Blue Screen Help!
Skeeter17
My computer recently started to blue screen without me changing anything about it. I've been fiddling trying to fix it but nothing seems to work. If anyone can help me out it would be greatly appreciated
Specs:
Vista Home Basic
Intel Pentium D CPU 3.00GHz, 3000Mhz, 2 Cores, 2 Logical Processors
Creative X-Fi Audio Processor
Video Card
EVGA NVIDIA GeForce 9500 GT
4G GSKILL ram.
BCCode: 124
BCP1: 00000000
BCP2: 85198028
BCP3: B2000000
BCP4: 1020080F
Hello Skeeter17,
Go to C > Windows > Minidump, zip up the files and upload them with your next post. You may have to save them to your desktop first.
When we get the files we will take a look for you.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
This is the result of your bugcheck.
STOP 0x00000124: WHEA_UNCORRECTABLE_ERROR
Usual causes: Hardware, Incompatibility, May be driver corruption
It could possibly be a driver, but is more likely to be a hardware problem.
If anything is overclocked set it back to default.
Start by updating your MB chipset drivers.
Check for over heating, in particular your CPU, the bugcheck points to your CPU being at fault.
Just check that its not getting too hot.
Has the CPU ever been overclocked ?.
Take a look and post your results, good luck.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
I'm updating the chipset drivers now.
The CPU has never been overclocked and i have the side panel off the computer there shouldn't be an over heating issue
Its quite possible that the paste is not as efficient as it should be.
Download and install this temp monitor and have a look at what your CPU and core temps are just before the BSOD comes.
Download SpeedFan - Access temperature sensor in your computer
It would not hurt to reseat the CPU and see if there is any improvement in system stability.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
