Bob
Vvillebob
Have Vista Home Edition. When playing Spider Solitare, dragging the cards happen very slowly. I'm sure I see slowness in other things also, but it is real evident playing cards. I've tried everything I can think of to solve the problem (used registry cleaning programs, run available diagnostics, etc). Anybody have any thoughts?
    Dell
    Intel(R) Core(TM) Duo CPU E6550 @ 2.33GHz
    2.00 GB
    NVIDIA GeForce 8300 GS
    288 GB Total 192 GB Free
    Dell Optical
    Dell (Standard)
    Cable Connection
First, never use registry cleaners. They do more harm than good.
That being said its probably not enough memory. How much memory do you have.
If you do have sufficient memory, I would take a memory test.
If you pass the test. I would make a complete anti virus scan
and
Download and make a full scan with malwarebytes.
http://www.geekstogo.com/forum/topic/246994-guide-to-using-memtest86/
Not sure if this is on track with the problem but what are your computer specs? My computer would do the same with my Graphics card, if the driver crashed and was forced to use the Standard VGA Driver unless restarted. otherwise... do what richard said.
hope i helped in some way
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Mouse
    Logitech K120 Wired Keyboard
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6 Thomson A/B/G/N Router LiteON CD/DVD Player GAME PERFORMANCE: Battlefield 3: 41 FPS High 1x AA @ 1280x720 Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080 Counter Strike Source (and other Valve games): 300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
Thanks for the replies (amazing you found me, since I didn't even know how to post a problem!)
Rich:
I have 2.0 GB Memory
Available Physical Memory is 927 MB
Total Virtual memory is 4.93 GB
Available Virtual Memory is 3.30 GB
I did run a full scan with the malwarebytes program, and it indicated no problems.
I use Norton Internet Security, and do frequent Quick Scans and a weekly Full Scan.
I was unable to get to the memory test. The download only produced an image with no program.
nostaw5:
What kind of computer specs are you looking for?
    Dell
    2.00 GB
    Dell Optical
    Dell (Standard)
    Cable Connection
Right click on computer, select properties, and then click on windows experience index. You'll then see a bunch of numbers--please tell us what they are.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
[/QUOTE]
nostaw5:
What kind of computer specs are you looking for?[/QUOTE]
CPU, Graphics card i know your ram. Also look in Device manager to see what the Display Adapter reports.
Start-control panel- system- (on you left) device manager- display adapter and report what it says (eg. Ati Radeon HD 6450 OR Standard VGA driver.
Thanks
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
Rich:
Every time I download Download - Pre-Compiled Bootable ISO (.zip) , all I end up getting is an image file. No program seems to be attached.
townsbg:
Processor - Intel Core 2 Duo CPU E6550 @ 2.33 GHz - Subscore 5.3
Memory - 2.00 GB - Subscore 5.9
Graphics - NVIDIA GeForce 8300 GS - Subscore 3.4
Gaming Graphics - 895 MB Total available graphics memory - Subscore 4.5
Primary hard disk - 192GB Free (288GB Total) - Subscore 5.6
Base Score - 3.4
Note - This base score has been the same all along, before I started experiencing the slow down.
nostaw5:
CPU - Intel Core 2 Duo CPU E6550 @ 2.33 GHz
The Display adapter - NVIDIA GeForce 8300 GS
Total available graphics memory - 895 MB
Dedicated graphics memory - 128 MB
Dedicated system memory - 0 MB
Shared system memory - 767 MB
Thanks again guys, for trying to help me.
    Dell
    2.00 GB
    Dell Optical
    Dell (Standard)
    Cable Connection
