Hello all,
I will try my best to be concise and provide the necessary information. I own the Fujitsu T5010 Tablet PC. It did not manage to safely shutdown yesterday and I find myself unable to boot up the computer like usual. It will reach the screen with "Microsoft Corporation" below a loading bar, and will prompt a restart after a few mins wait, sometimes with a BSOD that flashes for a split second before the laptop restarts.
I then proceed to the StartUp recovery and attempt to repair the problem. However, a cmd window will open with error messages such as
So I google around and there were suggestions to disable ACHI in BIOS. I tried it, the booting problem persists, but this time I am able to StartUp repair. I run the repair process a few times, some of which indiates that the problem could not be fixed and display the message in the report "A recent driver installation or upgrade may be preventing the system from starting", whereas for a few instances, StartUp repair concluded successfully but the computer is still unable to boot.
In conclusion, the booting problem persists irregardless of the ACHI option (but harddisk will only be recognized if ACHI is disabled, and I think ACHI is enabled all along even when before this problem came up since I used the default settings), and I believes that the failure to boot was due to a one-time unexpected shutdown and I did not change any hardware stuff.
I will appreciate any help. Thank you in advance! (:
- "Unable to restore the data because the hard disk can not be recognized. Please contact Fujitsu Computer Systems Corporation or your dealer"
- "The recovery and the utility disc can not be started because of the unexpected error in the hard disk. Please try again to restart the Recovery and Utility disc. If you see the same error again, there is a possibility that tour hard disk might be corrupt."
- Drive0 [Hitachi HTS54323...]
- Drive1 [MAT****ADVD-RAM UK8...]
