Broadband problem
ADR
Hello All
Recently my Internet has been going off for it seems no reason, i have a Bt Hub, every now and then internet goes off and sign comes on the screen say your Hub is not connected to the Internet, it then a says a cable in not connected, when i check the cables they are all ok , then a couple of minutes later everyting is back to normal, also sometimes my msn dosent work and it say it is unavailable at the moment,
could it be this is BT messing around with there servers?
Thanks
Allan
Welcome Allan
Of course it could be the servers, but it could be a host of other things.
Can you connect your computer via cable to see if the problem continues?
Can you tell if all computers in your home have the same problem at the same time?
Can you ask a friend using the same servers if he too has a problem?
Did you call the company?
Finally go to search and type event viewer
In event viewer look for errors that may explain your problem
I wish you luck
Thanks Richard
yes my daughter was using her laptop and the same thing happened when i was on the Internet on my Computer.
Thanks
Allan
Allan
If you and your daughter had the same problem at the same time the cause has to be the hub or the ISP.
Does not sound like a Vista software problem.
You are very welcome
Hello All
Thanks
Allan
Hi Allan, Welcome to the forum. Sorry about your troubles.
After completing the excellent suggestions by Richc, if you are still having problems may I suggest that you download the BT Broadband Desktop Help program from:-
BT Broadband Desktop Help | Help | BT.com Help
It is a good source of problem solving and information. They also have a 24hr. free helpline if your'e really stuck. Which BT Hub do you have?
I use BT myself for all my computers,I use the new Hub 3, and on occasions there are interruptions to service through upgrade work which is being carried out in many places at the moment. The best way to check is online for any work in your area.
Hope this information may be of use to you.
Thank you.
Too slow typing again!
    Hewlett-Packard SR5019UK
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    Realtec ALC888 Audio
    17" LCD Monitor
    160 Gb Usable Hard Drive
Thanks for your help, i got my hub 2 years ago, it i thing a Bt hub 4.0, i am not at home so i cant be sure, i shall look at the helpline and see what i can glean from that.
Regards
Allan
Regards
Allan
Hi Allen,
The Broadband desktop help. I will be surprised if it is not already downloaded onto your computer?
Do also follow Rich's suggestions.
Thank you.
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
