bluetooth problem
azraq
whenever i switch on my bluetooth..it does not appear on the tray/taskbar anymore..i have to search it on the start menu for bluetooth options..
how to make the bluetooth appear on the tray like before..i might accidentally have done something i do not know that led to this..
help anyone?
    ACER TravelMate 6291
    Intel Core 2 Duo processor T5500
    4 GB DDR2
    Intel Graphics Media Accelerator 950
    160 GB HDD
This may not be your answer but I'll give it a shot. If this fails, you can always try Uninstalling/Installing and hope that you get it working again.
Click on the Windows Orb, type MSCONFIG, the System Configuration Utility will open up (at least, that's what is called in XP. Sorry, I am not at home right now ;)).
Click on the Selective Startup Option, then, click on the Service Tab, tick Hide all Microsoft Services and check to see if Any Bluetooh services pop up there, if so... select them (tick).
Now, click on the Startup tab and look for any bluetooh entries here as well and select them.
Restart and hope for the best. Let us know if that works for you.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
i tried your suggestion..didn't work..
but i went to the bluetooth setting and options..and there it is..i just ticked 'show bluetooth in the notification area'..
damn i was stupid..:confused:
    4 GB DDR2
    160 GB HDD
