BIOS "POST" Beep Codes for AMI and Phoenix BIOS
Martee
Vista Die-Hard
When an IBM compatible computer is first turned on, the hardware runs a Power-On Self Test (POST). If errors are encountered during this POST test, they are usually displayed via an audio beep or in the form of a code number flashed across the screen. With this audio code in hand, you can determine what part of the system is having problems and find a solution.
<small>The pattern of beeps whether its the number of beeps or the length of those beeps will give you an indication of the actual problem. Its a distress signal from the computer in a morse code like pattern. Unless you have a diagnostic card to tell you more about the particular problem, you will have to use the charts below to decipher the computer error and get your machine back up and running.
ir
Source: </small>
BIOS Error Beep Codes
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
handy.......
thanks. :)
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech EX110
    logitech cordless optical
    2mb
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G15
    Logitech G5
    20Mbps
Glad you found it useful guys. Thank you. :)
Cheers...
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
Some of the advanced motherboards also have a two digit led display that will tell you how far the bios has gotten. The IP35 pro is one such board.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
Most modern boards do now, my XFX 750i does, and my friend's ASUS P6T6 does, too. Although I'm skeptical about some. When I built it for him, it wouldn't boot and the error code that the LED (error code 88) wasn't defined in the manual or anywhere on the Internet :sarc:
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
Some of the boards just tell you how far they have got. I wonder if that is the reason.
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
