Blocked Sites i need help please
Jzjk
Ok so i have blocked these sites through this:notepad c:\WINDOWS\system32\drivers\etc\hosts
and then I think I put a block on top of that so it couldn't be changed but I can't remember. If you think you can help me get the sites back unblocked that would be great. Thanks.
~Jzjk
This was also through the command prompt
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
No. Simply unzip the file (I had to zip it in order to attach it) and then replace the file in C:\Windows\System32\drivers\etc\ with this copy.
    Gigabyte IF233
Save the file on your computer, then right-click and select Extract All...
    Gigabyte IF233
Now right click on it and select Copy. Browse to the location I gave earlier and right click again and select Paste. Confirm that you want to replace the file.
    Gigabyte IF233
i tried entering the information and its saying its unrecongized
c:\WINDOWS\system32\drivers\etc\ I typed this in is there more?
ok so i tried to replace it and i got to but when i went to look at it again it showed the blocked sites.
OK. Can you post back with YOUR copy of the hosts file (you will need to zip it) and I'll have a look at it.
    Gigabyte IF233
