BSOD neld help
rdc1337
I need to kno wat it means and hopw to fix this??
Stop: 0X00000018(0X83772740, 0XAB49E3E8,0X00000001,0XFFFFFFFC)
wats is it??
thanx for any help
    a6220a
    Intel Pentium E2140
    Intel i945G
    1GB DDR2 pc2-5300 (333HMz)
    Intel 945G Express Chipset
    141GB
    Too SLow need new internet..
    Soon to get 4gb
Hey I will look this up and soon as I get home. Do you have any other info on it?
Have you installed any new hardware or software so on?
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Razer Lachesis
    Razer Tarantula
    not fast enough
    a6220a
    Intel Pentium E2140
    Intel i945G
    141GB
    Soon to get 4gb
Hey dude. Here is what I found out. It seems to be about Win2K (2000) but I think it might apply to vista too. It says there is a hardware incompatiblity on your computer. Installed any new memory, hard drives, motherboard, video cards, or sound cards on your computer recently? Well check this out:
STOP: 0x00000018 (parameter, parameter, parameter, parameter) REFERENCE_BY_
GOOD LUCK:)
    Apple MacBook Pro 13inch
    Intel Core 2 Duo @ 2.26GHz
    2GB DDR3 RAM
    NVIDIA GeForce 9400M @256MB Dedicated DDR3 VRAM
    Intel High Definition Audio
    Laptop: 32 bit Color LCD
    HITACHI HTS545025B9SA02 250GB (Internal) IOMEGA PRESTIGE PORTABLE 500GB (External)
    N/A
    N/A
    N/A
    No-Button Aluminum Trackpad w/ Mouse Gestures
    Black Chiclet-Style Keyboard (Standard US) with Backlight
    T1
Computer Age: Close but not quite.
It is a driver error. This bug check is caused by an inconsistency in the object’s reference count.
Check to make sure that all your drivers are up to date. Have you recently installed a new driver?
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
not very often i cant find the right drivers could someone help me with that i will give u my pc specs.
VIsta home premium 32bit
Manufacturer: Hewlett-Packed Company
Processer: Intel(R) Pentium(R) Dual CPU @ 1.60GHz
Memory: 1GB
my graphics card is a Intel(R) 82945G Express chipset family
some 1 help me pl0x some1 help me get some new drivers.
thnx for all answers
    a6220a
    Intel Pentium E2140
    Intel i945G
    141GB
    Soon to get 4gb
Hi rdc1337
The model number of your HP is required to know the exact hardware inside of it, so can you please post the model number for us. Thanx
    Personal Build
    Intel E6750 Core 2 Duo
    Asus Commando MoBo (P965/ICH8R)
    4G's Crucial Ballistix Tracer DDR2 PC26400 RAM
    BFG 8800GTS OC2 320MB
    Creative Sound Blaster X-FI Platinum FATAL1TY (next)
    2 x 22" w2207 LCD Monitors
    1- 1680 x 1050, 1 - 1920 x 1080
    3 x 500G SATA II WD Caviar HDD's
    EnerMax NoiseTaker II 600W
    NZXT Lexa Classic (modified, dual doored & windowed)
    Zalman 9700 CPU cooler, 4-120mm fans, 1-90mm
    Logitech Optical Trackman trackball
    NZXT Lexa Classic Case, Zalman 9700 CPU Cooler, 2 DVD Burners c/w LightScribe (Sony, TSST), Enermax NoiseTaker II 600W PSU with Custom Chrome cable sleeving, Hauppauge HDTV TV Tuner Card, 5.1 Logitech Z5500 speakers, 15 in 1 Multi-card reader
Model: a6220a
    a6220a
    Intel Pentium E2140
    Intel i945G
    141GB
    Soon to get 4gb
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
could some1 help i dont wanna start a new topic?? but can some1 help me to take this apart so i clean it out.. cos im a afraid that i havent cleanes my pc out and it
could be getting very dirty..
also could this help any of my BSODs?? form my past topics if i update my drivers ??
    a6220a
    Intel Pentium E2140
    Intel i945G
    141GB
    Soon to get 4gb
Take apart your physical computer? Its easy. Go buy a can of compressed air, and get it ready. Depending on your case, you should just be able to unscrew the side plate and pull it off. Then just hold your breath and spray around inside until the dust is cleaned out.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Fan blades are a different story tho, as well as many heatsinks. These need a physical brushing, use a soft bristled paint brush and move slowly thru the heatsink blades so as not to cause a static charge. Fan blades need a brushing and then the air blast will get rid of the dregs for you.
    Personal Build
Last night I got the BSOD however I don't have the stop code as since my last reinstall I didn't turn off the auto restart. When I came back up I got this from windows. I don't know if it will help or not
driver_irql_not_less_or_equal
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Additional information about the problem:
BCCode: d1
BCP1: 000000000000001C
BCP2: 0000000000000002
BCP3: 0000000000000001
BCP4: FFFFFA6001074514
OS Version: 6_0_6001
Service Pack: 1_0
Product: 768_1
Files that help describe the problem:
C:\WINDOWS\Minidump\Mini020909-01.dmp
C:\Users\Clay\AppData\Local\Temp\WER-178184-0.sysdata.xml
C:\Users\Clay\AppData\Local\Temp\WER38DA.tmp.version.txt
    HP Pavillion Elite M9350F
    AMD Phenom X4 9850 Quad
    NVIDIA GeForce 8200 Chipset
    6GB
    NVIDIA GeForce 9800GT graphics card 512MB dedicated
    LG 22"
    Internal: 750GB 7200 160GB 7200 External: WD 500GB
    460W
    Factory
    MX Laser 1000
    Logitech MX3200
    Canon MP500 Printer 3-n-1 Dell 5.1 Sound
Problem signature:
Locale ID: 1033
BCCode: d1
Service Pack: 1_0
Product: 768_1
The BCCode is what we need. The information above helps immensely. (or it would if I was home...)
When I get home, I can give you the exact details of the BCCode.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Thanks I will await your reply! I am running fine now. But would still like to know while I am under warranty with HP
    6GB
    LG 22"
    460W
    Factory
    MX Laser 1000
    Logitech MX3200
Alright. Your error is caused by a driver. Have you installed any new ones recently? Or done ANY updates?
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Only update I have done since my complete reinstall 3 weeks ago is CA Suite 2009. Anti Virus and Firewall. And a Logitech mouse
    6GB
    LG 22"
    460W
    Factory
    MX Laser 1000
    Logitech MX3200
Well I got rid of CA Security Suite 2009 and installed COMODO and everything seems to run smoother and allows access. I was having issues with CuteFTP and now it even works!
    6GB
    LG 22"
    460W
    Factory
    MX Laser 1000
    Logitech MX3200
Cool. Glad that it is fixed.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Me too! Once again thanks
    6GB
    LG 22"
    460W
    Factory
    MX Laser 1000
    Logitech MX3200
