (49E01923)
9d7ae000 9d7e7000 mrxsmb10 mrxsmb10.sys Sat Apr 11 00:14:34 2009 (49E0192A)
9d7e7000 9d7ff000 mrxsmb20 mrxsmb20.sys Sat Apr 11 00:14:28 2009 (49E01924)
9e206000 9e252000 srv srv.sys Sat Apr 11 00:15:17 2009 (49E01955)
9e252000 9e25c000 hcmon hcmon.sys Sun Oct 12 14:46:10 2008 (48F245F2)
9e25c000 9e263000 parvdm parvdm.sys Sat Jan 19 00:49:28 2008 (47918F68)
9e263000 9e26ec80 vmci vmci.sys Sun Oct 12 14:25:32 2008 (48F2411C)
9e26f000 9e271000 VMparport VMparport.sys Sun Oct 12 14:24:40 2008 (48F240E8)
9e271000 9e340b00 vmx86 vmx86.sys Sun Oct 12 16:19:37 2008 (48F25BD9)
9e341000 9e342500 elaunidr elaunidr.sys Sun Feb 18 13:31:02 2007 (45D89B66)
9e343000 9e344580 KeyAgent KeyAgent.sys Fri Dec 07 04:12:01 2007 (47590E61)
9e345000 9e346980 MacHALDriver MacHALDriver.sys Wed Oct 31 19:04:14 2007 (472909EE)
9e347000 9e34a180 mdmxsdk mdmxsdk.sys Mon Jun 19 17:26:59 2006 (449716A3)
a0e00000 a0ede000 peauth peauth.sys Mon Oct 23 04:55:32 2006 (453C8384)
a0ede000 a0ee8000 secdrv secdrv.SYS Wed Sep 13 09:18:32 2006 (45080528)
a0ee8000 a0ef4000 tcpipreg tcpipreg.sys Sat Apr 11 00:46:06 2009 (49E0208E)
a0ef4000 a0ef8c80 vmnetuserif vmnetuserif.sys Sun Oct 12 15:10:33 2008 (48F24BA9)
a0ef9000 a0f0d580 WUDFRd WUDFRd.sys Sat Jan 19 00:53:04 2008 (47919040)
a0f0e000 a0f20000 WUDFPf WUDFPf.sys Sat Jan 19 00:52:49 2008 (47919031)
a0f20000 a0f28000 xaudio xaudio.sys Fri Jun 29 20:11:00 2007 (46859F94)
a0f28000 a0f3e000 cdfs cdfs.sys Sat Jan 19 00:28:02 2008 (47918A62)
Unloaded modules:
a0f3e000 a0f46000 drmkaud.sys
Checksum: 00000000
93291000 93299000 drmkaud.sys
Checksum: 00000000
8abc2000 8abcf000 crashdmp.sys
Checksum: 00000000
8abcf000 8abd9000 dump_storpor
Checksum: 00000000
8abd9000 8abf6000 dump_nvstor3
Checksum: 00000000
93291000 9329a000 kbdhid.sys
Checksum: 00000000
93278000 9327a000 usbd.sys
Checksum: 00000000
9326b000 93278000 libusb0.sys
Checksum: 00000000
90087000 90089000 usbd.sys
Checksum: 00000000
9007a000 90087000 libusb0.sys
Checksum: 00000000
90078000 9007a000 usbd.sys
Checksum: 00000000
9006b000 90078000 libusb0.sys
Checksum: 00000000
90069000 9006b000 usbd.sys
Checksum: 00000000
9005c000 90069000 libusb0.sys
Checksum: 00000000
9005a000 9005c000 usbd.sys
Checksum: 00000000
9004d000 9005a000 libusb0.sys
Checksum: 00000000
9004b000 9004d000 usbd.sys
Checksum: 00000000
9003e000 9004b000 libusb0.sys
Checksum: 00000000
8f6ce000 8f6d0000 usbd.sys
Checksum: 00000000
8f5be000 8f5cb000 libusb0.sys
Checksum: 00000000
8f800000 8f802000 usbd.sys
Checksum: 00000000
Checksum: 00000000
8f804000 8f806000 usbd.sys
Checksum: 00000000
Checksum: 00000000
8f802000 8f804000 usbd.sys
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
8f5d8000 8f5e5000 libusb0.sys
Checksum: 00000000
Checksum: 00000000
8f5cb000 8f5d8000 libusb0.sys
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
8f6c3000 8f6d0000 libusb0.sys
Checksum: 00000000
8ffde000 8ffe0000 usbd.sys
Checksum: 00000000
8ffd1000 8ffde000 libusb0.sys
Checksum: 00000000
8f6d0000 8f6d2000 usbd.sys
Checksum: 00000000
Checksum: 00000000
8a942000 8a944000 usbd.sys
Checksum: 00000000
8a935000 8a942000 libusb0.sys
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
8a924000 8a926000 usbd.sys
Checksum: 00000000
8a917000 8a924000 libusb0.sys
Checksum: 00000000
8a94b000 8a94d000 usbd.sys
Checksum: 00000000
8a93e000 8a94b000 libusb0.sys
Checksum: 00000000
Unloaded modules:
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
