Blu Ray player on Vista64bit Not working
Brandon671
Hello all, i am a new user to this forum. I have been having troubles with "my Optiarc BD ROM BC-5500S". I've called Sony to try and determine the problem, unfortunately they only have free help the first 15 mins...usually they would like to drag on until time is up, after that i would have to pay 200.00 bucks to repair this! :( One thing they did tell me was, i have corrupted registry files...I purchased "registry mechanic" and it has found 157 errors that have been repaird...But still the drive is not working. I have looked up on the properties of this drive and it states that it is a CD-ROM drive, I know this use to play Blu ray's before once the computer was new... Please help...
Did it come with a CD with drivers on it?
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Brandon,
Is it possible for you to re-install Vista?
multiple problems generally cannot be easily sorted out.
Not just that it might start working properly after a re-install.
    HTPC/Desktop PC/Gateway LT2104u
    Intel Pentium 4 2.8Ghz with HT/3.0Ghz with HT/Atom N450
    GIGABYTE GA-81915ME-C/Intel D865GBF/Acer LT21
    2x1GB DDR 400Mhz/512x2GB DDR 400Mhz/1GB DDR2-800Mhz
    ECS 9800GT 512 DDR3/ Sapphire HD3650 AGP 8x 512MB/Intel 3150
    Turtle Beach RIVERIA 5.1 SPDIF Out/SoundMAX AD1985/Realtek H
    SONY BRAVIA KLV-32V300A V-Series/ KLV-19T400A/ Built-in
    1920x1080/1980x1080/1024x600
    MAXTOR 40GB WD ESSENTIAL EDITION 1TB USB Hitachi HDT721010SLA360 1TB SATA 150/ 250GB Toshiba
    OCZ Fatal1ty 550W/
    Lian-Li v351, Lancool K-62 DragonLord
    Logitech Combo
    Logitech Combo
    512 Kbps
Brandon,
I wouldn't recommend a reinstallation of an OS until we have established that the problem cannot be solved.
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
