Blue Sreen IRQL wit no networking
cmarz
This is a nightmare!! I have he BSOD with the IRQL not less or equal code. My VISTA OS fades to black before boot is complete. I I downloaded the Memory dump sysfile on to my backup PC, but I cannot find a way to get into my infected Laptop nor can I network out of it to post the file for review. Any ideas???
    Hewlet Packard
Are you able to get into Safe Mode? If so, you can try a system restore.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
I am. I did one sys retore with a recent (within 72 hour) restore point. Nothing improved. I also tried another round with a 15 day old resotre point. For some reason it could not complete during re-boot. Should I try one more time?
    Hewlet Packard
If it didn't error out, try again.
If it doesn't work, I suggest going to Safe Mode and Control Panel, Device Manager and check to see if there are any driver errors. If the BSOD error is a Stop, the problem is most likely a driver problem.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
