I'm having a problem with Windows Vista Home Premium, whenever I go to select a profile "Administrator" or "AL".
AL gives me a black screen with an error message "Windows Explorer has encountered and error and had to close", it also says "Host Process has encountered and error and needs to close", after opening Task Manager. If I try to open explorer.exe through Task Manager, it stops working, and I can't get anything else working either it just has the same problem.
The only process running are:
csrss.exe "System"
dwm.exe "AL"
taskeng.exe "AL"
taskmgr.exe "AL"
winlogon.exe "System"
Safe Mode also has the same problem.
I can only get into Repair Your Computer
Administrator has a blue screen problem ( i activated the account yesterday hoping i could fix the problem) it also has the Windows Explorer has stopped working and so on.
A few weeks before I had a blue screen with the account AL, but I had the Documents then, then a few days later I restored the desktop by going into the registry and fixing the problem, it worked fine, but know i have this Black Screen problem.
I would really like some help with this problem.
csrss.exe "System"
dwm.exe "AL"
taskeng.exe "AL"
taskmgr.exe "AL"
