I am new to these Forums especially with regard to bluescreening on my Acer Laptop running Vista....
I am experiencing alot of problems with my ACER ASPIRE laptop 5112WLMi AMD Turion 64 160gb 5400 rpm SATA HDD DDR2
I am running VISTA
It has been bluescreening for some time and then it works well and bluescreens again. There is also a flickering of the screen with horizontal lines through it when it boots up.This subsides after awhile.The machine seems to be running ok but it will be just a question of time when it crashes again.It is very unpredictable. Two days ago it did it twice.
Here is Problem event description;
First time>>>> OS version 6.0 6000.2.0.0768.3
Locale ID; 4105
Files: Mini 06 1910-01.dmp
sysdata.xml
version. txt
BCCODE: a
BCP1: 00020005
BCP2: 000000 1B
BCP3: 000000 1
BCP4: 81 CBB165
OS Version 6_0_6000
Service Pack 0_0
Product 768_1
Server Info: e8185a50-25f5-48c4-a30e-f58b7564d8b4
Second time: Problem event:Blue screening
OS Version; 6.0 6000.2.0.0768.3
Locale ID;4105
BCCODE f4
BCP1: 00000003
BCP2: 85FDA800
BCP3: 85FDA94C
BCP4: 81EAA730
OS Version 6_0_6000
Service Pack 0_0
Product 768_1
Files that help describe the Problem;
1) C:\Windows\MiniDump\Mini 06190-02.dmp
2) C:\USERS\ACER\APPData\Local\Temp\WER 85171-O.Sysdata.xml
3) C:\USERS\ACER\APPData\Local\Temp\WER B929.tmp.version.txt
So these are problem event descriptions.I was also trying to backup files on this ACER to my external HD,when all this occurred but this problem was also occuring way before i even bought an external HD.
I also get the IRQL less or equal error message sometimes as well
Can you suggest or tell me what the heck is going on and what the problem is with this machine?
I am enclosing the results after running the Blue Screen test.Dont ask me what it means
I am going crazy as to why the Acer keeps bluescreening.Is it my drivers are corrupted? Is it my hard drive? Someone,anyone,help![Smile :) :)](/images/smilies/001.png)
bigalsterCrash ListCrash List
Created by using BlueScreenView
Dump File Crash Time Bug Check String Bug Check Code Parameter 1 Parameter 2 Parameter 3 Parameter 4 Caused By Driver Caused By Address File Description Product Name Company File Version Processor Computer Name Full Path Processors Count Major Version Minor Version Mini062010-01.dmp 20/06/2010 11:16:54 AM CRITICAL_OBJECT_TERMINATION 0x000000f4 0x00000003 0x87859568 0x878596b4 0x81eaa730 ntkrnlpa.exe ntkrnlpa.exe+d8781 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.0.6000.17021 (vista_gdr.100218-0019) 32-bit C:\Windows\Minidump\Mini062010-01.dmp 2 15 6000 Mini061910-03.dmp 19/06/2010 2:24:21 PM NTFS_FILE_SYSTEM 0x00000024 0x001904ab 0x9b1dba50 0x9b1db74c 0x81b4b797 Ntfs.sys Ntfs.sys+8c797 NT File System Driver Microsoft® Windows® Operating System Microsoft Corporation 6.0.6000.16386 (vista_rtm.061101-2205) 32-bit C:\Windows\Minidump\Mini061910-03.dmp 2 15 6000 Mini061910-02.dmp 19/06/2010 1:50:35 PM CRITICAL_OBJECT_TERMINATION 0x000000f4 0x00000003 0x85fda800 0x85fda94c 0x81eaa730 ntkrnlpa.exe ntkrnlpa.exe+d8781 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.0.6000.17021 (vista_gdr.100218-0019) 32-bit C:\Windows\Minidump\Mini061910-02.dmp 2 15 6000 Mini061910-01.dmp 19/06/2010 1:33:57 PM IRQL_NOT_LESS_OR_EQUAL 0x0000000a 0x00020005 0x0000001b 0x00000001 0x81cbb165 Ntfs.sys Ntfs.sys+185ac NT File System Driver Microsoft® Windows® Operating System Microsoft Corporation 6.0.6000.16386 (vista_rtm.061101-2205) 32-bit C:\Windows\Minidump\Mini061910-01.dmp 2 15 6000 Mini061310-01.dmp 13/06/2010 12:44:04 AM MEMORY_MANAGEMENT 0x0000001a 0x00005010 0xc0801000 0x00038dfb 0x0715e100 ntkrnlpa.exe ntkrnlpa.exe+2b7d2 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.0.6000.17021 (vista_gdr.100218-0019) 32-bit C:\Windows\Minidump\Mini061310-01.dmp 2 15 6000 Mini061010-01.dmp 10/06/2010 12:36:50 AM MEMORY_MANAGEMENT 0x0000001a 0x00041284 0x1291f001 0x0000fcbf 0xc0801000 ntkrnlpa.exe ntkrnlpa.exe+d8781 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.0.6000.17021 (vista_gdr.100218-0019) 32-bit C:\Windows\Minidump\Mini061010-01.dmp 2 15 6000 Mini053010-01.dmp 30/05/2010 11:19:12 AM MEMORY_MANAGEMENT 0x0000001a 0x00041289 0x35c05001 0x00043b10 0x3e719121 ntkrnlpa.exe ntkrnlpa.exe+d8781 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.0.6000.17021 (vista_gdr.100218-0019) 32-bit C:\Windows\Minidump\Mini053010-01.dmp 2 15 6000 Mini052510-01.dmp 25/05/2010 10:31:04 PM IRQL_NOT_LESS_OR_EQUAL 0x0000000a 0x90dd851b 0x00000000 0x00000000 0x81cb6b2d ntkrnlpa.exe ntkrnlpa.exe+8fe14 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.0.6000.17021 (vista_gdr.100218-0019) 32-bit C:\Windows\Minidump\Mini052510-01.dmp 2 15 6000 Mini041510-01.dmp 15/04/2010 12:21:37 AM IRQL_NOT_LESS_OR_EQUAL 0x0000000a 0x0000006c 0x0000001b 0x00000001 0x818b3809 ntkrnlpa.exe ntkrnlpa.exe+8fe14 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.0.6000.17021 (vista_gdr.100218-0019) 32-bit C:\Windows\Minidump\Mini041510-01.dmp 2 15 6000 Mini041110-01.dmp 11/04/2010 7:58:17 AM MEMORY_MANAGEMENT 0x0000001a 0x00000030 0x85f4ea50 0x93d65000 0x9af29060 ntkrnlpa.exe ntkrnlpa.exe+d8781 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.0.6000.17021 (vista_gdr.100218-0019) 32-bit C:\Windows\Minidump\Mini041110-01.dmp 2 15 6000 Mini040910-01.dmp 09/04/2010 10:27:04 PM MEMORY_MANAGEMENT 0x0000001a 0x00041289 0x25401001 0x0001db42 0x1db411d6 ntkrnlpa.exe ntkrnlpa.exe+d8781 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.0.6000.17021 (vista_gdr.100218-0019) 32-bit C:\Windows\Minidump\Mini040910-01.dmp 2 15 6000 Mini040310-01.dmp 03/04/2010 10:50:52 PM PAGE_FAULT_IN_NONPAGED_AREA 0x00000050 0x9e8a8923 0x00000000 0x818b6a9f 0x00000002 ntkrnlpa.exe ntkrnlpa.exe+a9ff2 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.0.6000.17021 (vista_gdr.100218-0019) 32-bit C:\Windows\Minidump\Mini040310-01.dmp 2 15 6000 Mini032510-01.dmp 25/03/2010 3:19:16 PM PAGE_FAULT_IN_NONPAGED_AREA 0x00000050 0xba96e603 0x00000000 0x818b6a9f 0x00000002 ntkrnlpa.exe ntkrnlpa.exe+a9ff2 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.0.6000.17021 (vista_gdr.100218-0019) 32-bit C:\Windows\Minidump\Mini032510-01.dmp 2 15 6000 Mini032110-01.dmp 21/03/2010 12:22:20 PM IRQL_NOT_LESS_OR_EQUAL 0x0000000a 0x9e9a97e3 0x00000000 0x00000000 0x818b6a9f ntkrnlpa.exe ntkrnlpa.exe+8fe14 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.0.6000.17021 (vista_gdr.100218-0019) 32-bit C:\Windows\Minidump\Mini032110-01.dmp 2 15 6000 Mini031810-03.dmp 18/03/2010 3:25:37 PM MEMORY_MANAGEMENT 0x0000001a 0x00041790 0xc0801728 0x0000ffff 0x00000000 ntkrnlpa.exe ntkrnlpa.exe+4047e NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.0.6000.17021 (vista_gdr.100218-0019) 32-bit C:\Windows\Minidump\Mini031810-03.dmp 2 15 6000 Mini031810-02.dmp 18/03/2010 3:21:35 PM PAGE_FAULT_IN_NONPAGED_AREA 0x00000050 0x9c2ef890 0x00000001 0x818e88d9 0x00000000 fltmgr.sys fltmgr.sys+28c5 Microsoft Filesystem Filter Manager Microsoft® Windows® Operating System Microsoft Corporation 6.0.6000.16386 (vista_rtm.061101-2205) 32-bit C:\Windows\Minidump\Mini031810-02.dmp 2 15 6000 Mini031810-01.dmp 18/03/2010 2:50:22 PM NTFS_FILE_SYSTEM 0x00000024 0x001904ab 0x88423a7c 0x88423778 0x8185e688 Ntfs.sys Ntfs.sys+d6f0 NT File System Driver Microsoft® Windows® Operating System Microsoft Corporation 6.0.6000.16386 (vista_rtm.061101-2205) 32-bit C:\Windows\Minidump\Mini031810-01.dmp 2 15 6000
I am running VISTA
Locale ID; 4105
sysdata.xml
version. txt
BCCODE: a
BCP1: 00020005
BCP2: 000000 1B
BCP3: 000000 1
BCP4: 81 CBB165
OS Version 6_0_6000
Service Pack 0_0
Product 768_1
Locale ID;4105
BCCODE f4
BCP1: 00000003
BCP2: 85FDA800
BCP3: 85FDA94C
BCP4: 81EAA730
OS Version 6_0_6000
Service Pack 0_0
Product 768_1
