Bootdiskmgr problem
kuthedude
Hi, I have a problem. My new computer just came in, and I installed Vistax64 on my raided raptors and windows can not boot without the install cd in the drive, it will just say bootdiskmgr not found ctrl+alt+del restart. I check the diagnostics, and it said there was nothing to repair. What should I do? Thanks!
I would guess that it is trying to boot to an optical drive or flash drive that is set as priority before the main hard drive. Make sure you do not have a bootable disc in those if you have them or go into cmos and make sure the main hard drive is set as the first boot. It will be under boot priority in the bios.
    i7 940 @ 4GHz (193 x 21) w/CNPS9900LED
    Asus P6T Deluxe (BIOS 1604)
    6GB (3x2GB) Corsair DDR3-1600 @ 8-8-8-21-1N
    Tri-Fire 4870x2 + 4870 1GB
    Azun Prelude 7.1 + Inspire T6200 5.1
    Dell 3008WFP
    2560 x 1600
    300GB WD VelicoRaptor
    SilverStone DA 1200
    CM HAF 932
    3x230mm 1x140mm 1x120mm
    MX Revolution
    G15 Gaming KB
