BSOD and installation help
Unknowlegable
As you can tell by my name, I know very little when it comes to this stuff. I must hav gotten a virus because I got BSOD as soon as I logged in, and then the computer would restart itself. I got m OS cd, ran the diagnostics and repair of options (could not be automatically repaired) and set the computer to boot through cd only. When I try to install a clean copy (I formatted my c drive too) it gives an installation error (0x80070017) and says files are corrupt or missing. I really need this problem solved, on a Dell laptop, vista home basic
thank you!
Does this dell laptop have a graphics card? Nvidia or ATi?
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
From what I've read, your going to need to disable that video card in the bios until you can get vista installed. Unfortunately, I can't see the screen and wouldn't know how to walk you through it as some BIOS are different then others. Sorry :(
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
Yes, I've read a few posts where someone was stopped by vista with the same error you gave me, disabled there video card in the BIOS, and everything installed perfect afterwards.
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
