Bsod help
onegear3619
I need help fixing this issue I have attached a zip file from the SF Diagnostic Tool program. This issue has been going on for some time. I did a system re-load or what ever its called where it put my computer back to factory specs. I then had trouble updating the service packs so Microsoft helped with that. It was good for about a week the BSOD again. HELP
    HP pavilion elite m9177
    intell core2 quad q6700 2.66ghz
    ASUSTek Benicia intell chipset p35/G33/g31
    DDR2 333.2 mhz
    nvida Gforce 8500gt
    not sure
    HP 2408
Welcome
Your description of the problem and the not definitive nature of your reports leads me to believe that we are talking hardware problems
Lets start with the easy one first, memory:
Run for 8 passes.
Run memtest for 8 passes
Then test each individual stick in a good slot for 6 passes.
If you have dual channel, the results may be incorrect, if shows pass.
Guide to using Memtest86+ - Geeks to Go Forums
