BSOD I REALLY need help.
manomow
Ok. My computer has been crashing very frequently this past week. At first my computer just started to restart by itself. I just shrugged it off at first. Then, one day when it restarted I noticed all of my icons, folders, EVERYTHING was gone. At least until I noticed it was just hidden. I unhid it all, and im figuring I have a virus. Then I started getting BSOD a few times. It went on untill it only happened when my computer logged in. Usually I got lucky and could be on it for the day without it crashing. Today, I can only boot up, and then when I log in, the welcome center screen shows up as usual, then my computer gets the BSOD. Every single time. The only way to get it to work is to go into Safe Mode. Im afraid. I dont know what to do. This computer and everything on it is my life, and we currently cant afford to repair or replace it, and we JUST got it 3 years ago. What do I do? Also, when I run that one program, nothing happens. It just opens for a flash, then closes
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Good going Tom, that is the first step.
Aah, we have an expert :party: You're in excellent hands with Richard, I'll leave the rest to him as multiple users on a BSOD thread often leads to confusion - plus I can't do it!
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Hello and welcome to the forum.
After doing the above I would recommend you do the following.
See if you get go into safe mode and if you have the same problem.
1. Run a full updated virus scan using your anit-virus
2. If you do not have then download and run a full scan using malwarebytes, here is there link free version...
Malwarebytes : Free anti-malware, anti-virus and spyware removal download
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
I did install and use malwarebytes after someone told me to use it. After it ran, I started to delete the corrupted files, then crashed. Tried it several times before it just crasheed my computer. I am currently in safe mode. Thats the only way ive been able to get on the internet. Also, just in case, heres the Windows_NT6_BSOD_jcgriff2 folder.
Welcome
I have looked very quickly at your reports. They seem to point toward memory or drivers. I think its a driver. The driver test being a bit of a pain, lets start with memory after a thorough Virus Test
In this situation I must agree with AmerCritic. Based upon your own opening post, and the facts submitted. It is a very good possiblity that the problems regardless of the cause, originate with a virus.
Make a full anti virus scan
Make a full and updated scan with malwarebytes. If this cannot be done, use this tool, for both Vista and Seven
Microsoft Standalone System Sweeper - Windows 7 Forums
Download memtest86 and test RAM
www.sevenforums.com/tutorials/105647-ram-test-memtest86.html
Run for 8 passes
Ifit passes try a good stick in each slot for 3 passes
Ifit fails do the same for 8 passes.
Ok, ill try. Just so you know, try to use simple words with me. Im 14, and all the technical terms are confusing. I mean, im goo with computers, just not all these "larger" terms.
Now that I think about it, maybe I shouldt be messing around with all of this stuff.
You are a member now among friends, I will keep your age in mind. If you do not understand something or are not sure, just ask. We are all here to help.
That being said, its your computer. If you are uncomfortable or rather not do something, just tell us. You should not have to do anything that makes you nervous.
Perhaps, you have some older friends at school that can help, too.
Here is the simple version of how to do the meomory test
http://www.geekstogo.com/forum/topic/246994-guide-to-using-memtest86/
Hello
I am sorry I must have been typing when everyone else was doing the same, Please listen to RICH as he is a expert on BSOD problems. He will get it figured out for you so listen only to him about your BSOD. Thank you and I wish you much luck...LOL
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
