BSOD in win 7 home 64bit
tehnoob23
Hi guys, been experiencing BSOD errors whilst playing BFBC2 and Medal of Honor.
The errors are quite randomly spaced out, and i can go for an entire day without having any BSODs, OR I can keep having them non-stop.
error code seems to be : STOP 0x0000007F
Already updated graphics card drivers and BIOS, but doesn't seem to help.
My pc
Acer aspire m5810
-Win 7 home edition 64bit (OEM)
-4gb ram
-Nvidia GeForce GT230
-intel i5 CPU, 750 @ 2.67GHz (4 CPUs), ~2.7GHz
thanks alot in advance
32 memory dumps from 18 Aug to the present
All are STOP 0x7F's and all are Double Faults
All but one blame ntoskrnl.exe (the other is from 08 Sep 2010 and blames NETIO.sys).
Issues noted in MSINFO32 with Lunaclient.exe and mcshield.exe (McAfee)
ZoneAlarm has had issues with Win7 in the past, keep an eye on it.
I wonder if there was a conflict between McAfee (it has a firewall builtin) and ZoneAlarm. I presume that McAfee was uninstalled (the error was from July).
The double fault in ntoskrnl.exe and the access issues in the stack text tend to suggest a firewall issue.
Please use this free tool to remove any remnants of McAfee: How to uninstall or reinstall supported McAfee consumer products using the McAfee Consumer Products Removal tool (MCPR.exe)
Then, please do the following for ZoneAlarm:
- if you must have 3rd party firewall protection, please download this free 3rd party control for the Windows Firewall: Windows 7 Firewall Control : Sphinx Software
- uninstall ZoneAlarm
- use this free tool to remove the remnants of ZoneAlarm (direct download link): http://download.zonealarm.com/bin/free/support/cpes_clean.exe
- monitor for further BSOD's
If this doesn't fix the BSOD's, please post back and we'll run Driver Verifier according to these directions:
Using Driver Verifier is an iffy proposition. Most times it'll crash and it'll tell you what the driver is. But sometimes it'll crash and won't tell you the driver. Other times it'll crash before you can log in to Windows. If you can't get to Safe Mode, then you'll have to resort to offline editing of the registry to disable Driver Verifier.
So, I'd suggest that you first backup your stuff and then make sure you've got access to another computer so you can contact us if problems arise. Then make a System Restore point (so you can restore the system using the Vista/Win7 Startup Repair feature).
Then, here's the procedure:
- Go to Start and type in "verifier" (without the quotes) and press Enter
- Select "Create custom settings (for code developers)" and click "Next"
- Select "Select individual settings from a full list" and click "Next"
- Select everything EXCEPT FOR "Low Resource Simulation" and click "Next"
NOTE: You can use Low Resource Simulation if you'd like. From my limited experimentation it makes the BSOD's come faster.
- Select "Select driver names from a list" and click "Next"
Then select all drivers NOT provided by Microsoft and click "Next"
- Select "Finish" on the next page.
Reboot the system and wait for it to crash to the Blue Screen. Continue to use your system normally, and if you know what causes the crash, do that repeatedly. The objective here is to get the system to crash because Driver Verifier is stressing the drivers out. If it doesn't crash for you, then let it run for at least 36 hours of continuous operation (an estimate on my part).
Reboot into Windows (after the crash) and turn off Driver Verifier by going back in and selecting "Delete existing settings" on the first page, then locate and zip up the memory dump file and upload it with your next post.
If you can't get into Windows because it crashes too soon, try it in Safe Mode.
If you can't get into Safe Mode, try using System Restore from your installation DVD to set the system back to the previous restore point that you created.
If that doesn't work, post back and we'll have to see about fixing the registry entry off-line:
Code:
Delete these registry keys (works in XP, Vista, Win7):
        HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\VerifyDrivers
        HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\VerifyDriverLevel
More info on this at this link: Using Driver Verifier to identify issues with Windows drivers for advanced users
BSOD BUGCHECK SUMMARY
Code:
[font=lucida console]
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Debug session time: Tue Oct 19 08:08:46.096 2010 (UTC - 4:00)
System Uptime: 0 days 0:05:24.142
Probably caused by : ntkrnlmp.exe ( nt!KiDoubleFaultAbort+b2 )
BUGCHECK_STR:  0x7f_8
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
PROCESS_NAME:  System
Bugcheck code 0000007F
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`0308aec0
Debug session time: Tue Oct 19 08:02:44.648 2010 (UTC - 4:00)
System Uptime: 0 days 0:12:48.069
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`0303bec0
Debug session time: Mon Oct 18 07:56:29.054 2010 (UTC - 4:00)
System Uptime: 0 days 1:44:08.100
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`0309eec0
Debug session time: Sun Oct 17 08:14:02.884 2010 (UTC - 4:00)
System Uptime: 0 days 0:10:30.305
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03081ec0
Debug session time: Sun Oct 17 07:50:39.165 2010 (UTC - 4:00)
System Uptime: 0 days 0:16:55.586
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`0308bec0
Debug session time: Sun Oct 17 07:32:38.816 2010 (UTC - 4:00)
System Uptime: 0 days 2:06:06.086
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03056ec0
Debug session time: Sat Oct 16 08:31:38.090 2010 (UTC - 4:00)
System Uptime: 0 days 1:02:46.511
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03040ec0
Debug session time: Fri Oct 15 12:03:55.208 2010 (UTC - 4:00)
System Uptime: 0 days 10:54:16.628
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03096ec0
Debug session time: Tue Oct 12 11:07:13.584 2010 (UTC - 4:00)
System Uptime: 0 days 2:17:14.630
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03083ec0
Debug session time: Sun Oct 10 10:15:45.487 2010 (UTC - 4:00)
System Uptime: 0 days 1:40:57.534
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03090ec0
Debug session time: Sun Oct 10 08:33:41.798 2010 (UTC - 4:00)
System Uptime: 0 days 0:59:04.219
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03050ec0
Debug session time: Sun Oct 10 07:33:41.675 2010 (UTC - 4:00)
System Uptime: 0 days 8:06:17.096
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03084ec0
Debug session time: Sat Oct  9 01:00:31.411 2010 (UTC - 4:00)
System Uptime: 0 days 1:18:59.457
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03051ec0
Debug session time: Tue Oct  5 08:17:40.371 2010 (UTC - 4:00)
System Uptime: 0 days 0:40:57.791
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03055ec0
Debug session time: Mon Oct  4 07:20:02.412 2010 (UTC - 4:00)
System Uptime: 0 days 0:11:52.832
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03045ec0
Debug session time: Sun Oct  3 08:19:37.023 2010 (UTC - 4:00)
System Uptime: 0 days 1:19:56.070
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03039ec0
Debug session time: Sat Oct  2 13:15:12.700 2010 (UTC - 4:00)
System Uptime: 0 days 0:10:52.746
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03047ec0
Debug session time: Sat Oct  2 13:03:11.630 2010 (UTC - 4:00)
System Uptime: 0 days 0:22:18.590
Debug session time: Mon Sep 27 09:55:18.480 2010 (UTC - 4:00)
System Uptime: 0 days 1:42:10.900
Debug session time: Mon Sep 27 08:12:14.971 2010 (UTC - 4:00)
System Uptime: 0 days 0:35:44.392
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03099ec0
Debug session time: Sun Sep 26 11:39:31.077 2010 (UTC - 4:00)
System Uptime: 0 days 0:05:20.123
Debug session time: Sun Sep 26 11:33:30.900 2010 (UTC - 4:00)
System Uptime: 0 days 0:31:16.320
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03088ec0
Debug session time: Sat Sep 25 04:58:44.989 2010 (UTC - 4:00)
System Uptime: 0 days 0:42:23.035
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`0308eec0
Debug session time: Sat Sep 18 01:34:32.845 2010 (UTC - 4:00)
System Uptime: 0 days 1:11:38.266
Debug session time: Mon Sep 13 00:20:03.988 2010 (UTC - 4:00)
System Uptime: 0 days 3:21:57.034
Debug session time: Wed Sep  8 12:01:06.794 2010 (UTC - 4:00)
System Uptime: 0 days 5:51:42.215
Probably caused by : NETIO.SYS ( NETIO!CompareSecurityContexts+6a )
PROCESS_NAME:  LogonUI.exe
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`0308abd0
Debug session time: Sat Sep  4 03:53:12.811 2010 (UTC - 4:00)
System Uptime: 0 days 6:32:07.231
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03054ec0
Debug session time: Sat Aug 28 10:42:05.444 2010 (UTC - 4:00)
System Uptime: 0 days 13:34:07.864
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03098ec0
Debug session time: Wed Aug 25 04:59:48.279 2010 (UTC - 4:00)
System Uptime: 0 days 1:01:59.700
Debug session time: Sun Aug 22 11:03:40.443 2010 (UTC - 4:00)
System Uptime: 0 days 3:40:13.489
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03041ec0
Debug session time: Sat Aug 21 00:43:02.640 2010 (UTC - 4:00)
System Uptime: 0 days 2:08:27.060
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03043ec0
Debug session time: Wed Aug 18 00:31:31.717 2010 (UTC - 4:00)
System Uptime: 0 days 3:25:13.138
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`03053ec0
  [/font]
