blue screen problem?
christk
sorry i just copy pasted this from my yahoo answers question mainly because im trying to get quick answers (because there may be not enough time)
idk what happened but when i turned on my sony vaio laptop,
windows attempted to repair my system and it waas unable to repair it.
It told me to click finish for a shutdown
then i turned it on again and it took sometime to load my account (which im guessing is that it was trying to locate explorer.exe maybe) so i witched to another account and logged back in.
then this one showed up:
windows recovered from shut down error something:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Additional information about the problem:
BCCode: a
BCP1: 00000016
BCP2: 0000001B
BCP3: 00000000
BCP4: 82A6A648
OS Version: 6_0_6001
Service Pack: 1_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\Mini123009-01.dmp
C:\Users\sony\AppData\Local\Temp\WER-164…
C:\Users\sony\AppData\Local\Temp\WER3330…
Im on win vista 32 bit. 4gb ram. uhhh..service pack 1
i use kaspersky net security 2010
last program i used before shutting down was
diablo 2 load with median XL mod.
IM NOT A TECH DUD OR ANYTHING AND CAN ANYONE TELL ME IF I SHOULD BE WORRIED OR IS THIS FIXED OR WHAT? what JUST happened?
RIGHT NOW, im using the same laptop. its all good.
will my laptop be fine though even if i dont do a system restore or reinstallation? and im too broke to take it to a tech store.
i just spend around $4000 this year for some things. mum will kill me alredy
25 minutes ago
what do you think caused it?
15 minutes ago
and what if i dont wanna do system restore. it pains me to have all my games and modifications erased. some of them CANNOT be backed up apparently.
ANYONE PLS HELP ME? other suggestions? :'(
additional details: (incase)
after the incident i checked my solutions thing at the control panel
and it suggested me to update and install windows service pack 2. its now installed on my system.
If this is the first time it happened, don't worry about it.
If it happens again, post back here and we'll work on it.
I have suspicions about the Kaspersky Internet Security - but this is way too early to start doing anything about it.
