hello. last night, i turned my laptop on, then after the vista loading bar, it came with this of blue screen,
A problem has been detected and windows has been shut down to prevent damage to you computer.
A process or thread crucial to system operation has unexpectedly exited or been terminated.
If this is the first time..etc
If problem continues, disable..etc
Technical information:
*** STOP: 0x00000024 (0x001904AB,0x8DF03A44,0x8DF03740,0x82C5F362)
crash dump.....
Then it restarts and goes back to that again. I tried many times but the same thing happens. I also tried using safe mode but it wouldn't work. What can I do to fix this problem? thanks.
i have a toshiba laptop disc, but idk what is it for? will I lose all my data?
crash dump.....
