I was using my computer this morning, when suddenly it froze, so I restarted it and got the bsod. the message said:
A problem has been detected and windows has been shut down to prevent damage to your computer.
If this is the first time you've seen this stop error, restart your computer. If this screen appears again, follow these steps:
Check for viruses on your computer. Remove any newly installed hard drive controllers. Check your hard drive to make sure it is properly configured and terminated. Run CHKDSK?F to check for hard drive corruption, and then restart your computer.
Technical information:
*** STOP: 0x0000007B (ox81E03BA0, 0XC0000034, 0X00000000, 0X00000000)
I have no internet on my PC, i uses it solely for work purposes, and use my laptop for the internet. I have been going through recovery methods for the past few hours to no avail. Every time i enter safe mode, the blue screen stops me from going any further. Can any one please help!
thank you in advance
- Dell
