jagobruford
Can any one help with my start up problem?
For my desktop pc I have a power and boot up problem that does like this……….
Turn on main front power button
BIOS screens run through all OK
Windows startup screen runs OK (with the flashing green/yellow bar)
Then what normally happens is a pause of one or two seconds before the Windows iconappears and I can login.
What has been occurring recently is at this pause, the screen stays black and the computer goes into what can only be described as a low power mode. I sense this as the fan speed reduces, sometimes uneven and the screen stays black. Nothing else will happen.
BUT if I turn the pc off at the main power button at the rear and switch on again it will boot up, all through the processes with no problems. However if I do this at the stage above I have effectively forced a shut down and Windows enter via ther ecovery, but this still works fine. Windows etc works then with no problems atall.
Also if after shutting the PC down correctly I turn off the rear power button and turnit on before start up, all starts OK.
No devices are connected and powered on at start up other than Netgear router. I have disabled the devices (Control panel, Device manager, Properties) to “wake” the computer (mouse and keyboard) and also the Network Adapter, all of which were causingp roblems in waking the computer. This was a while ago and has been working fine for many months.
Any goodi deas would be appreciated. Could it be a software problem (drivers?) or ahardware problem (power supply?)
- Intel Core 2 Quad Q6600
- ASUS P5K
- Corsair CM2x2048 400 MHz x 4
- NVIDIA GeForce 8800 GTX
- Microsoft
- LG L226W
- Western Digital WDC 150 GB - main Western Digital WDC 500 GB - data
